MrEngman
How do I stop the GUI automatically starting
Thu Jul 12, 2012 1:12 pm
After updating pisces r2 with rpi-update the GUI is automatically started when I boot.
How can I stop the GUI automatically starting?
RaTTuS
Re: How do I stop the GUI automatically starting
Thu Jul 12, 2012 1:20 pm
sudo chmod 644 /etc/init.d/slim
Covfefe
Joe Schmoe
Thu Jul 12, 2012 1:30 pm
RaTTuS wrote:sudo chmod 644 /etc/init.d/slim
Is this real? How did the "auto-start X and present the user with a GINA" thing become the default on any publicly available Pi distro? I thought they were all setup as "You must type 'startx' to start the GUI.".
masterluke
Thu Jul 12, 2012 1:36 pm
I was surprised to see a graphical login on updating too. Its a bit annoying as XBMC needs X killed to work properly and I cant for the life of me figure out how to kill X without it restarting itself.
mard0
Thu Jul 12, 2012 2:06 pm
sudo apt-get purge slim
MrEngman
Thu Jul 12, 2012 2:54 pm
Thanks guys,
Both methods suggested work for those interested.
That's much better.
gidoca
Fri Jul 13, 2012 9:54 am
I don't have my Raspberry Pi in front of me right now to test it, but I believe that changing /etc/X11/default-display-manager to be empty should also prevent slim from starting.
mpthompson
Fri Jul 13, 2012 10:13 pm
gidoca wrote:I don't have my Raspberry Pi in front of me right now to test it, but I believe that changing /etc/X11/default-display-manager to be empty should also prevent slim from starting.
This is the approach I take. Actually, just putting a '#' in front of the first line in the file (commenting it out) will effectively disable the display manager from starting.
egorive
Sun Oct 28, 2012 12:31 pm
Any of the three methods given in this thread solve me the problem. There is still the login command line screen after reboot.
¿Any other ideas?
Thank you very much.
RaTTuS
Mon Oct 29, 2012 11:33 am
egorive wrote:Hi,
¿Any other ideas?
there are ways of enabling the auto login feature - can you make a new post as this is old info and should be ignored now
Covfefe
k7n4n5t3w4rt
Sat Dec 12, 2015 8:09 pm
Setting up a new Pi, I downloaded Noobs and selected Raspbian as the OS as I have done many times. It's pretty annoying that the gui now starts up automatically.
I used to get the config options where I could enable ssh, set the timezone etc. Now it just boots into the gui. My mouse doesn't seem to work (it's an old Apple one) and I can't seem to navigate the gui with my keyboard only (or maybe it's not recognising the keyboard). In any case, I can't get a command line and I can't use either of these options:
or
I'm thinking I might be able to get to this file if I put the SD card back into my mac:
But I have no idea where it is on the SD card. Any suggestions?
stderr
Sat Dec 12, 2015 8:42 pm
k7n4n5t3w4rt wrote:Setting up a new Pi, I downloaded Noobs and selected Raspbian as the OS as I have done many times. It's pretty annoying that the gui now starts up automatically.
This is usually controlled using some sort of systemd thing. So I'd look at that. Whether or not old methods are made new again, that is the old way you used to do it suddenly works, I cannot say, but I guess we all need to give in to the tsunami and learn this new scheme. Next week, upstart is back again! (I keed, I keed)
Sat Dec 12, 2015 8:52 pm
Try Ctrl-Alt-F2 to get to a virtual console. Then log in as "pi" and "sudo raspi-config"
Ctrl-Alt-F7 should get you back to the desktop afterwards, or you could just "sudo reboot" to make the changes take effect.
k7n4n5t3w4rt
Sun Dec 13, 2015 3:00 am
Thanks rpdom, I'd try that if the keyboard had any effect at all.
Maybe I'll try another. This one used to work fine with the pi when Raspbian didn't fire up the GUI automatically.
rpdom wrote:Try Ctrl-Alt-F2 to get to a virtual console. Then log in as "pi" and "sudo raspi-config"
stderr
Sun Dec 13, 2015 3:27 am
k7n4n5t3w4rt wrote:Thanks rpdom, I'd try that if the keyboard had any effect at all.
So when you hit caps lock, the light doesn't go on? If the ctrl-alt-F4 or other choices don't work, you've got to look at the flash drive by mounting it somewhere loop. (Or try a different flash drive or something that direction)
The img isn't just one partition, it could be several so you'll need to find out the offset when you mount everything. In any case, do that and then go in and change the target so it doesn't boot to the GUI. If you mount it on an x86 box, you won't be able to chroot to run the systemd config program or the raspberry pi one so you'll have to figure out how to change the target by hand directly. At least I think this is the situation, if someone else has a different plan by all means try that.
k7n4n5t3w4rt
Sun Dec 13, 2015 10:23 am
It worked! Thanks rpdom.
I did Ctrl-Alt-F2 while it was booting up and it recognised the keyboard and went into a virtual console without going into the GUI (I never did get the keyboard to work if it went into the GUI). Once once in the console, "sudo raspi-config" got me into the config interface and I set it to boot into console. Then a reboot and now it's all good.
Thanks again!
Shadow_7
Mon Dec 14, 2015 9:13 am
The more official way (at least in debian) is to populate this file with "false".
Although uninstalling a display manager works too. As previously mentioned. But then you install something that grabs a display manager and installs it as a dependency. Like many of the mainstream window managers / desktop environments. And you're back to square one.
$ sudo apt-get purge slim
As far as the keyboard, have you tried the usual?
$ sudo dpkg-reconfigure keyboard-configuration
Since my very first experience with raspbian was with the euro keyboard setup by default in my usa world. As in # and | aka number and pipe typed "other" characters.
These days I just do minimal debootstrap style installs. Running a wm in X and the install base is < 1GB (including downloaded .deb's). Which leaves plenty of room for useful things without the update hell that is an endless waiting game aka american ISPs.
stderr
Mon Dec 14, 2015 4:42 pm
Shadow_7 wrote:The more official way (at least in debian) is to populate this file with "false".
Does that work with systemd? When trying to get systemd to not start the GUI, I found so many different ways to stop it that didn't stop it that it was just amazing. This was with Ubuntu on x86 but the idea is similar.
RaTTuS
Mon Dec 14, 2015 4:50 pm
on new jessie - use
sudo raspbi-config
and disable it there
Covfefe
PhoenixFireBird
Mon Feb 15, 2016 6:06 pm
Thanks rpdom,
It worked, and now I am able to go to the command line and optionally get into GUI. :)
Return to “Raspbian”
