Herbaldew
Problem Rebooting/Shutdown After Update
Fri Sep 14, 2018 5:11 pm
My rPi3B+ will no longer shutdown or reboot since the update a couple days ago. Power it off and on after it hangs and it restarts and runs fine.
I have restored from backups and started from scratch several times with the same results. I also have used two different SD cards and my SSD with the same results.
Through experimentation, it seems to be caused by removing Wolfram. I usually remove Wolfram and other stuff first thing before doing my initial update and installing the programs I want. I just did a full normal setup run from scratch without the entry to remove Wolfram and all was fine. I then removed Wolfram and I cannot reboot or shutdown again.
Let me know if I need to provide any documentation and how to do so.
Edit: I didn't say, but when I restore from my backups ( a couple weeks old if that), all is fine until I update.
HawaiianPi
Re: Problem Rebooting/Shutdown After Update
Fri Sep 14, 2018 8:40 pm
If you turned Bluetooth off, try it with Bluetooth on. Several forum members have reported shutdown kernel panics when Bluetooth is turned off with the latest kernel/firmware.
You can roll back to the last stable firmware from mid-August with this command.
sudo rpi-update 911147a3276beee09afc4237e1b7b964e61fb88a
Herbaldew
Fri Sep 14, 2018 9:02 pm
Ahh, I remember seeing "kernel panic" on the screen several times whilst testing.
My Bluetooth was off. Turned it back on and reboot/shutdown work as they should. I don't know what that has to do with Wolfram, but I don't hang when it's installed even with Bluetooth off.
Herbaldew
Fri Sep 14, 2018 9:25 pm
After running the rollback, update doesn't show anything available.
When a new kernel is released will it show up?
Nevermind ... just going to leave Bluetooth enabled until issue is resolved.
Return to “Raspbian”
