Following this tutorial:
http://readwrite.com/2014/04/10/raspber ... b-browsing
When it tells you to reboot your PI at the end I see at startup:
I also see this when I type:[FAIL] Starting virtual private network daemon: server failed!
sudo service openvpn restart
In this tutorial I have changed everything that has needed to be changed to fit my needs like IP Address and also network interfaces.
Looking at:
sudo cat /var/log/openvpn.log
Tue Jul 21 18:55:06 2015 OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Dec 1 2014
Tue Jul 21 18:55:06 2015 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Tue Jul 21 18:55:06 2015 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Tue Jul 21 18:55:06 2015 Cannot open file key file '/etc/openvpn/easy-rsa/keys/ta.key': No such file or directory (errno=2)
Tue Jul 21 18:55:06 2015 Exiting
Anyhelp appreciated, thanks
Nick
