nitschkecm
Gstreamer on latest Raspbian
Thu Jun 04, 2015 10:51 am
I have been looking for a hardware accelerated jpg encoding for my Time-Lapse Project. I have come across this great tutorial in order to set this up http://www.onepitwopi.com/raspberry-pi/ ... pberry-pi/ However I did not get it to work yet.
I will give it another try on a completely new Raspbian Image.
Then I came across the fact that the latest release of Raspbian has already the gstreamer 1.2 included which is great news. I did the
sudo apt-get dist-upgrade
however when I run the command from the tutorial
gst-inspect-1.0 | grep omx
I get Command not found. Needless to say that the command that I really was looking forward to have functioning
gst-launch-1.0 -e multifilesrc location="image_%04d.jpg" ! image/jpeg, framerate=12/1 ! \
decodebin ! video/x-raw, width=1296, height=976 ! progressreport name=progress ! \
omxh264enc target-bitrate=15000000 control-rate=variable ! video/x-h264, profile=high ! \
h264parse ! mp4mux ! filesink location=test.mp4
Does not work either. My question is now, how can I get this to work. An instruction for dummies would be the most welcome, any other help also appreciated!
ktb
Re: Gstreamer on latest Raspbian
Thu Jun 04, 2015 11:03 am
Perhaps you need one of the gstreamer-tools packages, such as gstreamer1.0-tools or gstreamer0.10-tools. I'm not sure about the package names, I'm not using Raspbian right now.
Search for them to get the correct package names:
sudo apt-get update
apt-cache search gstreamer
nitschkecm
Thu Jun 04, 2015 11:09 am
just added the gstreamer tools via
sudo apt-get install gstreamer-tools
but it did not chance anything unfortunately regarding the commands.
ktb
Thu Jun 04, 2015 11:15 am
nitschkecm wrote:Hi,
You should search for the correct names of the actual packages. The gstreamer-tools command you used probably installs version 0.10. There will be two different packages for gstreamer version 0.10 and 1.0. It appears that you want version 1.0, so...
sudo apt-get install gstreamer1.0-tools
nitschkecm
Thu Jun 04, 2015 12:15 pm
Thanks a lot. that made me progress a bit more. Now when I try to run
gst-launch-1.0 -e multifilesrc location="image_%04d.jpg" ! image/jpeg, framerate=12/1 ! decodebin ! video/x-raw, width=1296, height=976 ! progressreport name=progress ! omxh264enc target-bitrate=15000000 control-rate=variable ! video/x-h264, profile=high ! h264parse ! mp4mux ! filesink location=test.mp4
I am getting the following error message. The directory and files are chmod 777
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0: Could not initialize supporting library.
Additional debug info:
gstvideoencoder.c(1426): gst_video_encoder_change_state (): /GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0:
Failed to open encoder
Setting pipeline to NULL ...
Freeing pipeline ...
I have seen this quite often from other users as well but have no clue on where to search. Help is welcome!
nitschkecm
Mon Jun 08, 2015 12:43 pm
I reinstalled Rapsbian (latest release) on a new Pi B+. All is updated to the latest version.
I have installed as well the gstreamer1.0-tools
when I run the above command to make the movie I am getting now a different error
Pipeline is PREROLLING ...
ERROR: from element /GstPipeline:pipeline0/GstMultiFileSrc:multifilesrc0: Internal data flow error.
gstbasesrc.c(2865): gst_base_src_loop (): /GstPipeline:pipeline0/GstMultiFileSrc:multifilesrc0:
streaming task paused, reason not-linked (-1)
ERROR: pipeline doesn't want to preroll.
Anybody any suggestion on where to look or what to do ?
