Rascas
Re: Kodi 15.1 Debian package for Raspbian on RPi 2
Fri Oct 09, 2015 7:13 pm
Baleeverne wrote:Hey thanks a lot for this! I do have a bit of an issue actually. I have no subtitles when playing some MKV files.
Reading around the net i thought it was due to libass not being present but libass4 is present (i'm on wheezy).
I don't get why it doesnt work for these files. Here is a description of the video (the exemple is the last One Piece episode to date in MKV):
Codec : H264 - MPEG-4 AVC (part 10) (avc1)
Resolution : 1920x1090
FPS : 23.976215
Format décodé: Planar 4:2:0 YUV
Codec : MPEG AAC Audio (mp4a)
Fréquence d'échantillonnage: 44100 Hz
Codec : SubStation Alpha subtitles (ssa )
(It's in french i'm sorry ;))
THanks a lot guys!
You need a newer version of libass than the one present in Raspbian Wheezy repos:
Here it is:
http://pipplware.pplware.pt/pipplware/d ... _armhf.deb
Baleeverne
Sat Oct 10, 2015 9:38 am
Thanks a bunch it was indeed coming from libass being too old!
<3 you man
gkreidl
Sat Oct 10, 2015 1:18 pm
I'm currently building a first kodi-15.2RC3 Jessie release and need one or two people to test it on on a fresh (not upgraded) Jessie release. Send me a PM is you are willing to help.
Minimal Kiosk Browser (kweb)
gkreidl
Re: Kodi 15 for Raspbian Wheezy & Jessie for RPi2
Sun Oct 11, 2015 9:42 am
I've just published kodi-15.2RC3 (release 151903, git Rev.: 20151006-9efd358) for Jessie and updated the OP accordingly.
c1zz
Sun Oct 11, 2015 11:35 am
Hi. I got an error i cant handle.
15.2-RC3 Git:2015-10-06-9efd358 Media Center Kodi
Linux raspberrypi 4.1.10-v7+ Raspbian GNU/Linux 8
RPi2B
Amazon-Prime Addon from lordk Version 1.1.7
11:08:07 T:1859122208  NOTICE: https://atv-ps-eu.amazon.com/cdp/catalog/GetASINDetails?version=2&format=json&asinlist=B00ILIGDUE&deviceID=A15AVU2FEGGB5L&includeRestrictions=true&deviceTypeID=A35LWR0L7KC0TJ&firmware=WIN%2017,0,0,188%20PlugIn&NumberOfResults=1
11:08:08 T:1859122208   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type: <class 'urllib2.HTTPError'>
                                            Error Contents: HTTP Error 410: Gone
                                              File "/home/pi/.kodi/addons/plugin.video.prime_instant/default.py", line 1461, in <module>
                                                playVideo(url, selectQuality=="true")
                                              File "/home/pi/.kodi/addons/plugin.video.prime_instant/default.py", line 784, in playVideo
                                                asincontent = getUnicodePage('https://'+apiMain+'.amazon.com/cdp/catalog/GetASINDetails?version=2&format=json&asinlist='+videoID+'&deviceID='+urllib.quote_plus(matchCID[0].encode("utf8"))+'&includeRestrictions=true&deviceTypeID='+matchDID[0]+'&firmware=WIN%2017,0,0,188%20PlugIn&NumberOfResults=1')
                                              File "/home/pi/.kodi/addons/plugin.video.prime_instant/default.py", line 1009, in getUnicodePage
                                                req = opener.open(url)
                                              File "/usr/lib/python2.7/urllib2.py", line 437, in open
                                                response = meth(req, response)
                                              File "/usr/lib/python2.7/urllib2.py", line 550, in http_response
                                                'http', request, response, code, msg, hdrs)
                                              File "/usr/lib/python2.7/urllib2.py", line 475, in error
                                                return self._call_chain(*args)
                                              File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain
                                                result = func(*args)
                                              File "/usr/lib/python2.7/urllib2.py", line 558, in http_error_default
                                                raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
                                            HTTPError: HTTP Error 410: Gone
                                            -->End of Python script error report<--
11:08:08 T:1950675728   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.prime_instant/?url=B00ILIGDUE&mode=playVideo&name=R.E.D.+2+%5Bdt.%2FOV%5D&thumb=https%3A%2F%2Fimages-eu.ssl-images-amazon.com%2Fimages%2FI%2F51RXDqJNSfL.jpg]
11:08:09 T:1859122208  NOTICE: Thread BackgroundLoader start, auto delete: false
Could this happen on a missing codec?
ty
gkreidl
Sun Oct 11, 2015 12:50 pm
No, wrong URL, as it looks. You should contact the author of the plugin.
chewy74
Sun Oct 11, 2015 2:24 pm
Got this during install... Is it OK for me to manually remove?
dpkg: warning: unable to delete old directory '/etc/sudoers.d/kodi': Directory not empty
gkreidl
Sun Oct 11, 2015 3:34 pm
chewy74 wrote:Got this during install... Is it OK for me to manually remove?
check the content; it should be the same as with the new version if you haven't changed it (should have been removed during installation if a kodi version was present).
diederik
Sun Oct 11, 2015 4:29 pm
gkreidl wrote:It seems not to be in Jessie any more. But you can install it manually:
http://archive.raspbian.org/raspbian/po ... _armhf.deb
It is superseded by libgcrypt20, see https://bugs.debian.org/cgi-bin/bugrepo ... bug=757575 and https://bugs.debian.org/cgi-bin/bugrepo ... bug=767611
gkreidl
Sun Oct 11, 2015 5:03 pm
It has been replaced in the 15.2RC3 Jessie version.
silviu
Mon Oct 12, 2015 7:00 am
In the tar.gz files there are .deb files. Thank you very much !
