Milliways
ping suid permission
Tue May 11, 2021 12:00 am
I was working on some scripts and ping was failing with error:-
ping: socket: Operation not permitted
I checked the permissions and found
-rwxr-xr-x 1 root root 55720 2020-01-14 10:29 /bin/ping*
I am sure it used to work and I can't recall changing anything.
On older OS ping had suid permissions - has there been any change, and if so why?
cleverca22
Re: ping suid permission
Tue May 11, 2021 12:12 am
root@pi400:~# stat /bin/ping
  File: /bin/ping
  Size: 55720           Blocks: 112        IO Block: 4096   regular file
Device: b302h/45826d    Inode: 3090        Links: 1
Access: (4755/-rwsr-xr-x)  Uid: (    0/    root)   Gid: (    0/    root)
Access: 2020-12-02 09:02:04.073953738 -0400
Modify: 2020-01-13 19:29:01.000000000 -0400
Change: 2020-12-02 09:02:04.073953738 -0400
 Birth: -
it probably still needs to be 4755, maybe you ran a chmod 755 /bin/* at some point?
jojopi
Tue May 11, 2021 12:40 am
Modern distros use capabilities instead of setuid.
pi@tau:~ $ getcap /bin/ping
/bin/ping = cap_net_raw+ep
Did you install or copy the root filesystem in an unusual way, that could cause the capability to be omitted?
cleverca22
Tue May 11, 2021 1:15 am
ah, ive got a ~7 year old install i think, so my apt hasnt migrated things to the new style
MiscBits
Tue May 11, 2021 3:41 am
So it's not only me viewtopic.php?f=28&t=311300
My install though was only a couple of months old...
Is a computer language with goto's totally Wirth-less?
Milliways
SOLVED: ping suid permission
Tue May 11, 2021 7:55 am
I "fixed" the problem (which was in both my Raspberry Pi OS & Lite installations) with
apt reinstall inetutils-ping
The cause remains unclear.
MiscBits
Tue May 11, 2021 11:39 am
Oddly enough its only happened on one of my boxes here.
Not sure if it was an update or package install - the dev box that got 'hit' gets backed up / restored and hacked about and had a few 'comms' related packages on recently as I'm coding MQTT / Telnet / and web scraping bits.
Like you, a re-install fixed it.
Return to “Raspberry Pi OS”
