Massi
Re: Jessie Q&A
Sun Oct 11, 2015 9:27 am
Massi wrote:what am i missing?
i couldn't get pigpiod to run as service even in this way
https://gist.github.com/tstellanova/7323116
stav242
Re: Jessie Q&A
Sun Oct 11, 2015 9:03 pm
Hi, tried several times to get apt-get working.
i simply write the lastest Jessie image to a SD card.
boot up and try `sudo apt-get update`
getting ....
Reading package lists... Error!
E: Encountered a section with no Package: header
E: problem with Mergelist /var/lib/dpkg/status
E: the package lists or status file could not be parsed.
-ive tried the apt-get clean.
any ideas ?
macrutan
Re: Jessie Q&A
Sun Oct 11, 2015 9:36 pm
I noticed that the elinux.org and raspbian.org sites have not been updated to reflect this wonderful evolution. Is anyone here involved with updating those wikis? or is anyone here able to send them copy?
Re: Jessie Q&A
Mon Oct 12, 2015 4:43 am
macrutan wrote:I noticed that the elinux.org and raspbian.org sites have not been updated to reflect this wonderful evolution. Is anyone here involved with updating those wikis? or is anyone here able to send them copy?
Forget the elinux.org one, it's old.
Plugwash may be able to update the notes on the Raspbian site to change the references from Wheezy to Jessie in the recommended sources.list entries. However the fact that the Foundation has decided to switch to using Jessie in their images is not an issue that necessarily requires the Raspbian people to act. They provide a (rather excellent) repo. The RPF decided to use/recommend that repo.
Bosse_B
Re: Jessie Q&A
Mon Oct 12, 2015 9:41 pm
I have started a separate thread about the strange way the start Menu in Jessie behaves.
Please check what is going on there.
Newly installed GUI programs do not appear on the Menu until another GUI program is installed, which in its turn does not show up...
Seems like there is an OBOB bug somewhere in Jessie or the Raspbian flavour.
Bo Berglund
Sweden
engineer_m
Re: Jessie Q&A
Tue Oct 13, 2015 4:52 pm
I recently installed the latest version of Raspbian and found out that /etc/inittab is missing. What seems to be the problem?
ShiftPlusOne
Re: Jessie Q&A
Tue Oct 13, 2015 5:11 pm
engineer_m wrote:I recently installed the latest version of Raspbian and found out that /etc/inittab is missing. What seems to be the problem?
No problem. inittab is a feature of sysvinit. sysvinit has been reeplaced with systemd.
engineer_m
Re: Jessie Q&A
Tue Oct 13, 2015 5:43 pm
Can you please give instructions on how to:
1. enable/ disable serial console
2. change baud rate
3. disable data and logs on serial port when booting ( i used to acomplish this with deleting this line in the /etc/inittab: T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100)
ShiftPlusOne
Re: Jessie Q&A
Tue Oct 13, 2015 6:05 pm
jimla
Re: Jessie Q&A
Wed Oct 14, 2015 12:24 am
Re: SSH login problems. My error: I was using the wrong IP address for the Pi. I used ifconfig to determine the Pi ethernet address and SSH is working fine.
Michael_O
Re: Jessie Q&A
Thu Oct 15, 2015 11:59 am
The fim image viewer package seems to have gone missing from jessie, is this an oversight and will it be replaced or is there a reason for leaving it out?
I use a bash script to take pictures, save them and then display them for 10 seconds before taking the next one. When the script is finished I combine the collected images into a 1fps timelapse video. The subject is an artist making a drawing over about 15 minutes. Fim has a good set of parameters for doing the display including the 10s delay and is a recommended update of fbi.
I hope we can get it back.
Michael
ShiftPlusOne
Re: Jessie Q&A
Thu Oct 15, 2015 12:08 pm
Michael_O wrote:The fim image viewer package seems to have gone missing from jessie, is this an oversight and will it be replaced or is there a reason for leaving it out?
