mob-i-l
Contact: Website Facebook Twitter YouTube
YouTube videos in Chromium sound like a cracked speaker
Fri Apr 16, 2021 10:52 am
Playing YouTube videos in Chromium sound like a cracked speaker, but sound good in Vivaldi browser on exactly the same system. I use the most full-upgraded Raspberry Pi OS Buster on Raspberry Pi 4 B 8GB and AV Jack and 256 MB GPU Memory. This cracked sound becomes less if I lower the video quality, but then it gets blurry. I didn't have this problem before. It started a few weeks ago after a big update. I have of course rebooted the machine before tests and do not have libwidevinecdm0 installed. I had libwidevinecdm0 installed before, but that didn't help with the cracked speaker sound in Chromium. I don't have the sound issue in VLC.
Example video, but this cracked speaker sound in Chromium applies to almost all videos, but never in Vivaldi:
https://www.youtube.com/watch?v=nlI_5vxm3bk (13 min, 720p)
Have Pi0&1A&1B&1B+&2B&3B&4B w/ rasPiOS. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
dom
Re: YouTube videos in Chromium sound like a cracked speaker
Fri Apr 16, 2021 10:58 am
Do you get same behaviour with hdmi output?
Can you try with audio_pwm_mode=1 in config.txt?
mob-i-l
Fri Apr 16, 2021 12:38 pm
I don't have a female HDMI sound input - my screens are DVI-D with HDMI to DVI-D adapters. (I have two screens.) I have an HDMI to VGA adapter with 3.5 mm stereo out, but I can't use that since it has male HDMI and I have no male microHDMI to female HDMI adapter. I could of course go out and buy an adapter, but they cost 160 SEK = 13 £(GBP) at my most local store.
audio_pwm_mode=1
made the cracking noise less, but introduced more background noise and noise in pauses on YouTube.
Some other settings I have in config.txt:
dtoverlay=vc4-fkms-v3d
gpu_mem=256
arm_64bit=1
start_x=0
enable_uart=1
gpu_freq=250
number698
Fri Apr 16, 2021 8:37 pm
pulse related ?
i would make/use my backup sd card and purge pulse, reboot and then test sound quality with alsa, then reinstall pulse.
pidd
Fri Apr 16, 2021 9:33 pm
This has been happening ever since the update to Chromium v88/v89, the old v86 worked fine.
mob-i-l
Sat Apr 17, 2021 10:09 pm
Thanks for the confirmation that I'm not the only one with this problem. Do you get sound via AV Jack or HDMI?
pidd
Sun Apr 18, 2021 1:12 am
The AV Jack, I've seen a few people report this sporadically since the update but I can only presume the majority of people don't have the same problem?
Switching off hardware acceleration in Chromium helps a little bit but perhaps that is because it ends up slower and drops a resolution. Even at 480p you can hear the clicking/clipping occasionally if you listen carefully for it.
I completely removed Chromium and all its settings and re-installed but that didn't help.
I keep on meaning to install the RPiOS from scratch but there are so many bits and pieces I added to this one, its my main desktop which interfaces to everything else and has all my music and programming stuff on it.
talraash
Sun Apr 18, 2021 9:44 pm
Same problem more that month since v88 chromium update... viewtopic.php?f=28&t=306919 output via bluetooth without cracking, 3.5 with noise when video res more that 480p
Don't help
Return to “Raspberry Pi OS”
