adylanchng
Raspberry Pi HP LaserJet M12a
Mon Jun 21, 2021 8:35 am
I have HP Laserjet Pro M12a USB printer. From my understanding, it is incompatible with my Raspberry Pi 400 running Raspberry Pi OS because my printer is not listed in the list of compatible printers. Additionally if I select what Raspberry recommends, it looks like a success. "Processing - Rendering completed" then "Idle" however nothing actually happens with the printer.
Is my understanding correct? If yes, is there a possibility that HP has marketed this printer in a different region under a different name which is supported by Raspberry Pi OS?
Re: Raspberry Pi HP LaserJet M12a
Mon Jun 21, 2021 8:50 am
The family of HP Printers are known as *WinPrinters* and not supported by HPLIP package. There is a foo2zjs driver package in the repository which "should" suffice:
sudo apt update
sudo apt install printer-driver-foo2zjs
https://packages.debian.org/buster/prin ... er-foo2zjs
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
adylanchng
Sat Jun 26, 2021 3:16 am
sudo apt update
Thank you. It now works.
I installed the package and then followed this guide https://www.raspberrypi.org/blog/printi ... pberry-pi/
Return to “Raspberry Pi OS”
