rtfmoz
Security: The boot process
Tue Oct 08, 2019 11:43 pm
If these devices get used for point solutions across an enterprise the security of the device has to be assessed. So with a security hat on I have a few questions regarding the Raspberry Pi4...
When Rasbian boots on the Pi4 are there any checks to validate the boot EEPROM just used is foundation issued? To be clear, I'm simply asking if such checks exist.
If the answer to the above is no. Can such checks be implemented, eg can a hardened Rasbian with a specific EEPROM perform such checks in a way that would assert the security of the boot process?
Please understand im not here discussing a specific use case, just the security posture of the device, whether it can be made more secure and how one might achieve it. Application security is an entirely different discussion. If there are existing discussions that may answer some of these questions please refer me to them.
I note in the documentation it says "It is possible to physically write-protect both EEPROMs via a simple resistor change." then refers to schematics. I was unable to determine where this is in the schematics -- issue #1302 raised for his
Re: Security: The boot process
Wed Oct 09, 2019 6:16 am
What is a "point solution across an enterprise"?
One should assume the Pi has zero security once deployed out in the field and people have physical access to it.
Otherwise it's as secure as you make it, which depends on what network services you run on it and how they are configured, like any Linux system.
openoms
Wed Oct 09, 2019 7:19 am
What would be the best way to verify the contents of this EEPROM?
Also the documentation states:
Note that if a bootcode.bin is present in the boot partition of the SD card in a Pi 4, it is ignored.
Is the check for the bootcode.bin on the SDcard governed by the code on the EEPROM or is it completely ignored (the RPi4 would boot even with an erased EEPROM)?
Wed Oct 09, 2019 9:08 am
The Pi4 bootloader doesn't even look for a bootcode.bin, it just runs the bootcode from the EEPROM.
As for the security, there are options here that I am not able to talk about at this stage.
What I can say:
You cannot brick a Pi4 i.e. you can ALWAYS return a Pi to a safe state by using a good recovery.bin on an SD card and booting. This is also a way of ensuring you are not using a hacked EEPROM.
In order to hack the EEPROM in the first place, you WILL need root access. At which point all bets are off anyway.
Wed Oct 09, 2019 4:51 pm
Or physical access to swap the boot device (currently only an SDCard).
It always worries me when these security folks come asking & inferring that the RPi is insecure. They seem to forget that a laptop is only as secure as the screws in the case that stop you swapping out the hard disk. BIOS security can make life difficult, but even a password protected hard drive carries the password on the media device.
Are you willing to reveal what processor runs the boot code? Is it run on the RPi 4's ARM8? Or is there still a proprietary "GPU" that runs it? If it's ARM8 then it is trivial to reverse engineer (as that is fully documented). If it still runs on some hidden Broadcom device that makes the bootcode more obscure (like the SDCard resident bootcode.bin & start.elf stuff on the older Raspberries).
This is a doctor free zone.
incognitum
Wed Oct 09, 2019 9:26 pm
That is not the case with modern storage.
E.g. Intel SSDs do full disk encryption if you set a drive password in the BIOS.
If an attacker has compromised a Pi, and his goal was to create a backdoor that he could continue to use even if the SD card was reinstalled, I can think of simpler ways then reverse engineering the bootcode.
E.g. he could change the EEPROM settings to enable netboot, and set TFTP_IP to a server under his control.
Netboot works over the Internet now.
rtfmoz
Wed Oct 09, 2019 11:44 pm
It is a standard question. You bring an inference by mentioning it. The Raspberry Pi is what it is, a tool designed to promote education in the electronics industry by enabling youth to take an interest. However, through the years, it has become more than just an educational tool. Solutions are being implemented on the platform because it is such a unique one providing access to a huge repository of open source work built over the last 30 years. As a result, it is quite likely all of you are running a server of some sort, usually application-specific performing a dedicated task, doing quite a good job at it too. These things filter from the personal use of professionals into business by the very nature of their usefulness and this is what brings on a security assessment. Nothing is implied, it is purely looking at it from a security looking glass and asking relevant questions.
rtfmoz
Wed Oct 09, 2019 11:53 pm
Thank you for your reply! Much appreciated.
