Re: Remote desktop (xrdp) on stretch: Some menu items do not work
Mon Apr 16, 2018 9:59 pm
jtmoderate876 wrote:
Sun Apr 15, 2018 11:58 pm
Feels like xrdp is no longer practical on rpi.
serious bummer.
What's wrong with using RealVNC?
This is a hippy & doctor free zone.
jtmoderate876
Sat Apr 21, 2018 10:02 pm
Continued bummer...
XRDP is still broken on 2018-04-18 release of stretch.
Still can't get past login.
jtmoderate876
Sun Apr 22, 2018 9:00 pm
Sorry for the delayed response @DougieLawson
It's just I use RDP to access everything else - servers and computers running locally, in Azure, AWS, my company cloud, and this use to work pretty perfectly (recently adding better mouse support and copy/paste).
But I guess I need to move to RealVNC for raspberry.
Thx.
jtmoderate876
Sun Apr 22, 2018 9:39 pm
GOT XRDP WORKING AGAIN with the help from another forum that mentioned enabling VNC for XRDP setups.
I've not had to do that previously - but it worked.
So to configure a new stretch install for XRDP:
#use raspi-config to enable VNC so XRDP will work (new step for 2018-04)
#attach to wifi network
sudo apt-get install xrdp
# to repair xrdp append '@xhost si:localuser:root' to /home/pi/.config/lxsession/LXDE-pi/autostart othterwise sudo gui like
echo '@xhost si:localuser:root' | sudo tee -a /home/pi/.config/lxsession/LXDE-pi/autostart
sudo reboot # required
# and RDP using XRDP should work again
jtmoderate876
Mon Apr 23, 2018 12:59 pm
MORE PROBLEMS with XRDP:
If I change the password from the default (pi/raspberry) I can no longer XRDP.
Yet if I change the password back to raspberry I can XRDP.
This is repeatable - back and forth.
jtmoderate876
Mon Apr 23, 2018 1:11 pm
I gave up on XRDP and switched to RealVNC.
jtmoderate876
Sun Apr 29, 2018 1:23 am
I have to pare down my use of pi because of this lack of xrdp support, the time consuming process of realizing that, trying to fix XRDP, giving up and adapting to RealVNC.
I know "RealVNC is better" and XRDP is dead and all, but..
The different VNC installs, learning curve (can't get true full screen, graphics still dithered, workflow different than cloud RDP computers, etc.) ...
... are causing me to depart from this previously enjoyable raspberry pi platform.
I was using these for expanding my testing options and instances but it has become combersome and the cloud options, while probably a little more costly, are now preferable.
The work here is so neat but I started to pull it in for professional things and that isn't working out without RDP.
There are plenty of great things about PI but also plenty of learning curves and time sinks for someone coming from windows.
It's too bad that raspbian became incompatible with RDP.
You guys should review this issue.
Sun Apr 29, 2018 3:52 am
The xRDP package is the responsibility of the Debian Maintainers nothing to do with RPT / RPF, contact them if broken:
https://packages.debian.org/stretch/xrdp
adieu
My other Computer is an Asus CS10 ChromeBit running Chrome Operating System.
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Stretch.
loopyludo
Mon Apr 30, 2018 9:09 am
First off many thanks for everyone that has contributed to this post so far, it has been an education for me as I searched for an alternative to VNC.
jtmoderate876 may I suggest that you try the backport xrdp package. I have successfully just installed this and it has worked for me.
You will need to add the backports source first to /etc/apt/sources.list
deb http://ftp.debian.org/debian stretch-backports main
Then install the backport xrdp
sudo apt-get -t stretch-backports install xrdp
jtmoderate876
Mon Apr 30, 2018 3:22 pm
THANK YOU loopyludo ! THAT WORKED!
My exact steps were:
sudo leafpad /etc/apt/sources.list
# and add the following excluding #:
# deb http://ftp.debian.org/debian stretch-backports main
sudo apt-get update
# to repair xrdp  to allow elevated apps like rasperry configure, etc. append '@xhost si:localuser:root' to /home/pi/.config/lxsession/LXDE-pi/autostart othterwise sudo gui like
Can you briefly describe what that did?
Is a backport the version of XRDP for the "NEXT" release of debian - pulled forward into this current stretch release?
So that would mean someone has already fixed it for the future?
Last edited by jtmoderate876 on Mon May 14, 2018 1:15 pm, edited 2 times in total.
loopyludo
Mon Apr 30, 2018 3:51 pm
jtmoderate876 Glad that worked for you, to be fair I am not exactly sure what the backports are, I believe what has happened is that someone has recompiled the xrdp package from the next unstable release however using the current stable release libraries.
