saary
rc.local
Sat Aug 15, 2015 6:48 pm
hi,
i'm new to all of this. i have raspberry 2 b. i installed blynk and it is working.
i want to start blynk at reboot so i added
./blynk-library/linux/blynk --token=<my token> &
in rc.local
when i run
sudo /etc/init.d/rc.local start
it works. but if i reboot. it doesn't work
i have already made /etc/rc.local executable
please advice
thank you
Re: rc.local
Sat Aug 15, 2015 6:58 pm
You need to put the full path of the file name.
You can't have
in /etc/rc.local because rc.local usually gets run with the working directory set to "/", but when you run
the working directory will be wherever you are at the time - probably /home/pi ?
So what you'd need is
/home/pi/blynk-library/linux/blynk --token=<my token> &
saary
Re: rc.local
Sat Aug 15, 2015 7:09 pm
Damn, you nailed it.
thank you very much
Return to “Raspberry Pi OS”
