mgrouch
How to set language, wifi country, locale, timezone on OS image before first boot?
Tue Apr 13, 2021 5:00 pm
How can I set language, wifi country, locale, timezone on OS image before first boot?
klricks
Re: How to set language, wifi country, locale, timezone on OS image before first boot?
Tue Apr 13, 2021 5:13 pm
Many settings can be done pre boot with the advanced menu of the RPi Imager: https://www.raspberrypi.org/blog/raspbe ... e-to-v1-6/
bls
Tue Apr 13, 2021 6:04 pm
As @klricks mentioned, the RPi imager can set many of these when writing the SD card.
Another alternative, for the CLI-minded, is https://github.com/gitbls/sdm, which enables you to do all that and more.
Pi tools:
Quickly and easily build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Easily run your network's DHCP/DNS on a Pi: https://github.com/gitbls/ndm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
thagrol
Tue Apr 13, 2021 7:02 pm
For serious command line geeks, mount the image via a loop device then edit the config files in there directly or, maybe, chroot into it and run the usual tools though I've not tried that.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
Jim Danner
Tue Apr 13, 2021 7:56 pm
Another alternative approach is putting a script on the /boot partition of the SD card, so you don't need the tools to mount the system (root) partition. I put it on GitLab as pi-boot-script. See also this post.
alphanumeric
Wed Apr 14, 2021 8:43 am
With V1.6 of the official imager, launch it and press Ctrl + shift + X. That will get you options to Enable SSH, set the Hostname, configure WIFI, set Locale settings, skip the first run wizard, etc.
Return to “Raspberry Pi OS”
