Pearson 39-II
OpenCPN Cannot Be Installed - unmet dependencies
Tue Jul 20, 2021 3:29 am
Just brought up a new Raspberry Pi 4 , using the Raspberry Pi Imager to fresh install the Pi OS. That seems to have gone well and uname -a returns :
Linux raspberrypi 5.10.17-v7l+ #1421 SMP Thu May 27 14:00:13 BST 2021 armv7l GNU/Linux
My problem is OpenCPN cannot install due to:
The following packages have unmet dependencies:
 opencpn : Depends: libtinyxml2.6.2v5 but it is not installable
           Depends: libwxbase3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
           Depends: libwxgtk3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
           Depends: wx3.0-i18n but it is not installable
           Recommends: xcalib but it is not installable
           Recommends: opencpn-doc but it is not going to be installed
I believe I followed the OpenCPN Manual instructions for adding the OpenCPN repository for the "latest Buster:"
That is, my only entry in etc/apt/sources.list is:
deb http://ppa.launchpad.net/opencpn/opencpn/ubuntu/ bionic main
My etc/sources/apt/sources.list.d/raspi.list is:
deb http://archive.raspberrypi.org/debian/ buster main
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://archive.raspberrypi.org/debian/ buster main
running apt-get update seemed to work well:
root@raspberrypi:~# apt-get update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Get:2 http://ppa.launchpad.net/opencpn/opencpn/ubuntu bionic InRelease [20.7 kB]
Get:3 http://ppa.launchpad.net/opencpn/opencpn/ubuntu bionic/main armhf Packages [5,576 B]
Get:4 http://ppa.launchpad.net/opencpn/opencpn/ubuntu bionic/main Translation-en [2,008 B]
Fetched 28.3 kB in 2s (15.7 kB/s)
Reading package lists... Done
root@raspberrypi:~# apt-get install opencpn
But running apt-get install opencpn fails due to the unmet dependencies listed above. What did I miss here? Was I supposed to install source code first even though this is not in the OpenCPN instructions? Am I sourcing the wrong repository? Is OpenCPN code dependent on Debian packages no longer part of Pi OS release 5.10.17?
I managed to hack my way to success a couple of years ago in getting Ubuntu / Mate running on a Beaglebone Black including OpenCPN from the then current Ubuntu ppa and have been navigating with it for all that time since. But I realize I remain a complete newbie on how these Linux releases and installations are managed, especially the Pi OS versions. Could someone enlighten me on what is going wrong here and suggest what to do to complete the OpenCPN installation?
ksharindam
Re: OpenCPN Cannot Be Installed - unmet dependencies
Thu Jul 22, 2021 7:02 am
Ubuntu bionic repository is not compatible with Debian Buster repo.
So if you try to install a package from bionic repo, it can not find the required dependencies in debian buster repo.
Again, the instructions you followed is for Ubuntu or ubuntu based distributions. But RPi OS is debian based.
Thu Jul 22, 2021 7:38 am
Please read the Official Instructions:
https://opencpn.org/wiki/dokuwiki/doku. ... rrypi_rpi2
Ubuntu like Raspberry Pi (Raspbian)OS are both based of Debian and have always been so... :lol:
I am a volunteer, take what I advise as advice not the utopian holy grail.
Thu Jul 22, 2021 7:41 am
The instructions appear to be slightly out of date from 6 months ago, contact the Developers to ask for their Support for their Software.
Alternatively if you can wait for Debian 11 Bullseye based Operating System then the package will be in repositories:
https://packages.debian.org/bullseye/opencpn
If you want to try Debian 11 Bullseye there is a 3rd Party Unofficial Release here:
https://raspi.debian.net/tested-images/
ksharindam
Thu Jul 22, 2021 3:18 pm
Yes you are right.
The opencpn package for bionic is compatible with debian buster.
ksharindam
Thu Jul 22, 2021 3:22 pm
I have successfully installed the package in this way.
1. download the package in this page http://ppa.launchpad.net/opencpn/opencp ... o/opencpn/ .
Direct link http://ppa.launchpad.net/opencpn/opencp ... _armhf.deb .
2. open terminal where the opencpn package was downloaded .
3. Run command
sudo apt install ./opencpn*deb
It will install all required dependencies.
Pearson 39-II
Thu Jul 22, 2021 5:21 pm
Thanks, fruitoftheloom. Yes, of course both Pi OS and Ubuntu are Debian-based variants and the written directions on the OpenCPN site for R Pi 2,3, and 4 are correct to specify the Ubuntu PPA for OpenCPN repository.
I feel pretty sure I followed those OpenCPN R Pi directions to the letter several times over the past few days as I used the R PI Org's Raspberry Pi Imager to do several clean new installs onto my SDHC memory card, then re-attempts to install OpenCPN, but with the same unmet dependencies failure.
But I tried that again last night and got some different results. I found small differences in the details of configuring the things like time zone and national location. Then a much longer initial update of the OS. Best of all the apt-update of both the Debian buster source and the opencpn/ubuntu source were much more detailed and took longer. And OpenCPN then did install apparently flawlessly without any of those unmet dependencies. I've been testing OpenCPN this morning on the many charts I downloaded and it's working great.
I do not discount entirely the possibility that I was making some installation human errors, but across 4 installs, I don't think so. Having posted the issue on several forums (Cruisers, R Pi Forum, and Stack Exchange ) I'm suspecting some kind OS engineer fixed the issue whether she or he read my posts or not, and we got the benefit of the OpenCPN install working exactly as directed in their manual once the update took place. Anyway, YAY, and thanks to everyone.
Return to “Raspberry Pi OS”
