spycatcher
sudo question
Sat Jun 12, 2021 8:49 am
Hi guys, i'm a complete newbie to sudo. My problem is when i run the command "sudo iwlist wlan0 scan" to list the wi fi hosts within range of my wireless raspberry pi. The list shoots up the screen before i can see them. In DOS i would use the more command to show one screen at a time. What is the equivalent command in sudo. Thanks
markkuk
Re: sudo question
Sat Jun 12, 2021 11:05 am
The "more" command was copied to DOS from Unix and it's also available in LInux. Using "more" to page command output has nothing to do with sudo.
kerry_s
Re: sudo question
Sat Jun 12, 2021 2:43 pm
sudo iwlist wlan0 scan | less
andrum99
Re: sudo question
Sat Jun 12, 2021 4:45 pm
No it wasn't. DOS's CLI was a clone of CP/M, which was loosely modelled on Unix.
swampdog
Re: sudo question
Sat Jun 12, 2021 8:07 pm
'sudo' invokes a command as the root user so (like here with 'iwlist') only use it if you have to.
You can redirect the output to a file if you like:
foo@pi21:~ $ sudo iwlist wlan0 scan > ~/z
..then fiddle with it later..
foo@pi21:~ $ cat z | egrep "(Address|Frequency|Quality|ESSID)(:|=)"
          Cell 01 - Address: C8:3A:35:F4:97:40
                    Frequency:2.437 GHz (Channel 6)
                    Quality=70/70  Signal level=-26 dBm
                    ESSID:"eek"
          Cell 02 - Address: 48:5A:B6:6A:DD:89
                    Quality=26/70  Signal level=-84 dBm
                    ESSID:"HP-Print-89-LaserJet 200 color"
          Cell 03 - Address: 10:C6:1F:F5:0D:FC
                    Frequency:2.412 GHz (Channel 1)
                    Quality=34/70  Signal level=-76 dBm
                    ESSID:"BTHub3-GGZ2"
          Cell 04 - Address: 42:C6:1F:F5:0D:FD
                    Quality=35/70  Signal level=-75 dBm
                    ESSID:"BTWi-fi"
          Cell 05 - Address: E8:DE:27:E9:83:EA
                    Quality=46/70  Signal level=-64 dBm
                    ESSID:"ook!"
          Cell 06 - Address: E4:57:40:44:88:5C
                    Frequency:2.462 GHz (Channel 11)
                    Quality=50/70  Signal level=-60 dBm
                    ESSID:"VM7506420"
          Cell 07 - Address: FA:8F:CA:7D:E9:37
                    ESSID:"Bedroom TV.b"
..and when you've got it working, do it all in one line..
foo@pi21:~ $ sudo iwlist wlan0 scan | egrep "(Address|Frequency|Quality|ESSID)(:|=)"
                    Quality=70/70  Signal level=-24 dBm
                    ESSID:"eek"
                    Quality=25/70  Signal level=-85 dBm
                    Quality=36/70  Signal level=-74 dBm
                    ESSID:"BTHub3-GGZ2"
                    Quality=33/70  Signal level=-77 dBm
                    ESSID:"BTWi-fi"
                    ESSID:"ook!"
                    ESSID:"VM7506420"
          Cell 07 - Address: 48:D2:4F:0A:2E:41
                    Quality=22/70  Signal level=-88 dBm
                    ESSID:"TALKTALK0A2E44"
The ">" denotes file redirection whereas "|" denotes a pipe. The former redirects output into a file(*) whereas the latter sends it to the input of the next program. You'll note that the file "z" isn't owned by root (because 'sudo' only ran 'iwlist' as root).
(*) slightly more complex than that. There's two output streams, one for normal (stdout) and one for errors (stderr) but that's for another time.
This kind of thing often goes nicely in a custom script..
foo@pi21:~ $ cd;mkdir -p bin && cd bin && touch z-scan && chmod u+x z-scan
foo@pi21:~/bin $ cat z-scan
#!/bin/bash
Now you can run it when you want and you've buried 'sudo' (it'll still prompt if it needs to).
Hmm. That went off at a tangent. ;-)
kerry_s
Re: sudo question
Sat Jun 12, 2021 9:50 pm
                    ESSID:"eek"
                    ESSID:"BTHub3-GGZ2"
                    ESSID:"BTWi-fi"
                    ESSID:"ook!"
                    ESSID:"VM7506420"
                    ESSID:"eek"
                    ESSID:"BTHub3-GGZ2"
                    ESSID:"BTWi-fi"
                    ESSID:"ook!"
                    ESSID:"VM7506420"
#!/bin/bash
:lol:
kinda overkill for the question
Return to “Raspberry Pi OS”
