Bmavinga300
Problems with systemd
Thu Apr 15, 2021 1:13 pm
So I was trying to create a .service file in my systemd to auto start a dual channel packet forwarder file.
I rebooted the system and nothing seemed to have happened, After trying for some time i decided to delete the file altogether and
continue on with the project without doing a auto-start.
I tried to run my gateway manually as you can see below but it wouldnt fully run. Its supposed to connect to the TTN servers but it doesnt anymore :( and i didn't know what to make of it.
pi@raspberrypi-B:~ $ cd dual_chan_pkt_fwd
pi@raspberrypi-B:~/dual_chan_pkt_fwd $ sudo ./dual_chan_pkt_fwd
server: .address = router.eu.staging.thethings.network; .port = 1700; .enable = 1
server: .address = router.eu.thethings.network; .port = 1700; .enable = 0
Gateway Configuration
your name (a@b.c)
Dual channel pkt forwarder
Latitude=0.00000000
Longitude=0.00000000
Altitude=10
Interface: eth0
Trying to detect module CE0 with NSS=6 DIO0=7 Reset=0 Led1=unused
Transceiver version 0x00
Unrecognized transceiver: Success
I did a systemctl status dual_chan_pkt_fwd.service and i got the output below.
pi@raspberrypi-B:~ $ systemctl status dual_chan_pkt_fwd
● dual_chan_pkt_fwd.service - Lora Packet Forwarder
Loaded: loaded (/lib/systemd/system/dual_chan_pkt_fwd.service; enabled; vendo
Active: activating (auto-restart) (Result: exit-code) since Thu 2021-04-15 13
Process: 1033 ExecStart=/home/pi/dual_chan_pkt_fwd/dual_chan_pkt_fwd (code=exi
Main PID: 1033 (code=exited, status=1/FAILURE)
Apr 15 13:59:18 raspberrypi-B systemd[1]: dual_chan_pkt_fwd.service: Main proc
Apr 15 13:59:18 raspberrypi-B systemd[1]: dual_chan_pkt_fwd.service: Failed wi
lines 1-8/8 (END)...skipping...
Loaded: loaded (/lib/systemd/system/dual_chan_pkt_fwd.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Thu 2021-04-15 13:59:18 IST; 1s ago
Process: 1033 ExecStart=/home/pi/dual_chan_pkt_fwd/dual_chan_pkt_fwd (code=exited, status=1/FAILURE)
Apr 15 13:59:18 raspberrypi-B systemd[1]: dual_chan_pkt_fwd.service: Main process exited, code=exite
Apr 15 13:59:18 raspberrypi-B systemd[1]: dual_chan_pkt_fwd.service: Failed with result 'exit-code'.
I then deleted the .service file with the command sudo rm /lib/systemd/system/dual_chan_pkt_fwd.service
sudo systemctl daemon-reload
The service file was gone and I uninstalled the gateway file then reinstalled it again but it hasn't worked ever since and I don't know why! Maybe I messed around too much with systemd and ruined the whole thing? I don't know I'm very new to this.
If you know why my gateway isn't working please let me know :) and I also want to know if systemd resides in the pi device or is it in the SD card because i have ordered a new SD card to install OS onto it to try fix this issue. Please let me know your thoughts on this also.
deepo
Re: Problems with systemd
Thu Apr 15, 2021 1:30 pm
A service file needs to be enabled and started before your service works again.
What happens when you do this again, after putting the service file back in place?
If the service is disabled then:
pi@raspberrypi-B:~ $ sudo systemctl enable dual_chan_pkt_fwd
pi@raspberrypi-B:~ $ sudo systemctl start dual_chan_pkt_fwd
Then your service should run - check again with:
bls
Thu Apr 15, 2021 1:46 pm
In general, you should put .service files that you create into /etc/systemd/system, rather than /lib/systemd/system, which is typically used for packages that are installed by the system.
systemd searches for .service files first in /etc/systemd/system, then in /lib/systemd/system. One nice feature of this is that you can copy the system-provided .service file into /etc/systemd/system, modify it, and it will be used instead of the one in /lib/systemd/system, should you need to do so.
systemd comes with RasPiOS (and virtually all Linux distros). It's not part of the hardware.
I've found that the best way to get a program running with systemd is to
  • build a script in /usr/local/bin that starts whatever it is you want to run
  • Get that script working on the command line with 'sudo /usr/local/bin/myscript'
  • Start the script in your .service file in /etc/systemd/system
Depending on what your program does, you may need to futz around with the .service file to properly stop the service when you issue a 'sudo systemctl stop myservice' command. Once start and stop are working, you can enable the service to start automatically with 'sudo systemctl enable myservice'
Pi tools:
Quickly and easily build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Easily run your network's DHCP/DNS on a Pi: https://github.com/gitbls/ndm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
cbad536
Mon Apr 19, 2021 5:43 pm
Hi Team, I'm having a slightly similar problem,
I'm trying to use systemd and systemctl to automatically open a webpage, my Grafana dashboard.
  GNU nano 3.2                               /etc/systemd/system/showgrafana.service
[Unit]
showgrafana
[Sevice]
ExecStart=chromium-browser -display 192.168.1.43:3000
When I try to run with systemctl, I get:
pi@Pimonitor:~ $ systemctl enable --now showgrafana.service
Failed to enable unit: File showgrafana.service: Invalid argument
I feel like I'm superclose...
CB
Mon Apr 19, 2021 5:58 pm
Try using
--display 192.168.1.43:3000
with two dashes not one.
bls
Mon Apr 19, 2021 6:32 pm
Also, your [Unit] section is wrong. "showgrafana" is not a valid systemd option. Have a look at some of the other *.service files in /lib/systemd/system for examples. Google/Bing/whatever for systemd.service for the details.
Pi tools:
cbad536
Mon Apr 19, 2021 6:53 pm
Ahh, that did something. I added 'description=' before show grafana. Now systemctl has a whole bunch more complaints about missing parameters. I'll look around the other .service files, see if I can cut and paste my way into success.
Return to “Raspberry Pi OS”
