red trev
cannot install Xorg / xinit via cmd line on Pi4
Wed Jun 16, 2021 1:26 pm
Hi all,
I am trying to install xorg & xinit on my Raspberry Pi 4 via the command line, with Xorg it installs about 97% then fails (see screenshot below) and with xinit it fails straight away.
The update script seems to to be pointing at an outdated URL (http://raspbian.raspberrypi.org/), when i browse this site via a web browser the missing files are not listed.
However if i browse the latest site a similar file is available: http://archive.raspbian.org/raspbian/po ... _armhf.deb
Is there a way of installing Xorg / xinit via the command line that does not point to the old repository ? thanks
scruss
Re: cannot install Xorg / xinit via cmd line on Pi4
Wed Jun 16, 2021 2:44 pm
Your network's down - it can't resolve the repo's address.
Pronouns: he/him
red trev
Wed Jun 16, 2021 2:52 pm
My network is not down, it is able to install other packages (just did not include in screenshot).
As i said, the item it is looking for (xterm_344-1+deb10u1_armhf.deb) is not on http://raspbian.raspberrypi.org/raspbia ... n/x/xterm/ which the install script is looking for, but it is listed on https://archive.raspbian.org/raspbian/p ... n/x/xterm/.
Therefore, is there a way of installing https://archive.raspbian.org/raspbian/p ... _armhf.deb from the command line directly, instead of relying on an outdated install script for Xorg ?
KeithMck
Wed Jun 16, 2021 5:21 pm
You could just download the file & use dpkg to install it.
bls
Wed Jun 16, 2021 5:49 pm
What "script" are you using?
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
RonR
Wed Jun 16, 2021 9:53 pm
xterm (344-1+deb10u1 Raspbian:stable [armhf]) is readily available with no special actions (simulation follows - remove '-s' for actual install):
root@raspberrypi:~# apt update
root@raspberrypi:~# apt -s install xterm
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  fontconfig-config fonts-dejavu-core libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libfontconfig1 libfontenc1 libgl1 libgl1-mesa-dri libglapi-mesa libglvnd0
  libglx-mesa0 libglx0 libice6 libllvm9 libsensors-config libsensors5 libsm6 libutempter0 libx11-xcb1 libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-shape0
  libxcb-sync1 libxcomposite1 libxdamage1 libxfixes3 libxft2 libxi6 libxinerama1 libxmu6 libxpm4 libxrandr2 libxrender1 libxshmfence1 libxt6 libxtst6 libxv1 libxxf86dga1 libxxf86vm1
  x11-common x11-utils xbitmaps
Suggested packages:
  lm-sensors mesa-utils xfonts-cyrillic
  x11-common x11-utils xbitmaps xterm
0 upgraded, 49 newly installed, 0 to remove and 0 not upgraded.
Inst xterm (344-1+deb10u1 Raspbian:stable [armhf])
Conf xterm (344-1+deb10u1 Raspbian:stable [armhf])
red trev
Thu Jun 17, 2021 7:30 am
thank you for all your help, much appreciated ! It actually fixed on its own in a weird way ...
I thought SSH might be interfering so went to check it was off via Raspi-Config, when i clicked that menu option the below happened automatically:
I was then able to install Xorg no problem via cmd line.
thatchunkylad198966
Thu Jun 17, 2021 1:37 pm
Oh, all you needed was "sudo apt update" good to know for next time. :)
[NEW] Ubuntu - CM4/RPi4B custom image(s)! XFCE4, LXQt, i3-WM, WireGuard, Samba, Kodi, Latest MESA graphics drivers!
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
Return to “Raspberry Pi OS”