You can help the server by making torrents for the .tar.gz with public or your server trackers and let us download the .torrent files instead.
A magnet link would mean no server is needed but the torrent would be lost at zero seeders. Unless you have a webseed open on the server like they do on jupiterbroadcasting.com
gkreidl
Mon Oct 12, 2015 7:51 am
silviu wrote:I've had success in building Kodi 15.1 Isengard for Raspbian Jessie by adapting an archlinuxarm pkgbuild file for kodi-rbp.
You can take a look and use the script that I made - it's not perfect but with some tinkering it did the job.
To make the deb I used the checkinstall program and dpkg-deb, so before running it do:
sudo apt-get install -y devscripts debhelper checkinstall
Here is the script:
https://github.com/iugamarian/raspberry ... siekodideb
Good luck !
1) You should not use this thread for this; create a new topic instead.
2) This is really missing most of the hard work: finding all the dependencies for compiling (-dev packages) and for installation (to put into the simple debian description created by checkinstall).
c1zz
Tue Oct 13, 2015 5:33 am
gkreidl wrote:No, wrong URL, as it looks. You should contact the author of the plugin.
Prime Video have change DRM and switched to html5.
http://www.kodinerds.net/index.php/Thre ... c9518588e8
[/close]
silviu
Tue Oct 13, 2015 7:04 am
gkreidl
Tue Oct 13, 2015 7:21 am
silviu wrote: 1) You should not use this thread for this; create a new topic instead.
1) This topic is found on google when searching "jessie kodi" and the script is not so good to deserve a topic of it's own I think...
2) Work in progress... anyone can make pull requests or build their own. Free and open source software.
P. S. I just want to help the community to have a media center now on Jessie (and hope someone makes a ppa soon 8-) ).[/quote]
There's a thread about compiling kodi 15 for RPi 2 already; this might be a better place for your offering.
This thread is for people who want to download an already compiled version. I've changed the title if the OP (again), to make it more clear.
silviu
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Tue Oct 13, 2015 5:36 pm
A possible problem identified: after installation of Kodi Jessie 15.2 and running ok (and after installing minimal kweb), when I install other programs I get.
The following packages were automatically installed and are no longer required:
libao-common libao4 libmicrohttpd10 libmysqlclient18 libpcrecpp0
libshairplay0 libtinyxml2.6.2 libva-x11-1 mysql-common python-imaging
ttf-dejavu-core ttf-liberation
Use 'apt-get autoremove' to remove them.
Checked after restart, it's installed and still appears.
Normally when a package is installed, it's dependencies don't risk being autoremoved.
Possible solution - a meta package that lists all dependencies plus the program.
expandables
Tue Oct 13, 2015 6:30 pm
Hi I only use wheezy and have no plans to update to Jessie. Can you please make the latest new stable version be both Jessie and Wheezy? :mrgreen:
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
expandables
Tue Oct 13, 2015 7:11 pm
Please continue wheezy development. :(
:mrgreen:
Tue Oct 13, 2015 7:32 pm
expandables wrote:Please continue wheezy development. :(
:mrgreen:
The official kodi-15.1 release (release 150901, git Rev.: 20150816-f4dda26) for Wheezy. This will be the last Wheezy version I publish.
If you are bothered then carry on updating yourself and hosting somewhere :!:
gkreidl
Tue Oct 13, 2015 8:44 pm
silviu wrote:A possible problem identified: after installation of Kodi Jessie 15.2 and running ok (and after installing minimal kweb), when I install other programs I get.
This should not happen! I didn't check all, but at least libmicrohttpd10 and libmysqlclient18 are in the dependencies list of kodi. Perhaps there is a bug in gdebi. You could try to install kodi-15 once more using dpkg.
gkreidl
Tue Oct 13, 2015 8:48 pm
expandables wrote:Hi I only use wheezy and have no plans to update to Jessie. Can you please make the latest new stable version be both Jessie and Wheezy? :mrgreen:
No. I've updated all my systems to Jessie and trying to build a Wheezy version would lead to a lot of trouble. If you want to stay on Wheezy you have to live with an older version (the same is true true for thousands of other packages).
expandables
Tue Oct 13, 2015 10:17 pm
:o :shock: :cry:
:mrgreen:
expandables
Tue Oct 13, 2015 11:16 pm
I will compile kodi for Wheezy and thanks for your builds appreciate it.
:mrgreen:
spel
Wed Oct 14, 2015 8:00 am
Thank for releasing a compiled package of Kodi 15 for Raspbian !
I'm new to Raspberry and Raspbian, I've bought a RPI2 last week and I have a fresh install of Raspbian Jessie. I've first installed Kodi 14, and I got the so famous black screen issue on exit. So I followed your instructions and installed Kodi 15.2RC3. It have been installed well and it works fine but ... It still hang on a black screen when exiting Kodi, nothing changed regarding this issue for me :(
Have you any idea ? Have I missed a step ?
gkreidl
Wed Oct 14, 2015 11:15 am
spel wrote:Hello,
Please check, if you have really installed kodi-15. check in kodi, options, system info
How do you start kodi? Do you use my startkodi command (or startt from the desktop menu)?
Return to “Raspberry Pi OS”
