GeorgS.
Tutorial Setting up a Raspberry Pi as an access point don't work anymore
Thu Oct 12, 2017 6:20 am
I spent lot's of hours in setting up an wlan accesspoint with raspberrypi and rasbian strech noobs 2.4.4. I followed this tut:
https://www.raspberrypi.org/documentati ... s-point.md
I read that this tut is at leased outdated since rasbian strech. I don't try it with jessy but I think it will also not work due to /etc/network/interfaces because this file is almost empty.
The problem is, that no accesspoint is visible.
Is there a new tut available?
Does anybody know for which version this tut works?
I also follow this tut:
https://elinux.org/RPI-Wireless-Hotspot
By using this I get an accesspoint but I don't get an internet connection.
Thanks so far.
George
epoch1970
Re: Tutorial Setting up a Raspberry Pi as an access point don't work anymore
Thu Oct 12, 2017 6:31 pm
The official tutorial was fine for Jessie. I tried it.
I do not use Stretch so I can't tell. User SurferTim seems adamant some updates are required to that tutorial, and he forked a new version of the documentation on GitHub
B.Goode
Thu Oct 12, 2017 8:31 pm
The documentation has a Github Issue open here: https://github.com/raspberrypi/documentation/issues/686
Maybe an "I am blocked on this" update there would flag it up to the maintainers?
The proposed update ("Pull Request") is here: https://github.com/raspberrypi/documentation/pull/735
it has not been approved by Raspberry Pi Foundation for release as official documentation.
Return to “Raspbian”
Who is online
Users browsing this forum: estorado and 23 guests
