cjan
update issue
Tue Nov 05, 2019 9:38 pm
Pi2 update, why does it need rpi-eeprom packages?
dangerous or no harm?
Re: update issue
Tue Nov 05, 2019 9:45 pm
Harmless. They will do nothing on a Pi 2. The packages are pulled in because the Pi 2 uses the same software as the Pi 4. The package manager can't tell them apart.
cjan
Re: update issue
Fri Nov 08, 2019 10:32 pm
another issue,
had blacklist rtl8192cu module, after update it been unmarked.
cause wifi speed slow down a lot, anyone beware this issue.
ps. Pi2 & EW-7811Un
trejan
Re: update issue
Fri Nov 08, 2019 10:41 pm
You need to add a comment to https://github.com/RPi-Distro/raspberry ... /issues/37 about this issue.
cjan
Re: update issue
Fri Nov 08, 2019 10:44 pm
but don't know which update package caused.
trejan
Re: update issue
Fri Nov 08, 2019 11:06 pm
It was a change the other day in https://github.com/RPi-Distro/raspberry ... 155430ca17 The linked issue is where it was briefly discussed.
cjan
Re: update issue
Sat Nov 09, 2019 1:27 am
EW-7811Un need 8192cu module from 1st Pi released.
there are 3 modules 8192cu rtl8192cu rtl8xxxu for different chip, why they do that?
timg236
Re: update issue
Sat Nov 09, 2019 11:45 am
Raspbian is designed so that a single image works on all Raspberry Pi models. Any software with specific hardware requirements checks the board-revision / CPU version before running.
Re: update issue
Sat Nov 09, 2019 12:03 pm
I've masked the service you've installed on all of my Raspberries (it would only be a pointless delay in systemd otherwise). It's a shame you couldn't have a post-install script to detect the machine type and do that automagically on anything that isn't a RPi4B (or later).
This is a doctor free zone.
Return to “Raspbian”
