Boot fails at "waiting for /dev to be fully populated"
Posted: Tue Jul 07, 2015 2:48 pm
by rjmusto
Hi Guys,
Using a new Raspberry 2 and a new install of NOOBS.
I have installed Raspian several times now and find that it will work just fine for a while and then seemly randomly will not boot up properly. Sometimes it will work fine for 5 or 6 boots, and others maybe just once. The most recent install worked fine but on the next boot up it failed.
During the start it pauses at:
then after a few seconds it caries on but with screens full of errors that seem to just keep repeating and never gets to the login.
I have tried a couple of different SD cards, but get the same each time.
Any advice much appreciated.
Ralph
Re: Boot fails at "waiting for /dev to be fully populated"
Posted: Wed Feb 10, 2016 7:28 pm
by Matt6i6
Based on my experiences problem is in Power Adaptor.
Even if you have DC 5V 2A OUT on adaptor it does not mean it will work well.
For example I used new Stontronics 5V 2A and was getting errors you write about every 4-7 reboots!?!? constantly.
When I changed to other adaptor (older Stontronics I had already before) with DC out 5V 1.5A everything works well.
