silviu
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Wed Oct 14, 2015 1:14 pm
spel wrote:Hello,
Thank for releasing a compiled package of Kodi 15 for Raspbian !
I'm new to Raspberry and Raspbian, I've bought a RPI2 last week and I have a fresh install of Raspbian Jessie. I've first installed Kodi 14, and I got the so famous black screen issue on exit. So I followed your instructions and installed Kodi 15.2RC3. It have been installed well and it works fine but ... It still hang on a black screen when exiting Kodi, nothing changed regarding this issue for me :(
Have you any idea ? Have I missed a step ?
Before installing Kodi 15.2 rc3 from here on a fresh Raspbian Jessie install I did:
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
sudo reboot
After installing I did all the commands specified up to the end of the first post in this topic (page 1 up).
For me when I exit I am right back to the Desktop.
In case the problem does not get fixed for you, maybe run the script I used when having the problem with "sudo script" 8-) :
echo '#!/bin/bash' > /usr/bin/kodiexitfix
echo '' >> /usr/bin/kodiexitfix
echo 'if [[ $(tail -1 /home/pi/.kodi/temp/kodi.log | grep "application stopped...") ]]' >> /usr/bin/kodiexitfix
echo 'then' >> /usr/bin/kodiexitfix
echo ' killall kodi.bin' >> /usr/bin/kodiexitfix
echo ' mv /home/pi/.kodi/temp/kodi.log /home/pi/.kodi/temp/kodi.old.log' >> /usr/bin/kodiexitfix
echo ' chvt 2 && sleep 2 && chvt 7' >> /usr/bin/kodiexitfix
echo 'fi' >> /usr/bin/kodiexitfix
cat <<EOG > /etc/systemd/system/kodiexitfix.timer
[Unit]
Description=kodiexitfix timer
[Timer]
# Every 10 seconds
OnCalendar=*-*-* *:*:0/10
Unit=kodiexitfix.service
[Install]
WantedBy=timers.target
EOG
cat <<EOG > /etc/systemd/system/kodiexitfix.service
[Unit]
Description=kodiexitfix service
[Service]
Type=oneshot
ExecStart=/bin/bash /usr/bin/kodiexitfix
EOG
sleep 1
systemctl daemon-reload
systemctl enable kodiexitfix.timer
systemctl start kodiexitfix.timer
Wed Oct 14, 2015 3:14 pm
silviu wrote:
spel wrote:Hello,
sudo apt-get update
sudo rpi-update
sudo reboot
[Unit]
[Timer]
# Every 10 seconds
[Install]
EOG
[Unit]
[Service]
Type=oneshot
EOG
sleep 1
rpi- update gets a testing kernel and is not required unless stated that it fixes a issue you have, best to go back to a stable Kernel ;) ;)
adieu
spel
Wed Oct 14, 2015 5:31 pm
gkreidl wrote: Please check, if you have really installed kodi-15. check in kodi, options, system info
How do you start kodi? Do you use my startkodi command (or startt from the desktop menu)?
sudo apt-get update
sudo rpi-update
sudo reboot
Kodi "system" tab tells me that I have : "Raspbian GNU/Linux 8 (Jessie), and "Kodi 15.2-RC3 compiled : Oct 10 2015). To run kodi, I uses the desktop shortcut which exec "startkodi %u" .
I have just executed a system update and a firmware update, then rebooted, but it has not resolved the problem :(
gkreidl
Wed Oct 14, 2015 5:37 pm
spel wrote: Kodi "system" tab tells me that I have : "Raspbian GNU/Linux 8 (Jessie), and "Kodi 15.2-RC3 compiled : Oct 10 2015). To run kodi, I uses the desktop shortcut which exec "startkodi %u" .
1) Did you follow all the additional steps in the OP?
2) Install x11-xserver-utils. My startkodi script uses xrefresh, if available.
Minimal Kiosk Browser (kweb)
spel
Wed Oct 14, 2015 5:53 pm
Thank you for helping me.
1/ I have followed only these steps :
wget http://steinerdatenbank.de/software/kod ... sie.tar.gz
tar -xzf kodi-15-jessie
cd kodi-15-jessie
sudo ./install
and
sudo ./install_cec3
But I didn't followed the next steps because I come from a previous install of Kodi 14. Should I ?
2/ xrefresh seems to be available :
[email protected] ~ $ xrefresh --help
usage:  xrefresh [-options] [geometry] [display]
gkreidl
Wed Oct 14, 2015 6:58 pm
You could at least check, if the udev files do exist and also check the groups.
Otherwise I have no idea. I compiled and published the first kodi-15 version more than 5 months ago and nobody (many thousand downloads) complained about a black screen since then.
silviu
Wed Oct 14, 2015 7:26 pm
And for me subtitles appear but then don't refresh - the first one remains on screen. Please anyone see if you have the same problem. I get this problem for Jessie but better check both :D .
silviu
Wed Oct 14, 2015 7:39 pm
fruitoftheloom wrote: rpi- update gets a testing kernel and is not required unless stated that it fixes a issue you have, best to go back to a stable Kernel ;) ;)
Well keeping a stable kernel too long not updated can lead to security vulnerabilities - better a little unstable than not secure... For now it works perfect :roll: .
kusti8
Wed Oct 14, 2015 7:41 pm
That's not how it works. All the fixes will eventually be stable. If there are desperate security vulnerabilities they will still go to stable. Rpi update will essentially get the beta which is not recommended.
