alias_neo wrote:I noticed your instructions explicitly disables a lot of useful features in the configure step, hence the lack of cec support. "--disable-pulse". I'm going to try build with a bunch of these features not disabled and see where I get, but it might be nice to see the instructions modified not to turn off these useful features.
I used the flag --enable-pulse, config seems to get what I'm going for as config responded that libcec should be enabled.alias_neo wrote:alias_neo wrote:I noticed your instructions explicitly disables a lot of useful features in the configure step, hence the lack of cec support. "--disable-pulse". I'm going to try build with a bunch of these features not disabled and see where I get, but it might be nice to see the instructions modified not to turn off these useful features.
My bad, the pulse one is not the correct flag. "--enable-libcec" is the correct one.
I'm building now so will report back tomorrow on progress, if it works, it would be nice to see this flag added to the instructions so people get CEC when they build.
Actually, as it turns out, the libCEC from the packages repository is too old (1.6.0) but XBMC wants 1.8.0 so I compiled libCEC from the git and installed, then CEC is automatically detected by the ./config for XBMC and is enabled.Emil wrote:I used the flag --enable-pulse, config seems to get what I'm going for as config responded that libcec should be enabled.alias_neo wrote:alias_neo wrote:I noticed your instructions explicitly disables a lot of useful features in the configure step, hence the lack of cec support. "--disable-pulse". I'm going to try build with a bunch of these features not disabled and see where I get, but it might be nice to see the instructions modified not to turn off these useful features.
I just started building and will be away until monday afternoon so I'll report back then.
However, i recently discovered that my television doesnt support CEC, that will not stop me from trying to implement it though.
Just don't forget to install libcec-dev.
D stands for uninterruptable sleep, which I guess can mean either that the linking process is doing something it shouldnt or that you have lost contact with whatever memory you were working in.alias_neo wrote:I configured mine slightly differently but build failed at linking of XBMC.bin this was due to insufficient memory, so I increased swap to 200M, still not big enough, then to 300M which is fine but it has been linking for the last 2 hours, htop says the process is status "D" which is usually "stuck", am I just being impatient and is the linking stage supposed to take so long? Or is it actually stuck?
Emil wrote:D stands for uninterruptable sleep, which I guess can mean either that the linking process is doing something it shouldnt or that you have lost contact with whatever memory you were working in.alias_neo wrote:I configured mine slightly differently but build failed at linking of XBMC.bin this was due to insufficient memory, so I increased swap to 200M, still not big enough, then to 300M which is fine but it has been linking for the last 2 hours, htop says the process is status "D" which is usually "stuck", am I just being impatient and is the linking stage supposed to take so long? Or is it actually stuck?
I actually compiled without using swap, I just ran it with 240/16 memory split. It worked last time I compiled XBMC. However, I have had errors compiling this time. The thing is I don't even know what errors I've had as I got no logs of it, so I will probably recompile tonight with the new libcec.
'arm-linux-gnueabihf-gcc: internal compiler error: Killed (program cc1)' means you have out of memory problem. Apply some moderate overclocking (if you have not already done so) by editing these lines in your /boot/config.txt file to:kiasa wrote:i my friend,![]()
like u i also have a problem when i make the buildthe output isCode: Select all
[email protected] ~/xbmc-rbp $ make -C tools/rbp/depends/xbmc/
here the procedure i'm followingCode: Select all
make: Entering directory `/home/pi/xbmc-rbp/tools/rbp/depends/xbmc' cd ../../../../; ./bootstrap autoreconf: Entering directory `.' autoreconf: configure.in: not using Gettext autoreconf: running: aclocal --output=aclocal.m4t Can't exec "aclocal": No such file or directory at /usr/share/autoconf/Autom4te/FileUtils.pm line 326. autoreconf: failed to run aclocal: No such file or directory make: *** [configure] Error 1 make: Leaving directory `/home/pi/xbmc-rbp/tools/rbp/depends/xbmc'
http://www.raspbian.org/RaspbianXBMC
want u share some info with me ?? thanks and bye
Stefano
nummy wrote:I get the same errors as you when I try to makesotris99 wrote:Hello i have some problems to make the build...
