Raspbian and epiphany issue. (Tested on RPI2)
Posted: Thu Feb 19, 2015 2:52 pm
by eriktheitalian
Tested on RPI2 raspbian with epiphany browser.
Some links cannot open like endless loop.
Sample:
http://www.turkcealtyazi.org/mov/046068 ... tural.html
Re: Raspbian and epiphany issue. (Tested on RPI2)
Posted: Thu Feb 19, 2015 3:10 pm
by gkreidl
Confirmed (with the link you posted). Astonishingly it does load in kweb3 (same engine).
Posted: Sun Feb 22, 2015 11:29 am
by florca
If you enable "Webkit - Experimental Features" in kweb3 it fails in exactly the same way - may be related to fast scrolling feature?
Brgds
Phil
Posted: Sun Feb 22, 2015 11:46 am
by gkreidl
florca wrote:If you enable "Webkit - Experimental Features" in kweb3 it fails in exactly the same way - may be related to fast scrolling feature?
Brgds
Phil
Good hint! You can test this in epiphany also. Start it from a terminal with
export WEBKIT_DISABLE_TBS=1
epiphany-browser
(Disables fast scrolling).
Posted: Sun Feb 22, 2015 12:02 pm
by florca
gkreidl wrote:Good hint! You can test this in epiphany also.
Loads perfectly in epiphany with FS disabled - both the Turkish video page and the Squeezebox forums link I posted in the other thread.
Certainly looks like the problem is somewhere in this area....?
Brgds
Phil
