omegacore
Penmount touchscreen not appearing in /dev
Wed May 20, 2015 2:23 am
I'm running a raspi2 with the most recent release of raspbian. I am trying to get a penmount touchscreen working on the pi.
inputattach fails when I say:
sudo inputattach -pm6k /dev/bus/usb/001/023
/dev/usb/001/023 is the device handle I can find with lsusb.
dmesg shows that udev recognizes the Penmount controller, but doesn't give it a /dev handle. I wrote a udev rule in 010-local.rules
ACTION=="add", ATTRS{idVendor}=="14e1", ATTRS{idProduct}=="6000", NAME="touchScreen"
Reloaded rules, still no handle in /dev.
Is there something I'm missing?
Thanks!
evignaux
Re: Penmount touchscreen not appearing in /dev
Fri Mar 18, 2016 10:50 am
Hi omegacore,
Did you have any chance making penmount6000 touchscreen working on the raspberry 2 ?
I have been trying to make it work for two weeks ...
No touch ! :cry:
When I plug usb, dmesg tells me :
[429203.825740] usb 1-1.2: New USB device found, idVendor=14e1, idProduct=6000
[429203.825769] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[429203.825787] usb 1-1.2: Product: PenMount USB
[429203.825803] usb 1-1.2: Manufacturer: DIALOGUE INC
[429204.503714] usb 1-1.2: USB disconnect, device number 22
[429207.557172] usb 1-1.2: new full-speed USB device number 23 using dwc_otg
[429207.665754] usb 1-1.2: New USB device found, idVendor=14e1, idProduct=6000
[429207.665788] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[429207.665805] usb 1-1.2: Product: PenMount USB
[429207.665820] usb 1-1.2: Manufacturer: DIALOGUE INC
lsusb tells me :
Bus 001 Device 023: ID 14e1:6000 Dialogue Technology Corp.
tail -f /dev/bus/usb/001/023 tells me
@?`?? )?? !"L?
When I put fingers on the screen, it doesn't change.
It works on windows 7
https://github.com/xvzf/linux-raspberry ... penmount.c
is the driver sourcecode fro penmount, but I have absolutely no idea on how to compile it ...
Any Idea ?
Eric
giancarlo.bacchio
Sun Mar 20, 2016 10:04 pm
Hi!
I am in your same troubles :)
After a contact with monitor's manufacturer, I received source drivers for Penmount 6000
unfortunately, my lack of experience prevents me from a successful compiling.
I have posted "penmount_linux_android_driver_src_v1_13_6.tar.bz2" for you on WeTransfer
this is the download address : http://we.tl/xCbvb1GXMO
(valid only few days).
please let me know if you are able to get a better result than me.
regards
Giancarlo
evignaux
Fri Apr 01, 2016 5:00 pm
Hi Giancarlo, Thanks for your answer,
Really sorry did not see you post before, and wetransfer file is not availlable...
Can you please send it to me again ?
I think this penmount.c fil must be placed in the kernel source tree
(in place of the standard penmount.c which already exists.)
Then you compile the kernel like described on this site :
https://www.raspberrypi.org/documentati ... uilding.md
You must reconfigure the kernel by typing : make menuconfig
and you choose penmount driver.
Cheers
Eric
giancarlo.bacchio
Sat Apr 02, 2016 6:15 am
Hello Eric,
here is the new link to wetransfer: https://we.tl/Ed38NnF1Cw
Since two weeks ago, I tried several times to compile the source code as per the description attached. I also asked support to some expert friends of mine but, unfortunately, without success.
What you are suggesting is still something different and I will try again.
Let me know your results
Cheers,
Giancarlo
evignaux
Sat Apr 02, 2016 6:26 pm
Hi GianCarlo,
Thx for the wetransfer, I will try it on my side and let you informed if I managed to compile the driver.
Cheers
Eric
evignaux
Thu Apr 14, 2016 3:12 pm
I Gian Carlo,
I finaly found a solution to make my penmount touchscreen operate withe my raspberry.
No need to use the archive you wetransfered to me.
If you have the rapseberry pi 2, follow these instruction :
1. compile the kernel
sudo apt-get update
sudo apt-get upgrade
cd /home/pi
git clone https://github.com/raspberrypi/linux
cd linux-rpi-4.1.y
KERNEL=kernel7
make bcm2709_defconfig
make menuconfig
...It loads a command ligne program (gray background)
Then try to go into the device drivers configuration section, go to HID support, follow specific drivers (or something like that) and finaly select “hid penmount drivers”.
Then save and exit. Back to the black terminal
Very long :
make -j4 zImage modules dtbs
sudo make modules_install
sudo cp arch/arm/boot/dts/*.dtb /boot/
sudo cp arch/arm/boot/dts/overlays/*.dtb* /boot/overlays/
sudo cp arch/arm/boot/dts/overlays/README /boot/overlays/
sudo scripts/mkknlimg arch/arm/boot/zImage /boot/$KERNEL.img
2. Restart the system
sudo reboot
3. Compile a calibration tool, because the xinput_calibrator that you can install with apt-get install is buggy.
cd /home/pi
wget http://github.com/downloads/tias/xinput ... 7.5.tar.gz
tar -zxvf xinput_calibrator-0.7.5.tar.gz
cd xinput_calibrator-0.7.5
./configure
make
sudo make install
Then .... run in a terminal, under X session:
xinput_calibrator
You just press the four crosses, and you copy/paste the snippet that has been generated in the terminal, in /etc/X11/xorg.conf/99-calibration.conf
4. restart the system
sudo reboot
5. Touch the screen and be happy !!!!
Cheers
Eric
giancarlo.bacchio
Fri Apr 15, 2016 6:55 am
Hello Eric,
Fantastic, you did a really great job!!!
I will follow your detailed procedure.
Thank you a lot and have a nice time!!
Giancarlo
matthmelt
Fri Apr 29, 2016 4:19 pm
Would you mind posting the source for that driver again please; I'm working on an industrial HMI project and am unable to get a screen to work out of the box.
Thank You Much,
Matt
giancarlo.bacchio
Sun May 01, 2016 10:22 pm
Hi Matt,
I did a github repo to get the drivers definitely available to everybody.
https://github.com/Gianbacchio/Penmount ... aspberryPI
Note that I wasn't able to complete the procedure from Penmount.
On the other side, the procedure from Eric works very well.
regards
Giancarlo
Return to “Raspberry Pi OS”