Michael
It seems to have been dropped by Debian:
https://packages.debian.org/search?keyw ... ection=all
magifix
Re: Jessie Q&A
Thu Oct 15, 2015 5:28 pm
I just installed the lasttest release (Linux raspberrypi 4.1.7-v7+). Can someone tell me why it want to get some old kernel headers when installing getting xtables-addons:
[email protected]:~# apt-get install xtables-addons-common
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Les paquets supplémentaires suivants seront installés :
cpp-4.6 dkms firmware-linux-free gcc-4.6 libuuid-perl linux-base linux-headers-3.6-trunk-common linux-headers-3.6-trunk-rpi
linux-image-3.6-trunk-rpi linux-kbuild-3.6 xtables-addons-dkms
Paquets suggérés :
gcc-4.6-locales libmudflap0-4.6-dev gcc-4.6-doc libgcc1-dbg libgomp1-dbg libquadmath-dbg libmudflap0-dbg libcloog-ppl1
libcloog-ppl0 libppl-c4 libppl12 libppl9 linux-doc-3.6 debian-kernel-handbook fdutils libtext-csv-xs-perl
Paquets recommandés :
linux-headers-686-pae linux-headers-amd64 linux-headers-generic linux-headers linux-image
Les NOUVEAUX paquets suivants seront installés :
linux-image-3.6-trunk-rpi linux-kbuild-3.6 xtables-addons-common xtables-addons-dkms
0 mis à jour, 12 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 23.7 Mo dans les archives.
Après cette opération, 89.3 Mo d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n]
blackminion
Re: Jessie Q&A
Thu Oct 15, 2015 9:13 pm
Hello
I downloaded Jessie . :D
Now how can I offline install Jessie ?
(Install from SDCard)
kusti8
Re: Jessie Q&A
Thu Oct 15, 2015 9:23 pm
blackminion wrote:Hello
I don't understand your question. What is there to offline install when you've already downloaded the img file? All you have to do is write the image, using Win32DiskImager or dd, or just use NOOBS.
blackminion
Re: Jessie Q&A
Thu Oct 15, 2015 11:29 pm
kusti8 wrote: I don't understand your question. What is there to offline install when you've already downloaded the img file? All you have to do is write the image, using Win32DiskImager or dd, or just use NOOBS.
Hi
I do not want update
I want to install Jessie from images
But I do not know how Can I install jessie.img
diederik
Re: Jessie Q&A
Thu Oct 15, 2015 11:49 pm
magifix wrote:I just installed the lasttest release (Linux raspberrypi 4.1.7-v7+). Can someone tell me why it want to get some old kernel headers when installing getting xtables-addons:
That's because it recommends xtables-addons-dkms which needs kernel headers to work and according to the Debian package page it really needs the dkms package in order to be useful.
Unfortunately, the kernels provided by the Raspberry Pi foundation still don't have a kernel-headers package :(
diederik
Re: Jessie Q&A
Thu Oct 15, 2015 11:50 pm
blackminion wrote:I want to install Jessie from images
Re: Jessie Q&A
Fri Oct 16, 2015 12:07 am
diederik wrote:Unfortunately, the kernels provided by the Raspberry Pi foundation still don't have a kernel-headers package :(
You don't need a headers package, just pull a copy of the 4.1.10+ source tree.
This is a doctor free zone.
diederik
Re: Jessie Q&A
Fri Oct 16, 2015 9:02 am
Not 'just'.
You need to set a couple of things up before that's usable so you can compile kernel modules.
And then you still haven't satisfied the linux-headers package dependency of dkms.
And yes, you can work around that too. But I doubt 'average Joe' knows how to do that all.
Michael_O
Re: Jessie Q&A
Fri Oct 16, 2015 10:00 am
Michael
Well that's a pity, I'll just have to look at the syntax for fbi and see if I can get what I want from it.
I note Plugwash located the bug report from 2013 asking to have it removed for bugs/lack of maintenance.
Thank you both for your trouble.
blackminion
Re: Jessie Q&A
Fri Oct 16, 2015 10:26 am
I installed Jessie ;)
now I want to be my desktop in the form below
http://s6.picofile.com/file/8188199468/Capture.JPG
How can i do this ???
plugh
Re: Jessie Q&A
Fri Oct 16, 2015 11:42 am
Is there a "noX" build available? (nightlies only has wheezy builds)
dom
Re: Jessie Q&A
Fri Oct 16, 2015 11:47 am
plugh wrote:Is there a "noX" build available? (nightlies only has wheezy builds)
This is jessie/NoX: viewtopic.php?f=66&t=111144&p=827424#p822611
Return to “Raspbian”