The modified EEPROM would be done offsite if it were to happen. Is then a case of loading using tools in the operating system. The write-protection of the EEPROM is pretty much the solution to this. Is there a way for the OS to check if the EEPROM is write-protected?
To give people a better idea, the security scenario is a deployed device at a customer site performing some useful networking function. There is no physical access to the device, only network access.
openoms
Thu Oct 10, 2019 8:58 am
What I can say:
Thank you for your answer and for clarifying what does get ignored during boot. It is clear now that the bootloader on the EEPROM is used on RPi4 regardless of a bootcode.ini on the SDcard.
Is there a PGP signature and a SH256 hash provided for the bootloader image downloadable here: https://www.raspberrypi.org/downloads/ (just like there is for the Raspbian releases)?
Also could there be way to verify the contents of the EEPROM without reflashing? That would make a secure start of a new device easier and could possibly be automated.
Thu Oct 10, 2019 9:32 am
Good point, I'll try and get that added.
Not sure, will ask.
trejan
Thu Oct 10, 2019 9:59 am
You can dump the existing contents using flashrom after reconfiguring the GPIOs for access. There is a configuration block inside the bootcode which sets various options like power off on halt so you need to take that into account for your verification hash.
hippy
Thu Oct 10, 2019 12:21 pm
Take a look at '/usr/bin/rpi-eeprom-config' which is a Python program which shows how to read the Boot Eeprom .bin files and separate out the various parts.
That should prove useful for comparing a 'flashrom' saved .bin from actual Boot Eeprom against a reference 'bin file, calculating checksums of each while disregarding the configuration settings.
hippy
Thu Oct 10, 2019 12:40 pm
Not sure about the OS but it appears to be possible to access the Boot Eeprom from userland, query the write-protect pin status, which is what I presume is used to write-protect the chip even though it's not shown on the published schematics.
It seems to me that so long as someone can get a program onto a targeted Pi 4B and have it executed, with root access or not, that can erase, corrupt or reprogram the Boot Eeprom if not physically write-protected.
As noted in previous discussions I don't believe this could be put to much use beyond being a nuisance. It is just one part of a chain-load bootloader so that restricts what could be easily done to seriously compromise or back-door a system.
Others however disagree. And, if the Boot Eeprom could be configured to network boot from an outside server and succeed in that, I guess that would be a pretty simple way to do that.
Thu Oct 10, 2019 12:51 pm
The programming process requires root privileges.
hippy
Thu Oct 10, 2019 1:11 pm
I will agree; it requires root privileges. It's just that by default those are easy to get on a Pi.
One can silently gain root privileges from a Python program running on a Pi without root privileges and I would guess that's the same for any other programming languages. I happened to mention that in an earlier post elsewhere -
https://www.raspberrypi.org/forums/view ... 7#p1549765
I guess that if sudo were configured some other way than Raspbian has it by default that would affect things as noted in the subsequent reply to that post.
But, wthout having changed 'sudo' configuration, it seems to me that all the commands needed to read or write the Boot Eeprom can be called from a Python program simply by wrapping them in os.system() calls or similar with sudo specified-
https://www.raspberrypi.org/forums/view ... 0#p1502253
I will admit I haven't tried it because I don't have a Pi 4B to try it on.
Andyroo
Thu Oct 10, 2019 1:21 pm
Why would you use the default user? Surely in a secure system you would lock the OS down more than a training / educational computer and create a user with limited rights?
Thu Oct 10, 2019 1:30 pm
If someone hasn't locked down sudo or done even the most basic of security changes, then worrying about a corrupted/hacked EEPROM isn't going to be high on their list.
So I think for the purposes of this topic, it can be ignored.
Return to “Raspbian”
