Fght
do i need to make only lighttpd to be updated or rasbian too
Thu Jul 02, 2015 1:34 pm
hi
i've a lighttpd server on raspbian.
i also have duckdns with the cron installation...
i want to know what should i make from these to be updated regularly and automatically.
i would also appreciate to know how to do this thing.
i really glad i could make a web server out of my pi
all the best..
Re: do i need to make only lighttpd to be updated or rasbian
Thu Jul 02, 2015 1:42 pm
You should be running apt-get update && apt-get upgrade at least once a week. Even that won't protect you from zero-day exploits.
This is a doctor free zone.
Fght
Thu Jul 02, 2015 6:19 pm
how can i make it run and execute by itself?
will it update/upgrade everything and there is no need to do anything? i mean will it do it all in the background?
Thu Jul 02, 2015 6:46 pm
sudo apt-get install unattended-upgrades
sudo dpkg-reconfigure unattended-upgrades
But that can be a poisoned chalice, if a bad fix comes down the wire you could crash your system. So the way I used to run that on my (now decommissioned) Ubuntu system was to simply get the fixes down the wire but not install them until I was ready.
Fght
Thu Jul 02, 2015 7:37 pm
how can you know an update or upgrade is not something that you want? do you check the version? i'm not that good at linux at all..........
thanks i will try what you said.
Thu Jul 02, 2015 7:40 pm
I've got seven Raspberry Pis that don't run my public webserver and one that does. Therefore I've got plenty of scope to test things, to take backups and be sure I've not got a bad fix before I deploy stuff to my B+ that's running the web services.
Fght
Thu Jul 02, 2015 7:51 pm
not sure i fully understood you
anyway, anymore ideas on securing my web server pi?
do you guys suggest me posting linux/raspbian questions elsewhere by the way?
Fght
Sun Jul 05, 2015 8:21 pm
hey again
how can i make sure i'm on the latest raspbian + latest packages?
is there some way to get a msg that everything updated already?
Sun Jul 05, 2015 11:32 pm
sudo apt-get update && sudo apt-get dist-upgrade will get all available packages.
Fght
Mon Jul 06, 2015 8:26 pm
do you mean making an updage/upgrade right?
my question is not that. my question is how to make sure that even after making automatic updates that it's really got done?
i want some way to be sure that i've the latest updates but just to get perhaps a msg saying "your system is up to date"
Mon Jul 06, 2015 8:33 pm
If it fails you'll get error messages. If it it works you get nothing.
Fght
Mon Jul 06, 2015 8:37 pm
the point is that... i'm not around the pi when the updates take place...
perhaps you are saying the easy way to check if my software up to date is to see what the command for updating gives? if it gives error then there was some problem?
i'm still a bit confused... :)
things work differently on a pc...
Mon Jul 06, 2015 9:39 pm
You really do NOT want to do unattended updates. It may seem like a good idea until something breaks your system.
Fght
Tue Jul 07, 2015 6:43 pm
ok
thanks for the suggestion
how can i revoke the unattended updates?
i think you gave me the commands of of to make it active but i'm not sure how to reverse it back to manual updates.
Tue Jul 07, 2015 6:45 pm
dpkg -configure unattended-updates
Tue Jul 07, 2015 10:10 pm
sudo dpkg-reconfigure ...
Fght
Tue Jul 07, 2015 11:29 pm
i get this msg:
http://postimg.org/image/l968nyc7b/
probably it have not installed unattended updates after all!?
Return to “Raspbian”
