aqab0N
RPI-Update
Thu Jul 19, 2012 8:35 pm
Heyho,
could it be that it isn't a quite good idea to use hexxeh's rpi-update for raspbian?
I tried it two times and both times my pi doesn't boot after a update with it. :oops:
Beini
Re: RPI-Update
Thu Jul 19, 2012 8:37 pm
You really don't need it anymore as the files are now distributed from apt repository.
aqab0N
Re: RPI-Update
Thu Jul 19, 2012 9:11 pm
okay. thanks :)
AndrewS
Re: RPI-Update
Fri Jul 20, 2012 12:40 pm
...but I believe the firmware updates installed via apt-get are released at a much slower rate than via rpi-update. I think in effect rpi-update is the bleeding edge, and apt-get will be the tested, stable versions :)
jbeale
Re: RPI-Update
Fri Jul 20, 2012 2:39 pm
for the uninformed among us, how does the update work?
sudo apt-get install firmware (?)
ntadej
Re: RPI-Update
Fri Jul 20, 2012 3:11 pm
I think that firmware is already installed on the images provided by the foundation. apt-get update and apt-get upgrade would be enough
Return to “Raspbian”
