anatomy
how to install a custom kernel
Fri Jul 23, 2021 8:53 pm
If I want to compile the Linux kernel myself and install it, what is the procedure?
1. What are the steps for installing it? The /boot files look unfamiliar compared to other Linuxes.
2. What special kernel modules are needed just for the Pi?
Thanks.
fep
Re: how to install a custom kernel
Sun Jul 25, 2021 3:49 pm
Here's my kernel config (attached). Everything seems to work except WiFi.
kernelconfig.txt.gz
(55.21 KiB) Downloaded 5 times
anatomy
Mon Jul 26, 2021 4:33 pm
I'm not having any luck following their directions. The drivers never end up getting loaded.
cleverca22
Mon Jul 26, 2021 5:27 pm
did you install the modules with `make modules_install` ?
anatomy
Tue Jul 27, 2021 1:18 am
I think what happens was that I forgot the sudo on that line.
dickon
Tue Jul 27, 2021 10:12 am
To the letter...
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
Return to “Raspberry Pi OS”
