jorisvergeer
bootc kernel compiled for armhf
Thu Jul 19, 2012 8:54 pm
For everyone who want to play with bootc kernel in raspbian. (http://www.bootc.net/projects/raspberry-pi-kernel/)
A newer kernel version from the 3.2 branch with more modules and drivers enables.
I compiled a version with armhf support.
https://github.com/downloads/jorisverge ... 23+.tar.gz
I didn't create a debian package (i don't really have time to discover how that works) but installation is as simple as unpacking a tar.gz in the root of your filesystem.
edit:
first do this:
sudo cp /boot/kernel.img /boot/kernel.img.bak
so you have a backup when you want to move back to the original kernel
cd /
sudo tar zfxv /path/to/RPi_bootc_kernel_modules_armhf_3.2.23+.tar.gz
Or if you think this is unsafe you can always unpack it in some other directory ans copy the files manually.
I give full credit to bootc and his custom RPi kernel:
https://github.com/bootc/linux/
I only rebuild it with my optimized toolchain for armhf.
drkbcn
Re: bootc kernel compiled for armhf
Tue Jul 31, 2012 6:09 pm
I'm trying to compile my kernel using bootc sources and the following command:
make ARCH=arm CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf- -k -j 3
I'm using your .config file (zcat /proc/config.gz > .config) to ensure I'm not choosing something wrong on menuconfig. Everything compiles ok, but when a put my kernel.img (modules and firmware to /lib) to my boot partition my Raspberry doesn't boots. Then I tried to compile my own toolchain with bootc's tutorial from thinking that my "arm-linux-gnueabihf" it would be the problem:
http://www.bootc.net/archives/2012/05/2 ... pberry-pi/
But I get the following error when I run "make" after config ct-ng:
Could not retrieve 'eglibc-2_15'
(seems that fails on getting this tarball)
Can you tell me how do you compile your ARMHF version, or where I can find a tutorial to make my own cross compiler? Your help is much appreciated.
Thanks in advance :)
PS: My firmware is updated to lastest version
PS2: I apologize for my English :P
cubii
Mon Aug 13, 2012 9:40 pm
hi wanted to try your kernel, but the download is dead...
Why?
cyberdemon
Tue Aug 14, 2012 11:09 pm
I would also like to try this kernel, and found a 404 :(
I want both i2c and hardfloat, and am struggling to get a crosscompiler working.
I guess i'll have to compile on the Pi.. How many weeks will that take I wonder.
Return to “Raspberry Pi OS”
