Re: Jessie Q&A
Fri Oct 16, 2015 11:50 am
blackminion wrote:I installed Jessie ;)
now I want to be my desktop in the form below
http://s6.picofile.com/file/8188199468/Capture.JPG
How can i do this ???
Right Click Task Bar
Left Click Panel Settings
Retired disgracefully.....
PalmBox
Re: Jessie Q&A
Fri Oct 16, 2015 3:22 pm
Hello, I would like to delete the graphical interface under Jessie to make os lighter. How to do this ? Thanks !
Re: Jessie Q&A
Fri Oct 16, 2015 3:27 pm
PalmBox wrote:Hello, I would like to delete the graphical interface under Jessie to make os lighter. How to do this ? Thanks !
Undertake a net-install and just install what you require:
https://github.com/debian-pi/raspbian-ua-netinst
Tavalin
Re: Jessie Q&A
Fri Oct 16, 2015 5:02 pm
I'm getting the following when trying to update/upgrade packages after a clean install.
[email protected] ~ $ sudo apt-get update
Get:1 http://mirrordirector.raspbian.org jessie InRelease [15.0 kB]
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main Sources
Hit http://archive.raspberrypi.org jessie/ui Sources
Get:2 http://mirrordirector.raspbian.org jessie/main armhf Packages [8,961 kB]
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Get:3 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37.4 kB]
Get:4 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70.2 kB]
Get:5 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1,356 B]
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 9,085 kB in 18s (500 kB/s)
Reading package lists... Error!
E: Unable to parse package file /var/lib/dpkg/status (1)
E: The package lists or status file could not be parsed or opened.
What's wrong with it?
diederik
Re: Jessie Q&A
Fri Oct 16, 2015 6:50 pm
Tavalin wrote:I'm getting the following when trying to update/upgrade packages after a clean install.
/var/lib/dpkg/status keeps track of the packages installed on your system.
If you really lost that file, you're basically screwed and you better start over.
Bosse_B
Re: Jessie Q&A
Fri Oct 16, 2015 7:55 pm
SAMBA in Jessie?
I am trying to set up samba in Jessie but I cannot make it work according to the webpages I have found to help me set it up.
Please give advice on how it works under systemd on Jessie (installation, configuration, start, stop).
I need the share to handle development source files.
EDIT:
Turns out tha samba was not installed even though it did exist as directory entries and the sample smb.conf file was where it was supposed to.
After doing:
sudo apt-get install samba samba-common-bin
everything started working.
Bo Berglund
Sweden
Re: Jessie Q&A
Fri Oct 16, 2015 8:12 pm
Bosse_B wrote:SAMBA in Jessie?
This is based on Debian 8 Desktop:
https://www.howtoforge.com/tutorial/debian-samba-server
Tavalin
Re: Jessie Q&A
Fri Oct 16, 2015 10:22 pm
Is the image available corrupt then? I've downloaded it three times, using both the torrent and the mirror links and I get the same every time I write the OS to the micro sd card.
Bosse_B
Re: Jessie Q&A
Fri Oct 16, 2015 10:34 pm
PPTP VPN Client setup in Jessie?
Asked before but never got a working system. Has anyone here managed to get a connection from Jessie to a corporate network using a PPTP VPN client?
Tutorials on the net for Debian are no good because they refer to GUI tools that are simply non-existing in Raspbian Jessie. :cry:
The steps I have taken did not lead to a working connection; I can elaborate if someone here is "in the know" and can help.
I used this:
http://devtidbits.com/2013/02/19/using- ... pberry-pi/
but it does not describe handling of errors. All of my connection attempts failed.
Bo Berglund
Sweden
magifix
Re: Jessie Q&A
Sat Oct 17, 2015 4:53 pm
diederik wrote:
DougieLawson wrote:
diederik wrote:Unfortunately, the kernels provided by the Raspberry Pi foundation still don't have a kernel-headers package :(
You don't need a headers package, just pull a copy of the 4.1.10+ source tree.
Not 'just'.
You need to set a couple of things up before that's usable so you can compile kernel modules.
And then you still haven't satisfied the linux-headers package dependency of dkms.
And yes, you can work around that too. But I doubt 'average Joe' knows how to do that all.
