PI B+ install error and Firmware update fail
Posted: Sun Feb 15, 2015 4:11 pm
Performed script to install, upgrade, update distribution and update firmware
pi@pi-clear ~/my_scripts $ sudo ./update_pi.sh
Sun Feb 15 11:04:06 EST 2015
UPDATING SYSTEM SOFTWARE – UPDATE
Hit http://repository.wolfram.com stable Release.gpg
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://repository.wolfram.com stable/non-free armhf Packages
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Ign http://repository.wolfram.com stable/non-free Translation-en_GB
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Reading package lists... Error!
E: Problem syncing the file - sync (5: Input/output error)
E: The package lists or status file could not be parsed or opened.
UPDATING SYSTEM SOFTWARE – UPGRADE
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
libraspberrypi-doc : Depends: libraspberrypi0 (= 1.20150130-1) but 1.20150212-1 is installed
libraspberrypi0 : Depends: raspberrypi-bootloader (= 1.20150212-1) but 1.20150130-1 is installed
E: Unmet dependencies. Try using -f.
UPDATING SYSTEM SOFTWARE – DISTRIBUTION
REMOVING APPLICATION ORPHANS
UPDATING FIRMWARE
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
*** Performing self-update
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 7938 100 7938 0 0 18848 0 --:--:-- --:--:-- --:--:-- 31375
*** Relaunching after update
*** Downloading specific firmware revision (this will take a few minutes)
100 168 0 168 0 0 458 0 --:--:-- --:--:-- --:--:-- 815
100 43.3M 100 43.3M 0 0 690k 0 0:01:04 0:01:04 --:--:-- 869k
*** Updating firmware
*** Updating kernel modules
cp: cannot overwrite non-directory `//lib/modules/3.18.7-v7+/kernel/drivers/net/bonding' with directory `//root/.rpi-firmware/modules/3.18.7-v7+/kernel/drivers/net/bonding'
cp: cannot overwrite non-directory `//lib/modules/3.18.7-v7+/kernel/drivers/net/irda' with directory `//root/.rpi-firmware/modules/3.18.7-v7+/kernel/drivers/net/irda'
Press [Enter] to exit
Try to repair:
pi@pi-clear ~ $ sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
libraspberrypi-doc raspberrypi-bootloader
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
6 not fully installed or removed.
Need to get 0 B/72.2 MB of archives.
After this operation, 437 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: warning: parsing file '/var/lib/dpkg/available' near line 5926 package 'libobt0':
missing description
dpkg: error: parsing file '/var/lib/dpkg/available' near line 5926 package 'libobt0':
missing version
E: Sub-process /usr/bin/dpkg returned an error code (2)
UPDATING FIRMWARE
Try to repair:
missing description
missing version
