truehl
Twonky on Raspbian
Fri Jul 20, 2012 9:15 am
Is there a way to install the Twonky Media Server on Raspbian ?
truehl
http://www.squeezeplug.de
truehl
Re: Twonky on Raspbian
Mon Jul 30, 2012 1:36 pm
Hi folks,
I can't believe there is absolutely no one able to answer this!
Please help,
thanks a lot,
Thomas
truehl
bob_binz
Mon Jul 30, 2012 4:38 pm
Dunno if this helps, but try here: community.twonky.com/twonky/topics/arm_versions
truehl
Mon Jul 30, 2012 7:35 pm
Hi Folks,
the "old" version of Twonky Media Server is runnng well on Raspbian by doing this commands:
mkdir /usr/local/twonkymedia/
cd /usr/local/twonkymedia/
wget http://www.twonkyforum.com/downloads/6.0.30/twonkymedia-kirkwood-6.0.30.zip
unzip twcdonkymedia-kirkwood-6.0.30.zip
chmod 700 twonkym* cgi-bin/* plugins/*
route add -net 224.0.0.0 netmask 240.0.0.0 dev eth0
/usr/local/twonkymedia/twonky_start.sh start
I tried to get a new version to run as well: http://www.twonkyforum.com/downloads/7.0.8-Special/ I picked the kirkwood version with no luck. Is anyone able to get this version to work? I think there is only a little step to success!
Greetings,
Thomas
truehl
isketerol
Thu Aug 16, 2012 12:13 pm
The correct commands given above seem to have gotten managled a bit. This worked:
unzip twonkymedia-kirkwood-6.0.30.zip
/usr/local/twonkymedia/twonkymedia.sh start
The Twonky Server is at http://<hostname>:9000
Create startup and shutdown scripts in /etc/rc3.d to automatically start and stop the software.
bighippo999
Mon Sep 24, 2012 11:44 pm
Thanks to the previous posters. I've been trying for a few days without any luck.
Find below the steps for the latest version of the Twonky 6.x.x branch. I've tested and it works with the latest image.
wget http://www.twonkyforum.com/downloads/6.0.39/twonkymedia-kirkwood-6.0.39.zip
unzip twonkymedia-kirkwood-6.0.39.zip
scorp
Thu Sep 27, 2012 8:48 pm
I installed Twonky 6 and registered it but whatever I try to open on my DLNA TV, it shows as not supported format (video, audio, pictures)
scorp
Fri Sep 28, 2012 11:05 am
all as NON-DLNA apart from few PNG files
llionevans
Fri Sep 28, 2012 12:05 pm
When I do the above all is fine until the final line where I get the error
Starting /usr/local/twonkymedia/twonkymedia ... /usr/local/twonkymedia/twonkymedia.sh: 91: /usr/local/twonkymedia/twonkymedia.sh: /usr/local/twonkymedia/twonkymedia: not found
I know that the file is there, I can see it when I do 'ls' and it has the permissions -rwx------
Any ideas?
pi_bald
Thu Nov 15, 2012 10:04 am
I got Twonky 7.0.8 running using
mkdir /usr/local/twonky/
cd /usr/local/twonky/
wget http://www.twonkyforum.com/downloads/7.0.8-Special/twonky-kirkwood-special-7.0.8.zip
unzip twonky-kirkwood-special-7.0.8.zip
chmod 700 twonky* cgi-bin/* plugins/*
mkdir /var/twonky
/usr/local/twonky/twonky.sh start
Once up and running I used webmin to add the service at bootup and shut down.
Edd321
Sun Dec 23, 2012 3:11 pm
I have installed Webmin but I am having difficulty and setting up the start on boot for Twonky (im fairly new to this). What script did you use to get it to start.
Also is there any solution over Twonky changing the IP on its links when accessing outside the main network?
Many thanks
mcgyver83
Wed Jan 02, 2013 3:17 pm
I'm following the instructions for Twonky 7.0.8 posted above, any news for the 7.1.2 version?
darrencuk
Raspberry Pi Certified Educator
Wed Jan 16, 2013 11:10 am
I have just discovered twonky and it seems to do what I want of my Pi. I would like to know if there is a demo version available before I pay for a license?
Thanks in advance
Darren.
MartinJSaunders
Wed Feb 13, 2013 10:54 pm
You'll need to change the twonky.sh script to work nicely with Raspbian:
Change:
# Default-Start: 3 5
# Default-Stop: 0 1 2 6
to:
# Required-Stop:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
I did this and then used Webmin to start on boot and off we went :)
Got this from here: http://server.vijge.net/archive/twonky- ... humbnails/
sonicdacrack
Wed Feb 20, 2013 7:19 am
Hey you guys,
i am trying to setup an twonky server but sadly the twonkyforum is down :-)
Anyone got the twonky-kirkwood-special-7.0.8.zip or newer on hand from a diffrent source?
That would be great so i can complete my project.
Return to “Raspbian”
