gkreidl
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Tue Oct 20, 2015 2:05 pm
Rascas wrote:SoftWord: Here you have all PVR addons for Kodi 15.X.
http://pipplware.pplware.pt/pipplware/d ... in/binary/
Just download and install with dpkg -i
They have been all compiled for Wheezy. Do they all work with Jessie without problems?
I still have an older version of pvr-iptvsimple client from your repository installed on Jessie and it's working quite well.
I think all pvr clients need libplatform1.
Minimal Kiosk Browser (kweb)
Rascas
Tue Oct 20, 2015 2:27 pm
Yes, they were compiled for Wheezy but they all work in Jessie, so I didnt bothered compiling them again. They need libplatform1 and there is one PVR addon that needs libtinyxml2-0.0.0, don't remember which one. If you install the PVRs, dpkg will detect the missing dependecies and warn if missing, they are all in my repo, so you can download and install them seperately.
giallopaperino
Wed Oct 21, 2015 9:55 am
Which is the sintax to install with dpkg on raspbian wheezy? Client iptv for me
I do not succeed to install kodi-pvr-iptvsimple_1.11.4-1~wheezy_armhf-4.deb
With command line I made
Sudo dpkg -i /home/pi/usbdisk/kodi-pvr-iptvsimple_1.11.4-1~wheezy_armhf-4.deb
Wheezy estract it but with command dpkg -l is not show
SoftWord
Wed Oct 21, 2015 4:20 pm
thanks for support :)
but I'v add that repository to my sources of apt and it work with apt-get:
"deb http://pipplware.pplware.pt/pipplware/d ... ain/binary /"
it's right in that way?
d.vogel
Wed Oct 21, 2015 5:06 pm
Rascas wrote:Yes, they were compiled for Wheezy but they all work in Jessie, so I didnt bothered compiling them again. They need libplatform1 and there is one PVR addon that needs libtinyxml2-0.0.0, don't remember which one. If you install the PVRs, dpkg will detect the missing dependecies and warn if missing, they are all in my repo, so you can download and install them seperately.
I'm experiencing problems installing the kodi-pvr-iptvsimple addon from your repo because libplatform1 cannot be installed. Every time I try to install libplatform1 I keep getting an error. The error says (translated it to English by myself, hope you know what it says...) "Try to overwrite »/usr/lib/arm-linux-gnueabihf/libplatform.so.1.0«, which is also in package libpulseeight-platform1:armhf 1.0.9-1~jessie".
So I don't know what to do to be able to install the iptvsimple addon... Can anyone please help me with this?
gergo2007
Wed Oct 21, 2015 7:19 pm
Hi
How can i add my hifiberry dac to kodi?
Thanks!
wwwgizy
Wed Oct 21, 2015 9:28 pm
Thank you very much
RainBlack
Thu Oct 22, 2015 3:04 am
Hi can you build the kodi-15.2 final version for debian jessie thank you =)
gkreidl
Thu Oct 22, 2015 7:54 am
RainBlack wrote:Hi can you build the kodi-15.2 final version for debian jessie thank you =)
Yes, it will follow soon.
gkreidl
Thu Oct 22, 2015 1:35 pm
I've just released kodi 15.2 final release for Jessie.
This will be my last version. I consider this project as finished.
SoftWord
Thu Oct 22, 2015 4:09 pm
gkreidl wrote:I've just released kodi 15.2 final release for Jessie.
ok but u don't have build addons that I use....vdr pvr vnsi and iptv....
gkreidl
Thu Oct 22, 2015 6:33 pm
No, and I never did.
SoftWord
Thu Oct 22, 2015 6:36 pm
So I can use your archive on the first post with plugin inside that repos? Because in that repos is preset 15.2 rc......!
gkreidl
Thu Oct 22, 2015 6:42 pm
SoftWord wrote: So I can use your archive on the first post with plugin inside that repos? Because in that repos is preset 15.2 rc......!
yes.
SoftWord
Thu Oct 22, 2015 6:45 pm
yes.
good!!! I update now :) thanks!
Rascas
Fri Oct 23, 2015 6:49 am
Well, that's because you have the same library that exists in two packages that have a diferent name: libplatform1 (mine) and libpulseeight-platform1 (which is in RPi Foundation repo). The package naming was already discused but nobody come to an agreenment, thats the problem. I just compiled that package from git and that is the name that you get...
But you don't need the Foundation package because theirs addons are old and don't work so you can just purge it and install mine. Well, if you really want the PVR addons...
I use exactly the same packaging system than the ones in Raspbian, but I needed libplatform1 earliear for the PVR addons, than the one that is avaible now in Raspbian, so the name is diferent and that's the problem.
The next time I compile the PVRs, I will see how the packging naming is in Raspbian and make them accordingly.
Rascas
Fri Oct 23, 2015 7:17 am
Yes. That is a repo for a Raspberry Pi distribution based on Raspbian named Pipplware. You can check it here but it is only in portuguese.
You can add the repo by editing /etc/apt/sources.list or add it to a new file like /etc/apt/sources.list.d/pipplware_jessie.list:
deb http://pipplware.pplware.pt/pipplware/dists/jessie/main/binary /
Than add the key:
wget -O - http://pipplware.pplware.pt/pipplware/key.asc | sudo apt-key add -
And update, upgrade and install Kodi:
sudo apt-get update && sudo apt-get dist-upgrade
sudo apt-get install kodi
To install PVRs you can execute the following command to list all PVRs available:
apt-cache search kodi-pvr
And then install what you want, for example:
sudo apt-get install kodi-pvr-iptvsimple
PS: The packages are compiled for armv6 so they work in all Raspberry versions.
PS2: This is for Jessie only
gkreidl
Fri Oct 23, 2015 8:06 am
@Rascas: This is really a nice repository containing stuff that is either missing in standard Raspbian (chromium browser, libdvdcss. kodi pvrs) or newer versions.
I think the posting above is worth a new thread. If it's buried deeply in this one, only a few people will find it.
SoftWord
Fri Oct 23, 2015 8:51 am
@Rascas: when you plan to rebuild to 15.2 final? So we can update simply with an aptitude upgrade?
EDIT2:
I'v talked with the developer team of addon pvr vnsi and seams that you don't link correctly the GL for that plugin because OSD doesn't show, this is the http://forum.kodi.tv/showthread.php?tid=244940.
gergo2007
Fri Oct 23, 2015 4:17 pm
Hi
I have tried to run the configure command as shown in the first post, but i get this error:
-bash: ./configure: No such file or directory
What should i do?
Also i tried to add my hifiberry dac+, its configured and works with system but i cant see it in kodi.
gkreidl
Fri Oct 23, 2015 4:33 pm
gergo2007 wrote:Hi
What should i do?
The configure command is part of the build process, not for users of the package. It may be useful if you compile your own version.
gergo2007
Fri Oct 23, 2015 5:07 pm
gkreidl wrote:
gergo2007 wrote:Hi
What should i do?
Oh, ok.
Any ideas on this?
SoftWord
Fri Oct 23, 2015 8:15 pm
Hi, repository jessie in pipplware isn't more present, why?
Rascas
Fri Oct 23, 2015 8:40 pm
SoftWord wrote:Hi, repository jessie in pipplware isn't more present, why?
The server is under maintenance, it will be online again ASAP. Meanwhile I will check the PVR vdr vnsi, and if there is a problem, I will update it. Thanks for the report about the PVR addon.
SoftWord
Fri Oct 23, 2015 9:20 pm
Thanks for all and I hope that u can fix vnsi asap please.....
Return to “Raspbian”
