mpthompson
Raspbian hosted on Raspbian
Fri Jul 20, 2012 10:22 pm
I'm not certain that I'd recommend this for everyone, but the folks at Mythic Beasts are hosting a Raspbian mirror on a Raspbian Raspberry Pi server.
http://blog.mythic-beasts.com/2012/07/2 ... f-hosting/
Good stuff. :)
plugwash
Re: Raspbian hosted on Raspbian
Fri Jul 20, 2012 10:38 pm
hmm, running apache is probablly a mistake......
computerpie
Sat Jul 21, 2012 12:41 pm
I'd like to have my raspi where I'd be confident enough to run as a webserver.
Is there any possibilities that they would share their hardware setup details? Please be specific with model #'s and mfg.
What OS? Any tweeks such as mem split , etc they are using?
How are they powering it? powered hub? Model. part number?
SD card? Model/part # ?
Mouse and Kb? Model Part# ?
Raspi eth0 hooked to hub, switch, router?
Any info to get a rock solid Raspi? I want to finalize my hardware setup and move on to bigger and better things.
Thanks for any input. I do like Raspbian much better than the Squeeze distro. Great work on that.
Pi1>OS: Rasbian Pi2>OS:Xbian .63
1:HDMI>>DVI>>Flat Screen Monitor
2: HDMI>>Toshiba 37" LCD
1:ASUS Wired USB Keyboard and Mouse
2:Logitech wireless mouse, CEC remote
SanDisk SDHC C4 8GB SD
kadamski
Sat Jul 21, 2012 12:53 pm
Most of the questions you asked are answered in the linked article. There are no part numbers but still...
computerpie
Sat Jul 21, 2012 12:59 pm
kadamski wrote:Most of the questions you asked are answered in the linked article. There are no part numbers but still...
I realize that. The point is I don't want to buy accesories, get them home and find out they don't work, take them back and so on. :) I found out the hard way that going on specs alone isn't bullet proof.
Thanks.
plugwash
Sat Jul 21, 2012 1:02 pm
Why would you need a hub anyway, it's just another thing to potentially cause problems.
computerpie
Sat Jul 21, 2012 1:06 pm
plugwash wrote:Why would you need a hub anyway, it's just another thing to potentially cause problems.
Right my point exactly. :D Every piece of this Pi puzzle is another variable and I want to eliminate all or most variables.
plugwash
Sat Jul 21, 2012 1:08 pm
Personally if I was going to do this i'd get a decent 5V PSU that could supply both Pi and drive and then mod cables as nessacerry to hook it up and I wouldn't use a hub at all.
computerpie
Sat Jul 21, 2012 1:16 pm
My ultimate goal is to have enough usb ports to handle, Kb, mouse, usb wifi, usb hdd(s) and maybe later items.
I'm seriously considering taking a pc power supply, make a circuit to regulate all the power rails I need +5, +- 12v, 3.3v ...etc. Power everything off that. Using powered hubs, phone chargers isn't giving me any confidence that I want to put this baby into production! :shock:
Return to “Raspbian”
