The serverfile is located /etc/openvpn/server.conf
When I boot the systemd fails to start openvpn@server.service
pi@RaspberryPi-Desiree ~ $ systemctl status openvpn@server
● openvpn@server.service - OpenVPN connection to server
Loaded: loaded (/lib/systemd/system/openvpn@.service; enabled)
Active: failed (Result: exit-code) since do 2015-07-16 23:18:13 CEST; 1min 36s ago
Process: 608 ExecStart=/usr/sbin/openvpn --daemon ovpn-%i --status /run/openvpn/%i.status 10 --cd /etc/openvpn --config /etc/openvpn/%i.conf (code=exited, status=1/FAILURE)
systemctl start openvpn@server
Does anyone know how I can fix that it will start at boot?
