SysGhost
fstrim SystemD service and timer
Thu Jun 10, 2021 10:46 am
I've noticed that the fstrim command (binary) is included in the OS image, but the fstrim.service and fstrim.timer files are missing in SystemD.
These files are usually found in the util-linux package. But not in the case here.
I took the liberty and created these files myself, and it works just fine with the already included fstrim command.
Here's a lil "how to":
Create a file named /etc/systemd/system/fstrim.service and put this in it:
[Unit]
Description=Discard unused blocks on filesystems from /etc/fstab
Documentation=man:fstrim(8)
ConditionVirtualization=!container
[Service]
Type=oneshot
ExecStart=/usr/sbin/fstrim -A
PrivateDevices=no
PrivateNetwork=yes
PrivateUsers=no
ProtectKernelTunables=yes
ProtectKernelModules=yes
ProtectControlGroups=yes
MemoryDenyWriteExecute=yes
SystemCallFilter=@default @file-system @basic-io @system-service
Create another file named /etc/systemd/system/fstrim.timer and put this in it:
[Unit]
Description=Discard unused blocks once a week
[Timer]
OnCalendar=weekly
AccuracySec=1h
Persistent=true
RandomizedDelaySec=6000
[Install]
WantedBy=timers.target
Then enable the timer unit:
sudo systemctl enable fstrim.timer
Now you're good to go. All your trim-capable volumes will be trimmed once a week.
Suggestions, alternatives and such are welcome.
RonR
Re: fstrim SystemD service and timer
Thu Jun 10, 2021 6:13 pm
They're already included in Raspberry Pi OS images:
/usr/lib/systemd/system/fstrim.service
/usr/lib/systemd/system/fstrim.timer
All that's needed is to create an /etc/udev/rules.d/ssd-trim.rules file:
lsusb
Bus 002 Device 004: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
ACTION=="add|change", ATTRS{idVendor}=="174c", ATTRS{idProduct}=="55aa", SUBSYSTEM=="scsi_disk", ATTR{provisioning_mode}="unmap"
And then run:
systemctl enable fstrim.timer && reboot
SysGhost
Fri Jun 11, 2021 7:56 am
Those were missing completely for me. Which package provides those files?
EDIT:
I reinstalled util-linux, and the two missing files are now present.
RonR
Fri Jun 11, 2021 8:08 am
They come installed in the Raspberry Pi OS image files. You'd have to ask the Raspberry Pi OS developers where they got them.
Return to “Raspberry Pi OS”