CC libavcodec/adpcm_data.o CC libavcodec/adx.o CC libavcodec/adx_parser.o CC libavcodec/adxdec.o CC libavcodec/alac.o CC libavcodec/allcodecs.o CC libavcodec/alsdec.o CC libavcodec/amrnbdec.o CC libavcodec/amrwbdec.o CC libavcodec/anm.o CC libavcodec/ansi.o libavcodec/ansi.c: In function βdecode_frameβ: libavcodec/ansi.c:224:35: warning: βheightβ may be used uninitialized in this function [-Wuninitialized] libavcodec/ansi.c:162:24: note: βheightβ was declared here libavcodec/ansi.c:224:35: warning: βwidthβ may be used uninitialized in this function [-Wuninitialized] libavcodec/ansi.c:162:17: note: βwidthβ was declared here CC libavcodec/apedec.o AS libavcodec/arm/ac3dsp_arm.o AS libavcodec/arm/ac3dsp_armv6.o CC libavcodec/arm/ac3dsp_init_arm.o CC libavcodec/arm/dcadsp_init_arm.o AS libavcodec/arm/dsputil_arm.o AS libavcodec/arm/dsputil_armv6.o CC libavcodec/arm/dsputil_init_arm.o CC libavcodec/arm/dsputil_init_armv5te.o CC libavcodec/arm/dsputil_init_armv6.o CC libavcodec/arm/dsputil_init_vfp.o AS libavcodec/arm/dsputil_vfp.o CC libavcodec/arm/fft_fixed_init_arm.o CC libavcodec/arm/fft_init_arm.o CC libavcodec/arm/fmtconvert_init_arm.o AS libavcodec/arm/fmtconvert_vfp.o CC libavcodec/arm/h264dsp_init_arm.o CC libavcodec/arm/h264pred_init_arm.o AS libavcodec/arm/jrevdct_arm.o AS libavcodec/arm/mpegaudiodsp_fixed_armv6.o CC libavcodec/arm/mpegaudiodsp_init_arm.o CC libavcodec/arm/mpegvideo_arm.o CC libavcodec/arm/mpegvideo_armv5te.o AS libavcodec/arm/mpegvideo_armv5te_s.o AS libavcodec/arm/simple_idct_arm.o AS libavcodec/arm/simple_idct_armv5te.o AS libavcodec/arm/simple_idct_armv6.o CC libavcodec/arm/vp56dsp_init_arm.o AS libavcodec/arm/vp8_armv6.o AS libavcodec/arm/vp8dsp_armv6.o CC libavcodec/arm/vp8dsp_init_arm.o CC libavcodec/ass.o CC libavcodec/ass_split.o CC libavcodec/assdec.o CC libavcodec/asv1.o CC libavcodec/atrac.o CC libavcodec/atrac1.o libavcodec/atrac1.c: In function βatrac1_decode_frameβ: libavcodec/atrac1.c:322:47: warning: to be safe all intermediate pointers in cast from βfloat **β to βconst float **β must be βconstβ qualified [-Wcast-qual] CC libavcodec/atrac3.o libavcodec/atrac3.c: In function βatrac3_decode_frameβ: libavcodec/atrac3.c:879:38: warning: to be safe all intermediate pointers in cast from βfloat **β to βconst float **β must be βconstβ qualified [-Wcast-qual] libavcodec/atrac3.c:883:47: warning: to be safe all intermediate pointers in cast from βfloat **β to βconst float **β must be βconstβ qualified [-Wcast-qual] CC libavcodec/audioconvert.o CC libavcodec/aura.o CC libavcodec/avfft.o CC libavcodec/avpacket.o libavcodec/avpacket.c: In function βav_dup_packetβ: libavcodec/avpacket.c:130:5: warning: βav_destruct_packet_nofreeβ is deprecated (declared at libavcodec/avpacket.c:27) [-Wdeprecated-declarations] CC libavcodec/avs.o libavcodec/avs.c: In function βavs_decode_frameβ: libavcodec/get_bits.h:278:8: warning: βchange_map.size_in_bits_plus8β may be used uninitialized in this function [-Wuninitialized] libavcodec/avs.c:60:19: note: βchange_map.size_in_bits_plus8β was declared here libavcodec/get_bits.h:261:26: warning: βchange_map.bufferβ may be used uninitialized in this function [-Wuninitialized] libavcodec/avs.c:60:19: note: βchange_map.bufferβ was declared here CC libavcodec/bethsoftvideo.o CC libavcodec/bfi.o CC libavcodec/bgmc.o CC libavcodec/bink.o libavcodec/bink.c: In function βbinkb_decode_planeβ: libavcodec/bink.c:860:17: warning: passing argument 4 of βread_dct_coeffsβ from incompatible