tokask
I can't install Cherokee
Sat Nov 03, 2012 2:40 pm
Hi, last Raspberry board with 512Mb.
I've installed raspbian but I can not install Cherokee web server :
$ sudo apt-get install cherokee
Reading package lists... Done
Building dependency tree
Package cherokee is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'cherokee' has no installation candidate
Sander
Re: I can't install Cherokee
Sat Nov 03, 2012 7:37 pm
Raspbian is based on Wheezy (isn't it?), and Wheezy does not contain Cherokee: http://packages.debian.org/search?suite ... s=cherokee
Could that be the explanation?
Sander
Sun Nov 04, 2012 10:56 am
I've created a cherokee package for you. You can install it like this:
wget http://www.appelboor.com/dump/cherokee_1.2.99b-1_armhf.deb
sudo dpkg -i cherokee*deb
sudo ldconfig
If you prefer to create it yourself, here's how:
sudo apt-get install checkinstall
wget http://www.cherokee-project.com/download/trunk/cherokee-latest-snapshot.tar.gz
tar xvzf cherokee-latest-snapshot.tar.gz
cd cherokee-1.2.99b/
./configure
make
sudo make install
sudo ldconfig
sudo checkinstall -D
ls -al *deb
That last command should should the .deb package:
-rw-r--r-- 1 root root 9326098 Nov  4 10:08 cherokee_1.2.99b-1_armhf.deb
HTH
candyman1976
Fri Jan 11, 2013 4:21 am
Thank you thank you thank you! This is exactly what I was looking for. I appreciate the extra details as well.
wdtaylor
Fri Jan 18, 2013 3:14 am
How can I make cherokee start when system boots using this install method?
JozzaTheWick
Sun Feb 24, 2013 6:24 pm
First up, thanks to Sander for the help on Cherokee. I ended up having to build it myself since I'm using the soft-float ABI, so both sets of instructions were helpful.
Secondly, setting Cherokee to start at boot.
There is a start / stop script in the contrib source directory. (I installed from source, so I had the source directory already. Not sure what happens with Sander's .deb package, but you can always download the source package just to get the script.)
It needs to be copied into the appropriate directory & registered. This should be done with root privileges, so either change to the root user or use sudo before each command:
cd <whereever you extracted the Cherokee source code>
cp contrib/cherokee /etc/init.d/
chmod 755 /etc/init.d/cherokee
update-rc.d /etc/init.d/cherokee defaults
The last command will give a warning about 'script cherokee missing LSB tags and overrides', which is due to a change in the way Debian handles dependency-based booting. I don't know enough about Debian to suggest how to tweak the script, and it still worked for me, so I would just ignore the warning :)
When you restart your Pi, you should see a message during the boot sequence about Cherokee starting up, and you'll be able to access your web server immediately!
Finally, here's a link on how to get to the Cherokee admin interface:
http://www.cherokee-project.com/doc/oth ... admin.html
I have a mainly headless setup, so I use
sudo cherokee-admin -b
and then browse to http://<my PI IP address>:9090 to get to the admin site. This is not the most secure way, but it works for me. See the link for full details. Also note that cherokee-admin must be run as root.
References:
Link to the startup script (scroll down to 'Autostart'): http://www.cherokee-project.com/doc/bas ... _unix.html
LSB: http://wiki.debian.org/LSBInitScripts/D ... yBasedBoot
Return to “Raspbian”
Who is online
Users browsing this forum: No registered users and 34 guests
