Startup errors on Pi2 using Pi1 image
Posted: Sun Feb 22, 2015 10:33 pm
by Bosse_B
I have set up a Pi2B using the SDcard image from a Pi1B following advice in this thread to first do this:
sudo apt-get update
sudo apt-get dist-upgrade -y
Then use Win32Diskimager to make an image of the upgraded Pi1B Raspbian followed by writing the same to a Micro-SD card to be used in the Pi2B.
Today I finally got hold of the TV so I can watch what is going on during startup, so I powered it up after first shutting down the original Pi1B.
After the start I interrogated my router to see what IP address was given to the new Pi2, so I could connect PuTTY using thta new address. Logged on and changed the hostname (since it was the same as the Pi1B).
Problem:
I have two services on the original P1B, which show up on the start screen as having errors.
These are:
- PPTP VPN server
- OpenVPN server
both of which I want to run on this Pi2 rather than on the original because of the higher processing power.
Hand copied from the TV screen:
[FAIL] Starting virtual private network daemon: server failed!
Starting PPTP daemon pptpd.
[FAIL] startpar: service(s) returned failure: openvpn ... failed!
Question:
How can I find out what is the cause of the start errors?
Is there a log somewhere I can view? And how?
Re: Startup errors on Pi2 using Pi1 image
Posted: Sun Feb 22, 2015 10:55 pm
by expandables
Sometimes the server.conf is missing in the /etc/openvpn directory. Or there is an error in that file.
You might not start it as root or the init scrips (/etc/init.d/openvpn) has a non-existing user.
You can enable debug logging in the server.conf and then try to start it again.
Can you also try
sudo /etc/init.d/openvpn start
:mrgreen:
Posted: Sun Feb 22, 2015 11:24 pm
by Bosse_B
Where do I find server.conf?
EDIT:
I got rid of the PPTP start error by editing the /etc/pptpd.conf file and changing localip to the new IP address.
Can't find a corresponding entry for openvpn though...
Posted: Sun Feb 22, 2015 11:35 pm
by expandables
You might need to revise the tutorial you did to install openvpn. There you should get the solution to solve your problem. :mrgreen:
Posted: Sun Feb 22, 2015 11:46 pm
by Bosse_B
Boy, I am daft! :oops:
I thought that server.conf was a raspbian thing but in reality it is the openvpn configuration file:
/etc/openvpn/server.conf
And sure enough, the old IP was present on line #2...
Changed it and no more errors on start! :D
However I have a little different problem concerning the routing system:
pi@raspbian-pi2 ~ $ sudo iptables -t nat -L
Chain PREROUTING (policy ACCEPT)
target     prot opt source               destination
Chain INPUT (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
SNAT       all  --  10.8.0.0/24          anywhere             to:192.168.0.146
The two lines containing something are wrong...
The iptables have been set up once on my Pi1B using its IP address and this is of course also wrong.
But I don't know about a similar conf file to edit to get this right...
Any suggestions?
So if there are erroneous entries in iptables, how can these be corrected?
If left like they are I think that the routing will not work on this OpenVPN server.
Posted: Mon Feb 23, 2015 12:25 am
by expandables
Here is the full openvpn tutorial it shows you how to setup iptables http://raspberrypi-hacks.com/29/turn-yo ... pn-server/ :mrgreen:
