mikerr
MiniBian and wifi (HOWTO & preconfigured image)
Wed Apr 29, 2015 5:14 pm
I've been using MiniBian for a while since its "raspbian without the bloat" and fits on a 512mb card:
https://minibianpi.wordpress.com/features/
but that was with ethernet, then came across some trouble getting wifi to work... so I thought I'd write up the steps below:
MiniBian is so minimal it doesn't have wifi drivers built in... so install some wifi drivers:
apt-get install firmware-ralink
apt-get install firmware-realtek
Test things are working by doing a scan for networks
apt-get install wireless-tools
iwlist wlan0 scan
Now we'll set it up to auto connect:
apt-get install wpasupplicant
edit /etc/network/interfaces:
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
edit /etc/wpa_supplicant/wpa_supplicant.conf:
network={
        key_mgmt=NONE
        priority=-999
The above sets it to connect to any open wifi.
I made an image with this pre-setup for those in the Model A "no ethernet to configure wifi" catch22 situation:
https://sourceforge.net/projects/minibianwifi/
Chillman90
Re: MiniBian and wifi (HOWTO & preconfigured image)
Thu May 07, 2015 8:37 am
Thank you!
Will try that at home!
Was looking for exactly this to have an airprint solution on a 2GB microSD card.
tobios
Thu Jul 16, 2015 7:31 pm
Thanks, it's useful !
But could you include the Atheros drivers in the next build ?
I have this adapter : https://wikidevi.com/wiki/TP-LINK_TL-WN722N but he is not supported.
Thank's.
Cheers.
deltalimablahblah²
No iwlist after install
Sat Nov 14, 2015 12:30 pm
I'm using minibian for MPD since a few weeks. I bought a RTL wifi adapter yesterday. I installed all tools above mentioned. But there's no iwlist or similar after installation!? What's wrong?
Thank you in advance for help...
diederik
Re: No iwlist after install
Sat Nov 14, 2015 8:24 pm
deltalimablahblah² wrote:I installed all tools above mentioned. But there's no iwlist or similar after installation!? What's wrong?
iwlist is located at /sbin/iwlist, so you either need to start it with the full path or run it as root or with sudo.
Return to “Raspberry Pi OS”
