evilkitty
Odd noise in audio playback
Sat Aug 12, 2017 10:19 pm
I have my pi setup as a headless server (link to pics in signature), i have a mpd server running on it to play mp3 files over it's audio output, now and then it will make a odd noise that is hard to describe (i really need to record it), but it takes a lot of time to happen usually happens the next day if i let it play overnight
when i first set this up using a regular B board on wheezy this was not a issue, but since upgrading to a b+ board with Jessie and re doing the inside of my case it now happens (too many variables to determine the cause)
odd thing it my card had got corrupt somehow and when i fixed it the noise quit happening for a few months (maybe the card is becoming corrupt again? but this issue was going on for at least 6 months before other issues manifested)
at first i suspected it was noise in the audio cable coming from the 110 AC to i put a higher grade cable in place
* i have confirmed it is not the speakers
* noise length varies from less that one second to a few seconds
has anyone experienced anything like this?
Pi config/kernel/cpu/os info
[email protected]:~ $ cat /boot/config.txt
# For more options and information see
# http://rpf.io/configtxtreadme
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
audio_pwm_mode=2
# Don't need GPU so it does not need more ram than required
gpu_mem=16
# Needed with newer kernerls than 3.12 to use thermel sensors
dtoverlay=w1-gpio
#Enable IR LED/Reciever (also see /etc/modules)
dtoverlay=lirc-rpi,gpio_out_pin=26,gpio_pin_in_pin=none
[email protected]:~ $ cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Enable IR LED/Receiver (next 2 lines)
lirc_dev
lirc_rpi gpio_out_pin=26 gpio_pin_in_pin=none
[email protected]:~ $ lsb_release -a
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 8.0 (jessie)
Release:	8.0
Codename:	jessie
[email protected]:~ $ uname -r
4.9.24+
[email protected]:~ $ cat /proc/cpuinfo
processor	: 0
model name	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 697.95
Features	: half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2835
Revision	: 0010
Serial		: 00000000d0d39aa1
My Pi Server: http://imgur.com/a/6xIUI | Thermostat: http://imgur.com/a/4LVnT
Return to “Raspbian”
Who is online
Users browsing this forum: il_diavolo and 21 guests
