apple2europe
Re: [Guide] Kodi on Raspberry Pi OS / Raspbian Buster
Wed Apr 07, 2021 10:55 am
I have a Rasperry Pi 4 with the latest OS and updates (just did an apt update & upgrade). Some time ago I have installed Kodi on it using this tutorial https://www.makeuseof.com/tag/install-k ... ia-center/
But I have never been able to run it. When I try to launch Kodi from RaspberryPi OS, nothing happens.
Wed Apr 07, 2021 11:01 am
The tutorial you linked to is for Raspbian Stretch which is out of date:
sudo apt update
sudo apt install kodi
As per the first post :?
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
apple2europe
Wed Apr 07, 2021 11:20 am
Yes I was able to make it work by following the first post and enabling the KMS video driver.
I have Kodi 18.7 now.. How do I update it to the latest v19? It looks like Kodi is not updated automatically when I do apt update and apt upgrade. Maybe v19 wasn't yet released for the Pi?
Do you know how to fix VNC? Basically when I launch Kodi the default VNC of Raspberry OS stops working. If I reconnect the screen is black. Should I enable Kodi's VNC but in that case won't it interfere with the RaspberryPi OS VNC?
Wed Apr 07, 2021 11:26 am
Kodi 19 has not *yet* been compiled for Raspberry Pi Operating System due to many issues, if you read back over the last couple of months of posts this subject has been discussed, there is no requirement to regurgitate.
Regards VNC see:
viewtopic.php?f=66&t=251645&start=450#p1806381
xoocoon
Wed Apr 07, 2021 6:00 pm
I also had the problem of Raspi 4B / Kodi 18.7 not playing HEVC videos any more after a kernel update to 5.10. However I could solve it.
To be more precise, the Raspi was still able to hardware-decode all my UHD HEVC videos after the 5.10 kernel update, but only at a standard HD resolution of 1920x1080p@60Hz. Whenever I changed the playback resolution to 3840x2160@30Hz in Kodi, it used to crash and restart itself. (I am using kodi-standalone wrapped by a systemd service unit.) The resolution switch to UHD used to work perfectly before the recent kernel update.
After I had carefully worked through the posts in this thread, I found the following solution which works for me:
In config.txt, I removed the line
gpu_mem=384
... and altered the graphics overlay line so that it reads
dtoverlay=vc4-fkms-v3d,cma-384
Hope this helps somebody.
whateva
Thu Apr 22, 2021 6:58 am
This maybe a silly question but do kodi require desktop to run?
I have this what would I call headless setup with running samba, sabnzbd, sonarr, docket etc so I decided to check how kodi run is it better than my old android TV box.
So I've install kodi as first post but when I run kodi or kodi-standalone screen goes blank and nothing happens.
Doesn't matter which driver I choose in rasp-config, GPU memory is set for 448 all the groups are set as suggested.
I can't seem to find the proper log to check what's going on.
Any ideas?
Forgot to add raspberry pi 4
Rascas
Thu Apr 22, 2021 12:57 pm
Any ideas?
You don't need a desktop environment to run Kodi. If you have problems read the first post carefully, it also has instructions on how to get the kodi log.
whateva
Fri Apr 23, 2021 8:00 am
Thanks, I have found it.
Can someone please look into this log?
Thank You
https://paste.ubuntu.com/p/9hCzBW4p6Q/
So I found something like
 CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
And also
viewtopic.php?t=250854
I'm going to install kodi from that post and see what will happen
https://paste.ubuntu.com/p/pWHWGVs3qB/
Not working
Rascas
Fri Apr 23, 2021 6:33 pm
You are using a different user than the default "pi", that's probably your problem, you have to add some groups to that user, see fisrt post to how to do it. You have to restart at the end. If it still doesn't work, try with user "pi".
whateva
Fri Apr 23, 2021 6:54 pm
 sudo usermod -a -G audio,video,input,dialout,plugdev,netdev,users,cdrom,tty "username"
Already done, i did everything in first post except start on boot.
Can't check pi user,it doesn't exist anymore since I look at it as security risk to have it in system.
Rascas
Fri Apr 23, 2021 6:57 pm
Can you start kodi as root ? If so, it is a permissions problem with your current user.
whateva
Fri Apr 23, 2021 7:04 pm
 Sudo kodi
Gives the same effect.
black screen.
https://paste.ubuntu.com/p/3qhfzTNGN6/
Rascas
Fri Apr 23, 2021 7:14 pm
 Sudo kodi
black screen.