I do hope that would mean that it will work in the future releases.
jtmoderate876
Mon Apr 30, 2018 4:03 pm
Thanks again - wish I met you a couple weeks ago!
mohsenganj
Mon Oct 22, 2018 6:02 am
this may help you find a solution:
1. first, use the "Logout" Button from "Shutdown Options" Dialogue to logout
2. then Log in again
3. now yo can use Shutdown and Reboot Buttons
it is strange but working
mohsenganj
Mon Oct 22, 2018 8:48 am
it is NOT working for me
devenh
Tue Oct 23, 2018 1:05 am
As much as I'd like to get the Shutdown options dialog to work, I gave up trying and simply created these two scripts and placed them on my desktop:
shutdown.sh
#!/bin/bash
sudo shutdown -h now
reboot.sh
#!/bin/bash
sudo reboot
noobinpi
Sun Nov 04, 2018 10:00 pm
You can get the Buttons working, just change the line 'Logout=lxde-pi-shutdown-helper' to 'Logout=gksudo lxde-pi-shutdown-helper'
in '/home/pi/.config/lxpanel/LXDE-pi/config'.
noobinpi
Sun Nov 04, 2018 10:12 pm
Just change 'Logout=lxde-pi-shutdown-helper' in '/home/pi/.config/lxpanel/LXDE-pi/config' to 'Logout=gksudo lxde-pi-shutdown-helper' and all buttons are working.
tony_lock
Fri Nov 09, 2018 10:26 am
The reason why the shutdown doesn't work even after running as sudo is it seems to check who the real user is. The program actually running is lxde-pi-shutdown-helper, which is called via /home/pi/.config/lxpanel/LXDE-pi/config commenting out the Logout=lxde-pi-shutdown-helper in the config file produces a much more useful logout menu which prompts for a password on Shutdown and Reboot but does do it.
ejolson
Fri Nov 09, 2018 10:01 pm
Where I am xrdp is used to allow many people to simultaneously log into Linux running on a fairly well provisioned Xeon server from their Windows office computers. It would be a disaster if the shutdown menu actually worked. I suspect permissions for the menu options that shut the system down rely on which user currently owns the console. Since people logging in remotely don't have physical access, it makes sense that they not be allowed to reboot.
Because the old versions in the repositories don't work very well, I've always resorted to compiling xorg and xorgrdp from source. It appears to be good code that is surprisingly easy to compile. Using the version from backports sounds like a reasonable compromise between the old package in Raspbian and compiling the latest version yourself.
bctf1
Sun Dec 09, 2018 6:50 am
I am interested in this thread as a xrdp user on my 3B+ running stretch. The primary issue I have with xrdp is the lack of access to Preferences/Raspberry Pi Configuration. I have workarounds in place for most of the other menu options that require sudo permission during remote sessions.
I tried jagoliveira's suggestion from this thread where he said "In order to run 'Raspberry PI Configuration' tool and others that need 'sudo' to run in Remote GUI, I inserted X authorization of 'xhost' for 'root' in:
/home/pi/.config/lxsession/LXDE-pi/autostart --> Insert '@xhost si:localuser:root' as last line."
There was no file named autostart at this folder location (yes, I displayed hidden files) so I used nano to create it and then added the line '@xhost si:localuser:root' and saved the file. My 3B+ would not boot afterwards until I deleted the autostart file.
This fix worked for ktm_91 but did not for me. I have not tried adding the the backports source/backport xrdp install option. Additional suggestions would be appreciated.
mohsenganj
Mon Dec 10, 2018 5:42 am
Raspbian Stretch with desktop and recommended software
Version: November 2018
Release date: 2018-11-13
Kernel version: 4.14
New release of raspbian rtretch is available
did they fix this problem or not?
fbe
Mon Dec 10, 2018 11:23 am
gksudo rc_gui
bctf1
Mon Dec 10, 2018 6:39 pm
gksudo rc_gui
Thanks fbe for your suggestion but after using VNC over the last few days as my primary remote connection tool, I have decided that it works just as well or better than xrdp and it suffers from none of the sudo permissions problems. The only drawback I see so far with VNC is that it does not support audio from the Pi which I can live with. I will however continue to monitor this thread for further xrdp developments.
jtmoderate876
Sat Dec 15, 2018 1:10 pm
It seems that the 2018-11-13 release of raspbian has again messed up my xrdp workarounds.
The previous autostart file is gone at:
so this no longer works:
Once again, sadly, without xrdp.
spl23
Sat Dec 15, 2018 3:04 pm
Your autostart file is backed up in /home/pi/oldconf/.config/lxsession/LXDE-pi/autostart - just copy it back to where you had it before.
As explained in the blog post for this release, the intention was to try to get to the point where we didn't have to change user config in future when we were updating themes and the like, but to do that, we did need to do one final backup of user files.
Autostart suffered from some bizarre behaviour in lxsession - there is a local autostart file and a global one, where the local file overrules the global one if it exists. Unfortunately, the lxsession authors made the decision to copy the global file into the local location if there wasn't one there already, which means it is impossible for further changes in the global file to take effect. I've modified the relevant code to not do this any more, but in order to make sure most people did see future changes to the global file, it was necessary to remove the local one.
Return to “Raspbian”
