Moreno
[Raspberry_PI4] Shutdown
Fri Sep 18, 2020 2:25 pm
I have a question, how can I do for re-activate the older method for shutdown the PI.
Now when i enter "shutdown now" (SSH) command the pi dont stop, need press the power button.
Before when enter shutdown the pi was turned off in a few moments.
i have seen this ( https://www.raspberrypi.org/documentati ... _config.md ) but i dont know if its the good files, and when i can re-activate this function.
Can you help me step by step?
Thanks for your help.
Regards.
epoch1970
Re: [Raspberry_PI4] Shutdown
Sat Sep 19, 2020 11:32 am
Which OS are you running?
Desktop or Lite?
andrum99
Sat Sep 19, 2020 4:10 pm
Regards.
The Raspberry Pi does not have a power button. You must be using a case or other device which has one. It sounds like whatever handles the button press is no longer working.
Return to “Raspberry Pi OS”