pointer type [enabled by default] libavcodec/bink.c:593:12: note: expected βconst int32_t (*)[64]β but argument is of type βint32_t (*)[64]β libavcodec/bink.c:893:17: warning: passing argument 4 of βread_dct_coeffsβ from incompatible pointer type [enabled by default] libavcodec/bink.c:593:12: note: expected βconst int32_t (*)[64]β but argument is of type βint32_t (*)[64]β CC libavcodec/binkaudio.o libavcodec/binkaudio.c: In function βdecode_blockβ: libavcodec/binkaudio.c:269:43: warning: to be safe all intermediate pointers in cast from βfloat **β to βconst float **β must be βconstβ qualified [-Wcast-qual] libavcodec/binkaudio.c:271:48: warning: to be safe all intermediate pointers in cast from βfloat **β to βconst float **β must be βconstβ qualified [-Wcast-qual] CC libavcodec/binkdsp.o CC libavcodec/bintext.o libavcodec/bintext.c:92:13: warning: βhscrollβ defined but not used [-Wunused-function] CC libavcodec/bitstream.o CC libavcodec/bitstream_filter.o libavcodec/bitstream_filter.c: In function βav_bitstream_filter_filterβ: libavcodec/bitstream_filter.c:62:15: warning: cast discards β__attribute__((const))β qualifier from pointer target type [-Wcast-qual] CC libavcodec/bmp.o libavcodec/bmp.c: In function βbmp_decode_frameβ: libavcodec/bmp.c:177:22: warning: βrgb[2]β may be used uninitialized in this function [-Wuninitialized] libavcodec/bmp.c:177:22: warning: βrgb[1]β may be used uninitialized in this function [-Wuninitialized] libavcodec/bmp.c:172:21: warning: βrgb[0]β may be used uninitialized in this function [-Wuninitialized] CC libavcodec/bmv.o CC libavcodec/c93.o CC libavcodec/cabac.o CC libavcodec/cavs.o CC libavcodec/cavs_parser.o CC libavcodec/cavsdec.o CC libavcodec/cavsdsp.o CC libavcodec/cdgraphics.o CC libavcodec/celp_filters.o CC libavcodec/celp_math.o CC libavcodec/cga_data.o CC libavcodec/chomp_bsf.o libavcodec/chomp_bsf.c: In function βchomp_filterβ: libavcodec/chomp_bsf.c:34:16: warning: cast discards β__attribute__((const))β qualifier from pointer target type [-Wcast-qual] CC libavcodec/cinepak.o CC libavcodec/cljr.o CC libavcodec/cook.o HOSTCC libavcodec/cos_tablegen.o HOSTCC libavcodec/cos_tablegen GEN libavcodec/cos_fixed_tables.c CC libavcodec/cos_fixed_tables.o GEN libavcodec/cos_tables.c CC libavcodec/cos_tables.o CC libavcodec/cscd.o CC libavcodec/cyuv.o CC libavcodec/dca.o CC libavcodec/dca_parser.o CC libavcodec/dcadsp.o CC libavcodec/dct.o CC libavcodec/dct32_fixed.o CC libavcodec/dct32_float.o CC libavcodec/dfa.o CC libavcodec/dirac.o CC libavcodec/dirac_arith.o CC libavcodec/dirac_parser.o CC libavcodec/diracdec.o CC libavcodec/diracdsp.o CC libavcodec/dnxhd_parser.o CC libavcodec/dnxhddata.o CC libavcodec/dnxhddec.o CC libavcodec/dpcm.o CC libavcodec/dpx.o CC libavcodec/dsicinav.o CC libavcodec/dsputil.o CC libavcodec/dump_extradata_bsf.o HOSTCC libavcodec/dv_tablegen.o HOSTCC libavcodec/dv_tablegen GEN libavcodec/dv_tables.h CC libavcodec/dv.o libavcodec/dv.c: In function βdvvideo_decode_frameβ: libavcodec/dv.c:1097:12: warning: assignment discards βconstβ qualifier from pointer target type [enabled by default] libavcodec/dv.c: At top level: libavcodec/dv.c:350:34: warning: βdvvideo_init_encoderβ defined but not used [-Wunused-function] libavcodec/dv.c:930:12: warning: βdv_encode_video_segmentβ defined but not used [-Wunused-function] CC libavcodec/dvbsub_parser.o CC libavcodec/dvbsubdec.o libavcodec/dvbsubdec.c: In function βdvbsub_parse_region_segmentβ: libavcodec/dvbsubdec.c:1034:9: warning: