Bigcat123
Screenshot?
Fri Oct 05, 2012 6:08 am
Dear Raspbian developers,
What is the easiest way to get a screenshot of my Raspberry Pi? Do I have to SSH it? Does 'control + alt + print screen' work?
Thanks a million! ;)
Just a beginner sharing his experiences on his way to geek nirvana...
joan
Re: Screenshot?
Fri Oct 05, 2012 8:06 am
If you have X running on the Pi (the graphical user interface) you can use
DISPLAY=":0.0"; export DISPLAY; import -window root screenshot.png
from ssh or locally I assume.
import is part of the imagemagick suite.
If it's not on your Pi you'd need to
sudo apt-get install imagemagick
joan
Re: Screenshot?
Fri Oct 05, 2012 8:11 am
If you have a keyboard connected just press the print screen key (whatever that is on your keyboard). I run my Pi without keyboard so don't know if it works or not.
Bigcat123
Re: Screenshot?
Fri Oct 05, 2012 3:15 pm
Sorry but either of those DIDN'T work for me... Anyone know any other ways to get a screenshot of your Pi? Please Someone help me! Thanks for trying though Joan!
scruss
Re: Screenshot?
Fri Oct 05, 2012 3:27 pm
I use the distressingly-named utility 'scrot'. To get a shot of the active window, I use:
sleep 5; scrot -bu
The five second delay gives you a chance to get the window in order. It has options to take the whole screen (root window in X jargon).
If you're using a remote X session through ssh, use whatever screenshot program is on the host.
cyanarnofsky
Re: Screenshot?
Wed Jan 16, 2013 7:24 pm
So I have a modified version of screenly going, so a uzbl browser is running, is there a simple way like
that would capture that browser window? I have tried the above command but gives me a blank black image. I assume I need to direct it at the uzbl window but I am new to this, is there a way to make it grab the top most window or active window through a basic import command like that. This is a remote system and I want to be able to verify with a screenshot what is running on the screen, which this is perfect for if I can get it to see the browser. Thanks!
cyanarnofsky
Re: Screenshot?
Wed Jan 16, 2013 8:27 pm
found my answer, scrot is much better for terminal option, at least in my case.
anatak
Re: Screenshot?
Wed Aug 20, 2014 4:35 am
would you care to tell us your answer ?
blavery
Re: Screenshot?
Wed Aug 20, 2014 5:25 am
I simply installed gnome-screenshot in the pi.
I have vnc installed too (XIIVNC), and I often control the pi from a linux laptop. Then it is easy to take the pi screenshot directly on the laptop. (That uses gnome-screenshot on the laptop!)
B.
scruss
Re: Screenshot?
Mon Feb 27, 2017 2:04 pm
(tying up an old thread that still gets good search engine hits)
Under Raspbian/Pixel, the Print Screen key should save a PNG image of your desktop in your home folder. The configuration is defined in the file .config/openbox/lxde-pi-rc.xml, and by default it uses ‘scrot’.
mwilliams03
Re: Screenshot?
Tue Feb 28, 2017 3:43 am
there is also fbcat. which will capture whatever is in the framebuffer
Mark -- OzzMaker.com -- Creator of PiScreen - A 3.5" TFT for the Rasspberry Pi and BerryIMU.
n67
Re: Screenshot?
Fri Feb 23, 2018 12:50 am
Just to be clear, fbcat is for screencapturing the text mode (virtual console), not the GUI (desktop).
There is a man page for it at:
https://www.unix.com/man-page/debian/1/fbcat/
There is also something called "fbgrab" (above URL, make the obvious change).
Note that fbcat takes the text contents of the virtual console, and "graphicalizes" it into a PPM file.
The PPM file can then be converted to any other graphics format (PNG, JPG, etc) using, e.g., ImageMagick's "convert" utility.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
Laui
Re: Screenshot?
Fri Feb 23, 2018 4:55 pm
not the easiest way, but the smartest way is to install a graphic editor/programm like 'pinta' or 'gimp'. They can Screenshots
scruss
Re: Screenshot?
Sat Feb 24, 2018 2:10 am
AndrewFromMelbourne/raspi2png is pretty magic, too. Grabs the hardware framebuffer
n67
Re: Screenshot?
Sat Feb 24, 2018 9:51 am
Seems to do about the same as scrot or, for that matter, display from ImageMagick.
Not that I am saying otherwise, mind you, but is there any particular reason to prefer Andrew's program over either of these?
Epmu Sn!
Re: Screenshot?
Sat Feb 24, 2018 10:45 am
No one appears to have mentioned Shutter which is in the repositories:
http://shutter-project.org/about/
Adieu
n67
Re: Screenshot?
Sat Feb 24, 2018 11:13 am
Which, yet again, begs the question "Why?"
Unless you give some kind of justification - some kind of reason for wanting something other than 'scrot' (which is installed by default), nobody's going to go chasing a URL.
Epmu Sn!
Re: Screenshot?
Sat Feb 24, 2018 7:40 pm
Seeing this Post started 6 years ago, thought an alternative may be of interest, and Shutter is just an apt away:
https://packages.debian.org/stretch/shutter
Adieu
scruss
Re: Screenshot?
Sun Feb 25, 2018 3:46 am
raspi2png doesn't need X, unlike scrot or ImageMagick. If it's displaying to the framebuffer, raspi2png will grab it. Raw SDL like RetroPie? Works great. scrot and IM would give up on this.
Since I mentioned scrot before in this thread, credit me with enough intelligence to add something … Also, that's not what “begs the question” means.
Return to “Raspbian”
