realtebo
Dynamic IP client
Sun Feb 22, 2015 3:44 pm
Can you suggest me a Dynamic Ip client full working on our R.pi 1 ?
ghans
Re: Dynamic IP client
Sun Feb 22, 2015 6:34 pm
sudo apt-get update
sudo apt-get install ddclient
ddclient --help | less
ghans
realtebo
Mon Feb 23, 2015 11:00 am
Thanks, I've tried but i've interrupted (involuntarily) the config.
How can I restart the config?
forenbenutzer
Mon Feb 23, 2015 11:11 am
Simply rename the config file and reinstall. That should do the trick.
Pitendo - Case And Emulator Project - http://edv-huber.com/index.php/problemloesungen/12-pitendo
realtebo
Mon Feb 23, 2015 1:53 pm
I deleted /etc/ddclient.conf then reinstalled.
It has not showed me the config wizard.
If i try executing ddclient I got this
WARNING:  file /etc/ddclient.conf: Cannot open file '/etc/ddclient.conf'. (Permesso negato)
stat() on closed filehandle FD at /usr/sbin/ddclient line 1006.
Use of uninitialized value $mode in bitwise and (&) at /usr/sbin/ddclient line 1007.
readline() on closed filehandle FD at /usr/sbin/ddclient line 1019.
forenbenutzer
Mon Feb 23, 2015 2:12 pm
Ah, OK, now I see what you mean. You want to access the wizard.
Please try:
dpkg-reconfigure ddclient
realtebo
Mon Feb 23, 2015 2:26 pm
command not found...
I used
sudo apt-get --purge remove ddclient && sudo apt-get install ddclient
This worked.
Return to “Raspbian”