variable βversionβ set but not used [-Wunused-but-set-variable] CC libavcodec/dvdata.o CC libavcodec/dvdsub_parser.o CC libavcodec/dvdsubdec.o CC libavcodec/dwt.o libavcodec/dwt.c: In function βspatial_compose_dd97i_dyβ: libavcodec/dwt.c:1080:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c:1081:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c: In function βspatial_compose_dirac53i_dyβ: libavcodec/dwt.c:1104:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c:1105:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c: In function βspatial_compose_dd137i_dyβ: libavcodec/dwt.c:1127:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c:1128:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c: In function βspatial_compose_haari_dyβ: libavcodec/dwt.c:1152:46: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c: In function βspatial_compose_fidelityβ: libavcodec/dwt.c:1168:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c:1169:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c: In function βspatial_compose_daub97i_dyβ: libavcodec/dwt.c:1193:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c:1194:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c:1195:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c:1196:49: warning: initialization from incompatible pointer type [enabled by default] libavcodec/dwt.c: In function βff_spatial_idwt_init2β: libavcodec/dwt.c:1303:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1304:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1310:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1311:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1317:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1318:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1325:29: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1334:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1335:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1340:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1341:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1342:32: warning: assignment from incompatible pointer type [enabled by default] libavcodec/dwt.c:1343:32: warning: assignment from incompatible pointer type [enabled by default] CC libavcodec/dxa.o CC libavcodec/dxtory.o CC libavcodec/eac3_data.o CC libavcodec/eac3dec.o CC libavcodec/eacmv.o CC libavcodec/eaidct.o CC libavcodec/eamad.o libavcodec/eamad.c: In function βdecode_frameβ: libavcodec/eamad.c:97:44: warning: βmv_yβ may be used uninitialized in this function [-Wuninitialized] libavcodec/eamad.c:198:15: note: βmv_yβ was declared here libavcodec/eamad.c:97:97: warning: βmv_xβ may be used uninitialized in this function [-Wuninitialized] libavcodec/eamad.c:198:9: note: βmv_xβ was declared here CC libavcodec/eatgq.o CC libavcodec/eatgv.o CC libavcodec/eatqi.o CC libavcodec/error_resilience.o CC libavcodec/escape124.o CC libavcodec/escape130.o CC libavcodec/faandct.o CC libavcodec/faanidct.o CC libavcodec/faxcompr.o CC libavcodec/fft_fixed.o CC libavcodec/fft_float.o CC libavcodec/ffv1.o libavcodec/ffv1.c:238:13: warning: βfind_best_stateβ defined but not used [-Wunused-function] libavcodec/ffv1.c:327:39: warning: βput_symbolβ defined but not used [-Wunused-function] libavcodec/ffv1.c: In function βdecode_frameβ: libavcodec/ffv1.c:1674:29: warning: βcontext_countβ may be used uninitialized in this function [-Wuninitialized] libavcodec/ffv1.c:1544:15: note: βcontext_countβ was declared here CC libavcodec/ffwavesynth.o CC libavcodec/flac.o CC libavcodec/flac_parser.o libavcodec/flac_parser.c: In function βflac_parseβ: libavcodec/flac_parser.c:572:50: warning: cast discards β__attribute__((const))β qualifier from pointer target type [-Wcast-qual] CC libavcodec/flacdata.o CC libavcodec/flacdec.o CC libavcodec/flashsv.o CC libavcodec/flicvideo.o CC libavcodec/flvdec.o CC libavcodec/fmtconvert.o CC libavcodec/fraps.o CC libavcodec/frwu.o CC libavcodec/g722.o CC libavcodec/g722dec.o CC libavcodec/g723_1.o CC libavcodec/g726.o CC libavcodec/g729dec.o libavcodec/g729dec.c: In function βdecode_frameβ: libavcodec/g729dec.c:423:14: warning: assignment from incompatible pointer type [enabled by default] CC libavcodec/g729postfilter.o CC libavcodec/gifdec.o CC libavcodec/golomb.o CC libavcodec/gsm_parser.o CC libavcodec/gsmdec.o CC libavcodec/gsmdec_data.o CC libavcodec/h261.o CC libavcodec/h261_parser.o CC libavcodec/h261dec.o CC libavcodec/h263.o CC libavcodec/h263_parser.o CC libavcodec/h263dec.o CC libavcodec/h264.o libavcodec/h264.c: In function βdecode_slice_headerβ: libavcodec/h264.c:2925:35: warning: to be safe all intermediate pointers in cast from βuint8_t **β to βconst uint8_t **β must be βconstβ qualified [-Wcast-qual] libavcodec/h264.c: In function βfill_filter_caches_interβ: libavcodec/h264.c:3282:34: warning: initialization from incompatible pointer type [enabled by default] libavcodec/h264.c:3297:38: warning: initialization from incompatible pointer type [enabled by default] libavcodec/h264.c:3330:30: warning: initialization from incompatible pointer type [enabled by default] libavcodec/h264.c: In function βdecode_frameβ: libavcodec/h264.c:4078:21: warning: initialization discards βconstβ qualifier from pointer target type [enabled by default] arm-linux-gnueabihf-gcc: internal compiler error: Killed (program cc1) Please submit a full bug report, with preprocessed source if appropriate. See <file:///usr/share/doc/gcc-4.6/README.Bugs> for instructions. make[2]: *** [libavcodec/h264.o] Error 4 make[2]: Leaving directory `/home/pi/xbmc-rbp/lib/ffmpeg' make[1]: *** [ffmpeg] Error 2 make[1]: Leaving directory `/home/pi/xbmc-rbp/lib' make: *** [dvdpcodecs] Error 2
cd xbmc-rbp/
cat /proc/sys/vm/swappiness
sudo sysctl vm.swappiness=10
git clone git://github.com/Pulse-Eight/libcec.git
sudo apt-get install liblockdev1-dev
cd libcec
autoreconf -vif
./configure
make
sude make install
cd ..
This is exactly how I compiled, I found that I had to switch for a 128/128 memory split for it to run, but I still get the openGL warning first then it starts... weird.Darkness wrote:I had no problem following the instructions here: http://www.raspbian.org/RaspbianXBMC
I even compiled it with libcec support adding these simple steps to the instructions:
somewhere before doing ./configure on xbmc:and for the ./configure command from XBMC, add the option: --enable-libcecCode: Select all
git clone git://github.com/Pulse-Eight/libcec.git sudo apt-get install liblockdev1-dev cd libcec autoreconf -vif ./configure make sude make install cd ..
However, when I want to start XBMC, it complains:
xbmc needs hardware accelerated opengl rendering.
Install an appropriate graphics driver
So at this moment it does not want to start yet, but at least compiling with libcec seems to be working out of the box.
Do I need to set some extra options somewhere?
I am running a raspbian image from a few weeks ago, but I did update it using apt-get update, apt-get upgrade and the rpi-update script.