Mon Jun 08, 2015 3:24 pm
Start with a short pipeline, with bits taken out, dump the output to null. Then add stuff until it break, that should give you some idea of what's wrong. Also add the verbose flag to gst-launch (cannot remember exact syntax) to see if you can get more information out.
nitschkecm
Wed Jun 10, 2015 2:02 pm
I ran the command like this
gst-launch-1.0 -e multifilesrc location=image_%04d.jpg ! image/jpeg, framerate=12/1 ! decodebin ! video/x-raw, width=1296, height=976 ! progressreport name=progress ! omxh264enc target-bitrate=15000000 control-rate=variable ! video/x-h264, profile=high ! h264parse ! mp4mux ! filesink location=test.mp4  --gst-debug-level=4 > log3 2>&1
attached is the log file that was output. Thanks for further help !
log3.log.zip
(10.82 KiB) Downloaded 189 times
jbeale
Sun May 22, 2016 1:57 am
I'm trying to use gstreamer with omxh264enc as well. I am not familiar with the somewhat complex gstreamer pipelines; is there any example online of a command which works using omxh264enc (from any source, to any sink)?
Update: one example from this post viewtopic.php?f=38&t=6852&start=225 doing a rtp stream appears to work with a USB camera on the RPi end, at least it doesn't generate an error- haven't yet successfully received it though.
gst-launch-1.0 -v -e v4l2src device=/dev/video0 ! 'video/x-raw,format=I420,width=640,height=480,framerate=30/1' ! omxh264enc target-bitrate=6500000 control-rate=variable ! rtph264pay pt=96 ! udpsink host=192.168.10.2 port=5001
mariusco
Thu Dec 15, 2016 11:07 pm
The information in the post is incomplete.
WARNING: erroneous pipeline: no element "omxh264enc"
waqarrashid33
Wed Jan 11, 2017 2:28 pm
Hi everyone,
I am trying to send stream (Motion JPEG) from one Pi1 to Pi2 and then I will process it together with picture from Pi2. Did anybody made the gstream work on Pi with picamera?
wpeForRPI
Fri Jan 27, 2017 6:31 am
nitschkecm wrote:I ran the command like this
try this
$gst-launch-1.0 playbin uri=file:///<path to mp4 media file>
that will at least skip your internal flow error.
Although I tried above and facing some segmentation fault issues.
Ratsima
Thu Oct 05, 2017 8:38 am
I've been using GStreamer to create videos from JPEG images for some time now. It only recently came to my attention that GStreamer produces a corrupt video file in that the first frame consists of a JPEG that is nowhere near the first in the queue. This never caused problems until new OS releases by Apple: High Sierra and iOS. Both of these do an integrity check on the individual frame time stamps and won't properly play the video if the time stamps are out of order. So, it gets stuck on the first frame of the video when viewed in Safari, Chrome or QuckTime Player. The video plays normally in VLC as either a local file or network stream.
The video is here: http://www.mgnewman.com/kamvideo.mp4
The code used to generate it is here:
gst-launch-1.0 \
	-e  multifilesrc location="$mfslocation" \
	! image/jpeg, framerate=10/1 \
	! jpegdec ! queue ! videoscale \
	! video/x-raw, width=640, height=480 \
	! progressreport name=progress \
	! omxh264enc target-bitrate=1200000 control-rate=variable \
	! video/x-h264,profile=high\
	! h264parse \
	! mp4mux \
	! filesink location="$fslocation"
Any ideas on how to stop GStreamer from inserting a random image into the first frame?
nitschkecm
Sat Oct 07, 2017 9:37 am
I have a similar problem. The video plays in VLC but I uploading it to youtube the video processing gets stuck at the very beginning.
Ratsima
Sat Oct 07, 2017 9:50 am
The reason it gets stuck is because the first frame has a time stamp that is out of sequence. For example, on my webcam videos the JPEGs that make up the time lapse start about 4:30 AM and end at about 4:00 AM the next day. But, the time stamp of frame #1 is just after midnight.
Some players, like VLC, ignore this discrepancy. Other video players, such as QuickTime Player or Safari running under High Sierra, show the first frame, but get stuck there until they reach a frame with a later time stamp.
I think that this is a bug in GStreamer, but I don''t know enough about it to file a bug report.
nitschkecm
Wed Oct 11, 2017 5:33 pm
I am quite sure that there is a bug since I have had the same sympton and it used to work just fine. Would be great to get GSTREAMER back to work correctly since it was much more efficient and faster than ffmpeg.
Please keep me posted if you find a solution!
developerRPI
Fri Mar 16, 2018 7:38 am
I got an error:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:00.000499325
Setting pipeline to READY ...
. What do I have to to?
Return to “Raspberry Pi OS”
