pcote_pi
PI2 -Ubuntu mate Web error HTTPS
Sun May 10, 2015 11:50 pm
From the download page, I am trying to access the ubuntu mate page with Midori and get:
Error - https://ubuntu-mate.org/
The page 'https://ubuntu-mate.org/' couldn't be loaded.
SSL handshake failed
Try again
Unable to access. Works with Chrome
buckyb
Re: PI2 -Ubuntu mate Web error HTTPS
Wed May 20, 2015 7:55 am
I had the same problem. Ubuntu / Firefox was ok but I wanted to leave the download going overnight in the RPi. And for the download to restart if the connection was flaky-which it was. So I captured the link in Ubuntu and copied it into RPi 2 Wheezy.
Then used the link in a terminal with
wget -c http://master.dl.sourceforge.net/project/ubuntu-mate/15.04/armhf/ubuntu-mate-15.04-desktop-armhf-raspberry-pi-2.img.bz2
This worked fine and I got the result
pi@raspberrypi ~ $ wget -c http://master.dl.sourceforge.net/projec ... -2.img.bz2
--2015-05-19 23:35:08-- http://master.dl.sourceforge.net/projec ... -2.img.bz2
Resolving master.dl.sourceforge.net (master.dl.sourceforge.net)... 216.34.181.56
Connecting to master.dl.sourceforge.net (master.dl.sourceforge.net)|216.34.181.56|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 947220777 (903M) [application/octet-stream]
Saving to: `ubuntu-mate-15.04-desktop-armhf-raspberry-pi-2.img.bz2'
84% [================================> ] 803,312,410 26.5K/s in 1h 51m
2015-05-20 01:26:24 (118 KB/s) - Connection closed at byte 803312410. Retrying.
--2015-05-20 01:26:25-- (try: 2) http://master.dl.sourceforge.net/projec ... -2.img.bz2
HTTP request sent, awaiting response... 206 Partial Content
Length: 947220777 (903M), 143908367 (137M) remaining [application/octet-stream]
85% [+++++++++++++++++++++++++++++++++ ] 810,882,217 42.0K/s in 3m 35s
2015-05-20 01:30:00 (34.4 KB/s) - Connection closed at byte 810882217. Retrying.
--2015-05-20 01:30:02-- (try: 3) http://master.dl.sourceforge.net/projec ... -2.img.bz2
Length: 947220777 (903M), 136338560 (130M) remaining [application/octet-stream]
86% [+++++++++++++++++++++++++++++++++ ] 819,258,424 53.1K/s in 3m 25s
2015-05-20 01:33:28 (39.8 KB/s) - Connection closed at byte 819258424. Retrying.
--2015-05-20 01:33:31-- (try: 4) http://master.dl.sourceforge.net/projec ... -2.img.bz2
Length: 947220777 (903M), 127962353 (122M) remaining [application/octet-stream]
100%[+++++++++++++++++++++++++++++++++=====>] 947,220,777 103K/s in 34m 28s
2015-05-20 02:07:59 (60.4 KB/s) - `ubuntu-mate-15.04-desktop-armhf-raspberry-pi-2.img.bz2' saved [947220777/947220777]
Hope this helps anyone with the same problem
Return to “Raspberry Pi OS”