Yeh, I saw loads of this error, I solved it by uninstalling libcec from apt-get ... go figure.Darkness wrote:another thing, I see a few log in the home directory which contains an error about the libcec:
ERROR: Unsupported libCEC interface version. 5634 is greater than the version XBMC supports (5888)
though 5634 does not really seem greater than 5888 to me![]()
Does xbmc actually require openGL? I read here that it should be using EGL:
http://archlinuxarm.org/forum/viewtopic ... 1ba#p18108
That's what I did, compiled it, and made sure to uninstall the version from apt.Diaoul wrote:AFAIK Raspbian provides libcec 1.6.x whereas RPi support has been introduced with the 1.8.x releases.
This is never gonna work until Raspbian updates libcec to 1.8.x
--or--
You can manually compile libcec 1.8.x on the RPi and install it that way
00:11:28 T:1103012400 ERROR: EGL failed to return any matching configurations: 1
00:11:28 T:1103012400 NOTICE: EGL not configured correctly. Let's try to do that now...
00:11:28 T:1103012400 ERROR: EGL not configured correctly to create a surface
00:11:28 T:1103012400 FATAL: CApplication::Create: Unable to create window
Might be this:Darkness wrote:I compared my ./configure output with the one on the raspbianXBMC page and except for the added libcec support and mysql support, they are identical.
So I suspect a difference somewhere in my raspbian image and the one others here are using to successfully compile an run xbmc, probably related to video modes.
/home/pi/.xbmc/temp/xbmc.log contains the following:
http://pastebin.com/iL9hzVvS
note the last few lines:Code: Select all
00:11:28 T:1103012400 ERROR: EGL failed to return any matching configurations: 1 00:11:28 T:1103012400 NOTICE: EGL not configured correctly. Let's try to do that now... 00:11:28 T:1103012400 ERROR: EGL failed to return any matching configurations: 1 00:11:28 T:1103012400 ERROR: EGL not configured correctly to create a surface 00:11:28 T:1103012400 FATAL: CApplication::Create: Unable to create window
that could be indeed related. I had seen reference to that earlier in this thread but I did not see which packages exactly to uninstall.dom wrote: Might be this:
http://www.raspberrypi.org/phpBB3/viewt ... 9&p=161414
The instructions are wrong. mesa egl and gl libs should not be installed.
sudo apt-get remove libegl1-mesa-dev libgl1-mesa-dev libgles2-mesa-devDarkness wrote:that could be indeed related. I had seen reference to that earlier in this thread but I did not see which packages exactly to uninstall.dom wrote: Might be this:
I'll try this tonight. However, I do not have issues building it like he did.
Some of these are set to auto so as long as you don't explicitly disable, and you have the appropriate development package installed, it will be compiled in anyway.smonkey wrote:I've been keeping up (as much as possible) with distributions like XBian and Raspbmc, whilst all the time wanting to actually give it a go myself.
I've noticed a few people saying that the following repo should be used:
https://github.com/huceke/xbmc/tree/raspberrypi
instead of the xbmc-rbp one, as it's more up to date with mainline.
Can anyone shed some light on this? I haven't actually been able to find anyone official saying that this is the preferred repository now.
I'd also recommend using --enable-nfs and --enable-airplay (I guess a few people will want it)
Yes, it has more bug fixes and that is where bug fixes will go (until R-Pi patches are accepted into mainline).smonkey wrote: I've noticed a few people saying that the following repo should be used:
Actually, it'd make more sense to just have an official build of XBMC in the package repository so anyone with Raspbian can just install it (if they choose) with apt-get.Montala wrote:Judging by the comments made in this particular thread, and in other also, there is obviously a great deal of interest in an XBMC 'version' of Raspbian.
I know that others, such as raspbmc are already available, but it is not everyone who has the knowledge, or expertise, to build their own image.
What I would like to see is an 'official' Raspbian XBMC image, which could easily be download, and installed by the 'average' user, and also kept regularly updated.
Is this something which is currently under consideration, or indeed perhaps even already available?
Thanks!
If it is indeed as easy as that, then that would be great... but surely if it was, someone would already have done it by now?alias_neo wrote: Actually, it'd make more sense to just have an official build of XBMC in the package repository so anyone with Raspbian can just install it (if they choose) with apt-get.
