NimbUx
[SOLVED] Control terminal window from Bash command line ?
Sun Aug 09, 2020 5:21 pm
Under RaspiOS+LXDE+Terminal+Bash : do we have a command (Bash-internal or otherwise) to minimise/iconify the current terminal window ?
Similarly command lines that would maximise, (un)roll, restore the terminal window? Or even move/size/position the window at set coordinates (x,y) and size (W,H) ?
Thanks...
trejan
Re: Control terminal window from Bash command line ?
Sun Aug 09, 2020 5:22 pm
xdotool will do what you want.
scruss
Sun Aug 09, 2020 5:58 pm
as will wmctrl.
Note that lxterminal doesn't seem to like console-resize escape sequences.
Pronouns: he/him
NimbUx
Sun Aug 09, 2020 8:46 pm
Thank both of you guys, appreciate the replies ! I just apt-get install'd xdotool and seems to do all I wanted (and more, indeed).
@Scruss: ...well, maybe not for the resizing and moving thing; fortunately I mentionned them for completeness sake mainly, my actual need currently is to minimise the lxterm, from commandline; following code does it right :
$ xdotool getactivewindow windowminimize --sync
Return to “Raspberry Pi OS”
