rpi35
problème "make"
Fri May 09, 2014 1:09 pm
pi@raspberry ~ $ cd /home/pi/Documents/Jeux/SUPERTUX/supertux-0.1.3
pi@raspberry ~/Documents/Jeux/SUPERTUX/supertux-0.1.3 $ ./configure --disable-opengl
checking build system type... armv6l-unknown-linux-gnu
checking host system type... armv6l-unknown-linux-gnu
checking target system type... armv6l-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for unistd.h... (cached) yes
checking for an ANSI C-conforming const... yes
checking for gprof mode... disabled
checking for debug mode... disabled
checking wether OpenGL should be used... no
checking for sdl-config... /usr/bin/sdl-config
checking for SDL - version >= 1.2.4... yes
checking for Mix_OpenAudio in -lSDL_mixer... no
configure: error: SDL_mixer library required
pi@raspberry ~/Documents/Jeux/SUPERTUX/supertux-0.1.3 $ make
make: *** Pas de cibles spécifiées et aucun makefile n'a été trouvé. Arrêt.
Re: problème "make"
Fri May 09, 2014 1:16 pm
Votre problème
sudo apt-get install libsdl-mixer1.2-dev
chris57100
Re: problème "make"
Fri May 09, 2014 1:18 pm
C'est la commande configure qui génére le fichier Makefile nécessaire à la commande make. Tant que configure n'affiche pas que le fichier Makefile a été créé, make ne fonctionnera pas
Comme le dit DougieLawson, il faut corriger l'erreur avec la librairie SDL (et aussi peut être les suivantes)
Raspberry Pi Home Server : http://www.pihomeserver.fr
Software and electronic tutorials : Samba, Airplay, CUPS, Time machine, Nginx, Owncloud, rTorrent, Wordpress, etc.
Full Wi-Fi hotspot installation on a RPi 3 including a captive portal and freeradius management: https://github.com/pihomeserver/Kupiki-Hotspot-Script
rpi35
Re: problème "make"
Fri May 09, 2014 1:56 pm
Que voulez-vous dire par là :? :?
rpi35
Re: problème "make"
Fri May 09, 2014 1:59 pm
Après avoir testé sudo apt-get install libsdl-mixer1.2-dev, j'ai la facheuse surprise que le problème n'a pas disparu : Après avoir testé sudo apt-get install libsdl-mixer1.2-dev, j'ai la facheuse surprise que le problème n'a pas disparu. j'ai maintenant droit à un
checking for IMG_Load in -lSDL_image... no
configure: error: SDL_image library required
:cry:
Peut-on installer la librairie SDL en une seule commande ???
Re: problème "make"
Fri May 09, 2014 2:14 pm
sudo apt-get install libsdl-*
chris57100
Re: problème "make"
Fri May 09, 2014 3:27 pm
L'erreur suivante (celle qui est d'ailleurs arrivée).
Le site ne donne pas les librairies a installer ?
rpi35
Re: problème "make"
Fri May 09, 2014 3:30 pm
J'avoue que je ne sais pas, je suis un tuto de framboisepi.fr
rpi35
Re: problème "make"
Fri May 09, 2014 5:27 pm
Au risque d'être pénible, je voudrais savoir quel est le problème ici:
sudo apt-get install hostapd isc-dhcp-server iptables
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
iptables est déjà la plus récente version disponible.
Paquets suggérés :
isc-dhcp-server-ldap
Les NOUVEAUX paquets suivants seront installés :
0 mis à jour, 2 nouvellement installés, 0 à enlever et 58 non mis à jour.
Il est nécessaire de prendre 1 305 ko dans les archives.
Après cette opération, 2 783 ko d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer [O/n] ? o
Réception de : 1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main hostapd armhf 1:1.0-3 [419 kB]
Réception de : 2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main isc-dhcp-server armhf 4.2.2.dfsg.1-5+deb70u6 [887 kB]
1 305 ko réceptionnés en 3s (357 ko/s)
Préconfiguration des paquets...
Sélection du paquet hostapd précédemment désélectionné.
(Lecture de la base de données... 101748 fichiers et répertoires déjà installés.)
Dépaquetage de hostapd (à partir de .../hostapd_1%3a1.0-3_armhf.deb) ...
Sélection du paquet isc-dhcp-server précédemment désélectionné.
Dépaquetage de isc-dhcp-server (à partir de .../isc-dhcp-server_4.2.2.dfsg.1-5+deb70u6_armhf.deb) ...
Traitement des actions différées (« triggers ») pour « man-db »...
Paramétrage de hostapd (1:1.0-3) ...
insserv: warning: script 'mathkernel' missing LSB tags and overrides
Paramétrage de isc-dhcp-server (4.2.2.dfsg.1-5+deb70u6) ...
Generating /etc/default/isc-dhcp-server...
[FAIL] Starting ISC DHCP server: dhcpd[....] check syslog for diagnostics. ... failed!
failed!
invoke-rc.d: initscript isc-dhcp-server, action "start" failed.
LeSanglier
Re: problème "make"
Sat May 10, 2014 5:21 am
rpi35 wrote:Au risque d'être pénible, je voudrais savoir quel est le problème ici:
Tu veux installer quoi le jeu ou le serveur DHCP ??
Mon blog sur le Raspberry Pi : http://framboisepi.fr/
Pour avoir plus de chance d'avoir une réponse à votre question,
allez sur le forum français Rasberry Pi : http://forum.raspfr.org
rpi35
Re: problème "make"
Sat May 10, 2014 9:21 am
Non, là je suis ce tuto http://raspberry-at-home.com/hotspot-wifi-access-point/ pour installer un point d'accès wifi. Mais, il y a des erreurs. :x
chris57100
Re: problème "make"
Tue May 13, 2014 6:07 am
C'est marqué dans le texte !
Va dans /var/log, regarde les fichiers récents et leur contenu tu devrais avoir plus d'explications sur le problème pour que tu cherches la solution.
rpi35
Re: problème "make"
Tue May 13, 2014 7:00 am
Je ne comprend pas vraiment ce que je dois faire. Je dois chercher quoi dans var/log ??? Dois-je chercher syslog ???
Return to “Français”