There are 10 types of people: those who understand binary and those who don't.
gkreidl
Wed Oct 14, 2015 8:08 pm
silviu wrote:And for me subtitles appear but then don't refresh - the first one remains on screen. Please anyone see if you have the same problem. I get this problem for Jessie but better check both :D .
Which player do you use? I only use omxplayer.
You might also install libass5.
FPi
Wed Oct 14, 2015 11:11 pm
I'm getting a black screen on exit everytime too (15.2 on jessie). I ran kodi and installed some addons before doing the additional steps in the OP, would this be the problem?
I also did not use the config.txt from the OP as my gpumem is set high enough, should I be using it?
Complete Linux noob here so any help is very much appreciated and a massive thanks to gkreidl for the guide.
silviu
Thu Oct 15, 2015 8:25 am
For all the extreme noobs out there:
cd kodi-15-jessie
sudo ./install
should be
tar -xzf kodi-15-jessie.tar.gz
cd kodi-15-jessie
sudo ./install
About the subtitles I am using omxplayer and libass5 - default in fresh Raspbian Jessie.
gkreidl
Thu Oct 15, 2015 9:11 am
silviu wrote:For all the extreme noobs out there:
cd kodi-15-jessie
sudo ./install
should be
cd kodi-15-jessie
sudo ./install
Thanks, I've updated the OP accordingly.
Regarding the subtitles; I run a test yesterday (only have a few video files with subtitles) and it worked for me. So this may be something very special.
gkreidl
Thu Oct 15, 2015 9:15 am
Since yesterday there is a kodi-15.1 Jessie release in the archive of the foundation. It contains a few RPi-specific patches and may be a better solution than my package. It is not optimized for RPi2 and will work with any RPi model.
spel
Thu Oct 15, 2015 9:33 am
I have made a new install of Raspbian Jessie and Kodi 15.2 . I haven't the time to load movies into kodi yesterday, but it seems to be better since I'm able to exit kodi. I will try this evening after loading and playing some movies.
gkreidl wrote:Since yesterday there is a kodi-15.1 Jessie release in the archive of the foundation. It contains a few RPi-specific patches and may be a better solution than my package. It is not optimized for RPi2 and will work with any RPi model.
So we could install kodi 15.1 through an "apt-get install kodi" command now ?
gkreidl
Thu Oct 15, 2015 10:27 am
Yes. But you should remove my package first.
c1zz
Thu Oct 15, 2015 2:08 pm
ty4all the good work.
silviu
Sun Oct 18, 2015 9:43 am
gkreidl wrote:So this may be something very special.
Yes - the problem was only for a movie I got as a gift from someone on dvd:
Real.Genius.1985.1080p.WEB-DL.AAC2.0.H.264-pyrodex.mkv
Saran
Mon Oct 19, 2015 4:10 pm
Easier way for Raspbian Jessie:
sudo apt-get update
sudo apt-get install kodi
The version installed is:
$ kodi --version
15.1 Git:Unknown Media Center Kodi
Copyright (C) 2005-2013 Team Kodi - http://kodi.tv
Works just fine...
gkreidl
Mon Oct 19, 2015 4:19 pm
Saran wrote:Easier way for Raspbian Jessie:
sudo apt-get update
$ kodi --version
Works just fine...
I already reported it ( viewtopic.php?f=66&t=109088&p=831057#p829355 ) and also mention it now in the OP-
The difference is the newer version and that it has been compiled for RPi2 with some optimizations.
But basically I consider my job done now as we have a kodi 15 release in the repository. I will update it once more though to get the final 15.2 release.
giallopaperino
Mon Oct 19, 2015 7:34 pm
where I find iptv simple client for kodi 15?? in add on menu is not present. So please to help me to find it.
SoftWord
Mon Oct 19, 2015 7:47 pm
I'v installed kodi 15.1 from mene's repository (http://archive.mene.za.net/raspbian/) and I think that kodi addons in that repository aren't updated because when enable vdr vnsi addon, tell me that kodi have api version 1.9.6 but plugin is 1.9.2.
Please I need help for that, I'm new about raspberry and kodi 15.x new compilation system
SoftWord
Mon Oct 19, 2015 7:50 pm
where I can find addon vdr vnsi build with api 1.9.6?
spel
Mon Oct 19, 2015 9:44 pm
Thank you gkreidl for your great work !
For my part, I've also installed the official package throught apt-get, so I have now kodi 15.1. But ... I still have a black screen when in try to leave Kodi :( Am I the only one ?
Rascas
Tue Oct 20, 2015 12:35 pm
SoftWord: Here you have all PVR addons for Kodi 15.X.
http://pipplware.pplware.pt/pipplware/d ... in/binary/
Just download and install with dpkg -i
Return to “Raspbian”