Are you trying to open Kodi remotely ? It doesn't work on VNC/RDP and that kind of stuff. It only works on a TV connected to the Pi.
whateva
Fri Apr 23, 2021 7:17 pm
 Sudo kodi
black screen.
Of course is connected to TV
https://ibb.co/nCTgk0D
I've just executed once again this
  sudo usermod -a -G audio,video,input,dialout,plugdev,netdev,users,cdrom,tty whateva]
Rebooted hit kodi-standalone and received something new.
 segmentation fault (core dumped)
 Crash report avail....
 Invalid argument
https://paste.ubuntu.com/p/KkghD6272K/
Windsaw
Sat Apr 24, 2021 1:21 pm
I installed Kodi on my fresh Raspbian installation.
In order to start it I used the kodi.service from the beginning of this thread.
Kodi starts up like expected.
But I have one problem: Pulse is not available as a sound choice.
If I log in as user "pi" and start kodi-standalone manually, that choice is available and works without problems.
I need pulseaudio. I can't go back to alsa since I have multiple applications with sound running which would block each other if I do.
How can I get it to work?
Edit: I managed to resolve my issue by installing PulseAudio as a service.
max11
Sat May 01, 2021 6:08 pm
Hi Rascas,
sometimes ago i complained about crackling sounds on Kodi/Bluetooth ....
Finally i found the solution: changing in Sytem/Audio/Channels from 2.0 to 5.1 channels (even if it is only one speaker) ... and the crackle is gone.
Maybe it helps others too.
Lipown
Thu May 06, 2021 4:28 pm
I just bought airmouse and the pointer in Kodi freezes for 20 sec, meanwhile you can see that your movement is invisibly happending because the menu items are being highlighted, then the pointer shows on different direction and after some secs freezes again. It is doing the same think with normal mouse. Any suggestions for fix pls?
Khyinn
Mon May 17, 2021 7:13 am
Hi :)
Any news now that Kodi 19.1 is out ?
mattrix
Wed May 26, 2021 3:13 am
Hi Rascas,
I see you maintain the kodi package for ARM debian.
You may be interested in upcoming Widevine blob changes that will break playback on ARM (probably in 5-6 days from now)
You can read here:
https://github.com/raspberrypi/Raspberr ... -838118259
& here
https://github.com/xbmc/inputstream.adaptive/issues/678
Thanks,
Matt
www.matthuisman.nz
Rascas
Wed May 26, 2021 9:26 am
Hi Rascas,
You can read here:
& here
Thanks,
Matt
Thanks for the advice. So if I understood currectly, I need a new version of glibc to recompile Kodi and kodi-inpustream-adaptive also needs to be updated then. Is the new/patched glibc already available on stable repo?
ShiftPlusOne
Wed May 26, 2021 12:32 pm
Rascas wrote: Thanks for the advice. So if I understood currectly, I need a new version of glibc to recompile Kodi and kodi-inpustream-adaptive also needs to be updated then. Is the new/patched glibc already available on stable repo?
I'm a bit uneasy with patching glibc system-wide with changes that aren't upstream. You can see what I've done for chromium here: http://archive.raspberrypi.org/debian/p ... _armhf.deb
It includes the patched libc6 files and then uses patchelf to force chromium to use use the new interpreter.
Edit: but you should be able to pass the right flag to set the patched loader while building without having to use patchelf.
Rascas
Wed May 26, 2021 1:31 pm
I don't believe cmake cpack deb supports that. That is too complicated to implement in Kodi packages, which is already heavily patched. Does gcc/glibc from Bullseye work ?
ShiftPlusOne
Wed May 26, 2021 2:26 pm
No, the patches google added are only used in ChromeOS, AFAIK.
Rascas
Wed May 26, 2021 2:53 pm
So, there is no plans for you to remove the old Debian patches and include the new one needed for glibc ?
Only way is to compile glibc with that patches, include it in Kodi packages and link Kodi to use it instead of the system wide one?
ShiftPlusOne
Wed May 26, 2021 3:34 pm
I'm not sure. I wouldn't 100% rule it out, but changing a package which the rest of the system depends on feels a bit risky and then we'd be taking on responsibility for security updates rather than letting them flow in from Debian automatically.
My understanding is that the risk is actually minimal, since it's only adding support for a new section rather than changing any existing behaviour. Official glibc may add a new section which disagrees with the patches, but such changes are unlikely to be unexpectedly introduced in a 'stable' release.
Something to think about. I could put an appropriately patched version in the 'untested' component in the meanwhile.
Return to “Raspberry Pi OS”