I agree, intel arch ist much easier. I did proceed by building a kernel (https://www.raspberrypi.org/documentati ... uilding.md), and got a brand new kernel (4.1.10), but it was still the same with xtables-addons-common (or dkms). So I decided to go on my own, and compiled myself xtables-addons source. This last about one hour to build the new kernel (thanks to -j4), and few minutes to get the xtables-addons working. I'm just asking me why the distribution is almost unsuable in my case?
tpylkko
Re: Jessie Q&A
Sat Oct 17, 2015 6:05 pm
did youverify the md5 sum?
klricks
Re: Jessie Q&A
Sat Oct 17, 2015 6:57 pm
Tavalin wrote: Is the image available corrupt then? I've downloaded it three times, using both the torrent and the mirror links and I get the same every time I write the OS to the micro sd card.
I would try on a different SD card. Note Jessie requires an 8GB SD card
Tavalin
Re: Jessie Q&A
Sun Oct 18, 2015 12:01 pm
tpylkko wrote: did youverify the md5 sum?
The sha-1 checksum matches so I know it downloaded fine.
klricks wrote:I would try on a different SD card. Note Jessie requires an 8GB SD card
I'll try a different one but this particular card has been running fine in my Pi for the last 6 months on Wheezy.
TexasBill
Re: Jessie Q&A
Mon Oct 19, 2015 6:59 pm
Having trouble with the main menu editor (in Jessey)
Anytime I try to modify the menu structure, the whole menu disappears and I am unable to get it back.
devenh
Re: Jessie Q&A
Tue Oct 20, 2015 5:20 pm
I must be doing something wrong as every time I try to run one of my install scripts that worked with Wheezie, I get an error:
E: Package 'samba' has no installation candidate
I get the same type of error when trying to install iceweasel, xrdp, terminator, etc. What have I overlooked?
EDIT:
After doing:
diederik
Re: Jessie Q&A
Wed Oct 21, 2015 9:38 am
devenh wrote:every time I try to run one of my install scripts that worked with Wheezie
Then you need to upgrade your install scripts to work with jessie ...
... and if you want others to help you with that, it may be an idea to post them or when they are public, point to them.
gordon77
Re: Jessie Q&A
Wed Oct 21, 2015 9:48 am
I have a couple of issues with Jessie:
My RTC no longer works, I am using this setup http://www.cjemicros.co.uk/rpi-rtc which works fine with Wheezy.
Also I can't set hdmi_group=2 and hdmi_mode=14 in /boot/config.txt and get a 840x480 display, just a hi-res one out of focus, again works fine in Wheezy.
Any answers ?
Gordon77
Re: Jessie Q&A
Wed Oct 21, 2015 10:07 am
The RTC stuff should be done in /boot/config.txt. Read /boot/overlays/README for the full details.
Are you editing the right config? Use the NOOBS recovery system config editor (by holding [SHIFT] during boot).
This is a doctor free zone.
gordon77
Re: Jessie Q&A
Wed Oct 21, 2015 10:09 am
DougieLawson wrote:The RTC stuff should be done in /boot/config.txt. Read /boot/overlays/README for the full details.
Yes right config as far as I know, I use Raspbian not NOOBS. All works fine with Wheezy.
Gordon
Re: Jessie Q&A
Wed Oct 21, 2015 10:39 am
My RTC set-up worked with Wheezy.
dtoverlay=i2c-rtc,ds1307
If it doesn't work that's a feature of the kernel you're running, not the OS that it loads with /sbin/init.
gordon77
Re: Jessie Q&A
Wed Oct 21, 2015 10:56 am
I've disabled all the rtc stuff in rc.local and have
dtparam=i2c_arm=on
in /boot/config.txt
but still not working, anything else to do ?
Re: Jessie Q&A
Wed Oct 21, 2015 11:41 am
ShiftPlusOne
Re: Jessie Q&A
Wed Oct 21, 2015 11:44 am
I wouldn't consider that a kernel issue. I think it's best sorted on the forum in a separate thread with a clear description of all the steps taken and content of files modified.
gordon77
Re: Jessie Q&A
Wed Oct 21, 2015 11:46 am
ShiftPlusOne wrote:I wouldn't consider that a kernel issue. I think it's best sorted on the forum in a separate thread with a clear description of all the steps taken and content of files modified.
What else do you need to know, l've detailed above what l've done?
Any thoughts on the hdmi mode issue?
Gordon
dom
Re: Jessie Q&A
Wed Oct 21, 2015 12:11 pm
gordon77 wrote: Any thoughts on the hdmi mode issue?
Very unlikely to be directly related to Jessie. It will be a firmware issue (that the upgrade to Jessie happened to update).
Create a github issue and we can do some troubleshooting.
Return to “Raspbian”
