plugwash
Re: Java on Raspbian
Tue Dec 11, 2012 4:36 pm
dpkg --print-architecture
dms
Tue Dec 11, 2012 10:45 pm
2012-08-08-wheezy-armel has soft fp
uname -a gives 3.1.9+ #272 PREEMPT
ls /lib | grep arm-linux-gnueabi gives arm-linux-gnueabi
2012-10-28-wheezy-raspbian has hard fp
uname -a gives 3.2.27+ #160 PREEMPT
ls /lib | grep arm-linux-gnueabi gives arm-linux-gnueabihf
I am running tests on the vfp with 'C' and assembler routines.
gcc -c -mfloat-abi=hard test.c gives an error on a soft fp system.
Hope this helps
Don
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Wed Dec 12, 2012 4:27 am
I haven't been able to track what's been going on here since the presentations at Java One a few months ago, but from a quick scan of the posts here, we don't expect Oracle to release a Raspbian-compatible version of a JDK until they release Java 8 in Fall 2013, correct?
So, I've gotten the impression that the best-performing Raspbian-compatible alternative is OpenJDK 7 with JamVM, which I timed and am very impressed, but Avian doesn't seem to fare as well as JamVM (although still far better than OpenJDK 7). Mind you, these were just a few typical demos that could be quickly compiled that were picked at random to make sure my installation was working.
Next, on to try out some OpenGL ES stuff ... with Blocky as a starting point? :)
plugwash
Wed Dec 12, 2012 12:56 pm
In the quick test I did (see my post in the java forum) avian beat jamvm but I imagine this is very workload specific.
ota-kun
Thu Dec 13, 2012 1:21 pm
@Jim
Oracle never stated a release date, but they stated that they will bring a Raspbian version out.
My assumption was that they bring it out with Java 8, due to the changes (load less of the whole JVM, if not needed) they showed at JavaOne. They even presented a Raspberry with a experimantel Java 8 version on it.
ota-kun
Fri Dec 28, 2012 7:26 pm
There exists a developer preview of Oracle embedded Java 8 including JavaFX
http://jdk8.java.net/fxarmpreview/
Thread started by oracle in Raspberry forum
http://www.raspberrypi.org/phpBB3/viewt ... 81&t=26110
Return to “Raspbian”
