Can't install Chromium on Raspbian
Posted: Sun May 03, 2015 4:32 pm
by FuzzyToothpaste
I'm running Raspbian Jessie now that it has gone stable, and I'm having a bit of a problem getting Chromium. It seems that there are no builds for Chromium for armhf from Debian https://packages.debian.org/jessie/chromium. Also, if you go to http://mirrordirector.raspbian.org/rasp ... m-browser/ to look in the Raspbian repos, you will notice that there are source packages for Chromium, but for some odd reason, there are no binary packages. Why are there no binary packages here? How can I install Chromium now? P.S. I want Chromium because I want a very advanced browser for my Raspberry Pi 2. I figured that Chromium would make good use of the Raspberry Pi 2's four processor cores because it uses a new process for each tab and plugin.
Re: Can't install Chromium on Raspbian
Posted: Sun May 03, 2015 4:37 pm
by fruitoftheloom
FuzzyToothpaste wrote:I'm running Raspbian Jessie now that it has gone stable, and I'm having a bit of a problem getting Chromium. It seems that there are no builds for Chromium for armhf from Debian https://packages.debian.org/jessie/chromium. Also, if you go to http://mirrordirector.raspbian.org/rasp ... m-browser/ to look in the Raspbian repos, you will notice that there are source packages for Chromium, but for some odd reason, there are no binary packages. Why are there no binary packages here? How can I install Chromium now? P.S. I want Chromium because I want a very advanced browser for my Raspberry Pi 2. I figured that Chromium would make good use of the Raspberry Pi 2's four processor cores because it uses a new process for each tab and plugin.
:?: http://blog.valitov.me/2014/06/installi ... m.html?m=1
Posted: Sun May 03, 2015 4:44 pm
by FuzzyToothpaste
Thanks, but I'd like to be able to get Chromium out of a repo of some kind so that it would stay up-to-date. I guess I'll just get a different browser. Let me know if there is a better solution.
Posted: Sun May 03, 2015 5:17 pm
by fruitoftheloom
fyi Raspbian Jessie is still Testing and we are awaiting a stable release. ;)
IceWeasel (Firefox) Browser is in the Raspbian Repository and is at version 31ESR
sudo apt-get update
sudo apt-get install iceweasel
https://packages.debian.org/jessie/iceweasel
Posted: Sun May 03, 2015 7:03 pm
by kusti8
If you want the latest chromium, install the linaro image. That comes with v41 and if you fiddle with your sources then you can get v43.
Posted: Sat Apr 30, 2016 12:19 pm
by Ben_is_best
FuzzyToothpaste wrote: Thanks, but I'd like to be able to get Chromium out of a repo of some kind so that it would stay up-to-date. I guess I'll just get a different browser. Let me know if there is a better solution.
You can install a repo from here.
Posted: Sat Apr 30, 2016 5:56 pm
by fruitoftheloom
Fuzzy last visited 5 months ago, and his Chromium query was a year ago !!!!!
