e-raser
Linux permissions problem - create files (goaccess, nginx)
Tue Apr 07, 2015 8:13 pm
it seems I have a little "typical" linux permissions problem. Freaked me out for almost 2 hours already. Maybe you can help me here (didn´t find a better matching area on the forum).
What I want to do: Use "goaccess" for parsing nginx webserver logs.
Problem:
Manual command "sudo -u www-data /usr/local/bin/goaccess -p /var/www/.goaccessrc -f /var/log/nginx/access.log > /var/www/owncloud/logs/ahd.htm" gives "bash: /var/www/owncloud/logs/ahd.htm: no rights"
So the user www-data can´t write the .htm file (same result with "sudo -u www-data touch /var/www/owncloud/logs/test.txt"). Same with user pi, even with sudo!
I created the logs-folder manually and used "sudo chown -R www-data:www-data /var/www/owncloud/logs" for changing the owner to www-data. I also tried a chmod with 777 on the directory - nothing changed.
Owner of the folder is already www-data:
drw-r--r-- 2 www-data www-data 4096 Apr 6 20:30 logs
Question: What can I do for giving www-data access to read+write to the logs-folder? I already tried several chown and chmod commands, but I simply don´t get it... really really frustrating.
1x Nextcloud & Pi-hole & ... on Raspbian @ Pi (4 4 GB)
1x Kodi media center on LibreELEC @ Pi 3 B+
Re: Linux permissions problem - create files (goaccess, ngin
Tue Apr 07, 2015 8:45 pm
If it's a directory you need rwx to create new files.
This is a doctor free zone.
e-raser
Tue Apr 07, 2015 8:47 pm
What would be the right chmod command for changing it?
"sudo chmod ??? /var/www/owncloud/logs" ?
Tue Apr 07, 2015 9:25 pm
e-raser wrote:What would be the right chmod command for changing it?
sudo chmod 755 /var/www/owncloud/logs
e-raser
Wed Apr 08, 2015 7:14 am
Same result! Seems it´s a bit more complicated...
e-raser
Wed Apr 08, 2015 7:25 am
No chance. My ownly workaround at the moment is writing the .htm file to e.g. /home/pi and doing "sudo -u www-data cp /home/pi/ahd.htm /var/www/owncloud/logs/ahd.htm".
It´s really freaky...
Wed Apr 08, 2015 7:45 am
e-raser wrote: Owner of the folder is already www-data:
sudo chmod 775 logs
or
sudo chmod g+w logs
jojopi
Wed Apr 08, 2015 8:27 am
e-raser wrote:Manual command "sudo -u www-data /usr/local/bin/goaccess -p /var/www/.goaccessrc -f /var/log/nginx/access.log > /var/www/owncloud/logs/ahd.htm" gives "bash: /var/www/owncloud/logs/ahd.htm: no rights"
Shell redirections (">") are set up before the command ("sudo") is started. This error means that pi cannot write the file, not www-data. (In fact user www-data would not require access at all. Permissions are needed at the time of opening, not the time of writing.)
Of course the main problem is that the directory lacks execute permission, but as well as that you will need either the clumsy:
sudo -u www-data bash -c "command > file"
Or, perhaps more sensibly, add user pi to group www-data and make the directory group-writeable so that both users have access.
e-raser
Wed Apr 08, 2015 8:30 am
Same result (no rights). I almost gave up and used the following workaround as cronjob:
/usr/local/bin/goaccess -p /var/www/.goaccessrc -f /var/log/nginx/access.log > /var/www/goaccess.html; mv /var/www/goaccess.html /var/www/owncloud/logs/index.html
BUT - UPDATE:
I think I found the mistake.
After
when using the cronjob the command
/usr/local/bin/goaccess -p /var/www/.goaccessrc -f /var/log/nginx/access.log > /var/www/owncloud/logs/index.html
worked perfectly.
So I checked the same command on bash with "sudo -u www-data ..." --> error again.
So I was wondering if the whole command really was processed as www-data: I put an "...; whoami" at the end, which gave "pi"... so the error was (or is) that the command on bash was not run as www-data. Would be interesting to know the correct syntax; i thought "sudo -u username command" is the right one.
At the end not a permission issue, more a "bash sudo as another user" one.
e-raser
Wed Apr 08, 2015 11:41 am
Thanks, didn't read your post before my update.
Return to “Raspbian”
