Jackotheoz
saving config.txt on raspian
Thu Sep 24, 2015 11:42 am
Hello all, I am using Raspian that comes with Noobs.
I want the monitor full screen, read the instructions, unquoted the lines required and tried to save. The save changes to 'config.txt'? appears, I press yes. I select the config.txt from the list and press save. I get the message that 'config.txt' already exists Overwrite?. I select yes then the error message pops up and says, Can't open file to write. How do I save changes to this file please?
metalj
Re: saving config.txt on raspian
Thu Sep 24, 2015 12:05 pm
Did you:
Press Control-x
Press y
Press [enter]
Backspace 28 times :)
Thu Sep 24, 2015 12:06 pm
Jackotheoz wrote:Hello all, I am using Raspian that comes with Noobs.
NOOBS has its own config editor:
Edit Config: Opens a text editor allowing the cmdline and config for the selected installed OS to be edited.
https://github.com/raspberrypi/noobs
Thinking outside the box is better than burying your head in the sand...
Jackotheoz
Mon Oct 05, 2015 4:59 am
metalj wrote:Did you:
Press Control-x
Press y
Press [enter]
Up until now I hadn't done that. Seems like a NOOB has a lot to learn. Thank you for the advice.
Also, how do I load "LINARO" to a spare SD card? Have tried it many ways with no joy..... :? Unpacked it to the SD card, no joy in getting it to boot.
Maybe someone can point me to a "Linux for totally dumb Noobs" book or similar. :D
Return to “Raspberry Pi OS”
